What Are Your Primary Speakers?
Cpyder
Cpyder Posts: 514
edited May 2010 in 2 Channel Audio
I wanted to start a poll-like thread discussing what speakers everyone uses on this forum, as well as some other specifics. I'll start us off. List your primary 2 channel rig speakers. Also post whether they are bookshelves or towers, whether you use a sub or not, the audio format you listen to the most, and what you like best about them.
Speakers: Polk Audio LSi9s
Type: Bookshelves
Sub: No
Audio Format Most Commonly Listened To: Digital lossless from computer
Most Favorable Aspect: I really like the realistic highs. Not to bright, not to soft.
Post edited by Cpyder on
«13
  • Cpyder
    Cpyder Posts: 514
    edited April 2010
    BlueFox wrote: »
    PSB Synchrony One towers, replaced my old SDA-2s. Source is 97% iPod Classic (Apple lossless), Wadia iTransport, Bryston BDA-1 DAC. Sony XA5400ES SACD is the other 3%, primarily to audtion CDs to determine if they are iPod worthy. I am auditioning a CD now. I love everything about these speakers and system. It is so clear, revealing, precise, etc., etc., etc.
    HT is 4 LSi15s and PSB Synchrony One center. Sony NS9100ES SACD for multi-channel SACD, and Oppo BD83 for movies. Sub for movies, not music.
    That's a very nice setup. Good work! How do you like the Bryston?
    I should probably add that I'm using the DAC in my Marantz SR5003.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2010
    Speakers-SDA 2A's
    type-floorstanders
    sub-Not currently, though I'd love to try some stereo subs eventually
    Audio format-50% CD, 50% vinyl
    favorite aspect-SDA effect!! Excellent low end output, liquid midrange, smooth highs...I guess I just love everything about these speakers.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • samnor
    samnor Posts: 155
    edited April 2010
    Speakers: wharfedale diamond 9.6
    Type: floorstanding 3 way
    Sub: Yes, wharfedale sw250
    Audio Format Most Commonly Listened To: CD
    Most Favorable Aspect: warm sound, tight bass
    Fronts: Wharfedale diamond 9.6
    Sub: Wharfedale sw250
    Rears: Wharfedale diamond 9.1
    Center: Paradigm cc-350
    Pre-amp: Oppo dv981hd
    Amp for fronts: Parasound hca-1500a
    Amp for rears: Adcom gfa-5400
    Amp for center: Marantz MA500 monoblock
    Polk multimedia speakers for PC setup
  • Hawkeye
    Hawkeye Posts: 1,313
    edited April 2010
    Speakers: Martin Logan Spire
    Subs: A pair of JL Audio F112's
    I have three sources: 98% of listening is by CD or XRCD
    1% is vinyl
    1% is XM Radio by the better half.
    I've found the Spire and JL subs are a great match. The transparency and accuracy of the panel combined with the solid bottom provides a combination that I find quite pleasing. Of course, room treatments are a large factor in the room sounding as good as it can.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • Knucklehead
    Knucklehead Posts: 3,602
    edited April 2010
    Speakers: baby Advent ii ....slightly modded
    Type: Bookshelves
    Sub: No
    Audio Format Most Commonly Listened To: Digital lossless from computer and standard CD's
    Most Favorable Aspect: Nice clean neutral sound with very good low end.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • doctor r
    doctor r Posts: 837
    edited April 2010
    Speakers: Aurum Cantus Lesiure 3 SE
    Type: Monitor
    Sub: No
    Audio Format: Vinyl 65%, CD 45%
    Favorable Aspect: clear extended highs (ribbon tweeter) with a realistic stage presentation.
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
  • skipf
    skipf Posts: 694
    edited April 2010
    I'm using Carver ALS Platinums in my main rig. No sub required with these, the 4 12" woofers in each do just fine. Full range speakers with incredible soundstage, crystal clear highs, warm midrange and bass you feel as well as hear. Their only downside is they require massive amounts of power and headroom to drive properly if using SS amps like I am. Tube amps in the 180 watt range do even better than my 575 watt monoblocks.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited April 2010
    Hawkeye wrote: »
    1% is vinyl
    Gordon
    Gordon, I've got to get over there & hear your setup soon! :D
    My setup:
    Speakers: Carver Amazing Loudspeakers-III (AL-III)
    Type: Full-range, 6 feet tall!
    Sub: Klipsch RT-12d
    Audio Format Most Commonly Listened To: SACD/CD
    Most Favorable Aspect: Imaging is phenomenal. I've done some customizing with the woofers on mine & they have a great low end. :cool:
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • Dawgfish
    Dawgfish Posts: 2,554
    edited April 2010
    Speakers: Polk Audio SDA-1Cs with RDO-194 tweets
    Type: Full Range
    Sub: No
    Audio Format Most Commonly Listened To: Lately it's been about 50% Vinyl, 50% CD
    Most Favorable Aspect: I think Curt really summed it up well the way I feel about my SDAs. I love the SDA effect with it's wide and deep soundstage, great bass and midrange, and good highs. These speakers really get me emotionally involved with my music.
  • erniejade
    erniejade Posts: 6,321
    edited April 2010
    For me, primary speakers depends on what I am listening to...
    For rock or dance, Polk 1.2 Carver C-19 tube pre, Jolida cd100, Technics 1200 with a denon DL160 on a McIntosh 2105.
    For Jazz or classical, the same as above except the speakers are Carver Amazing 0riginal, with a Sunfire Sig. II 625 X 2.
    If I just want pure volume or just want to rock out, I add in the polk 2.3 1.2 at the same time on the McIntosh, and Integra amps. I put the cable on the 1.2's on the outside and the 2.3's on the inside. OMG the place just shakes.
  • Timothy Smith
    Timothy Smith Posts: 764
    edited April 2010
    Currently Dahlquist DQ-10's.
    The only mods are that I removed the Piezo "screecher" supertweeter and replaced the stock tweeter with Vifa ring dome radiators like those in Polk Lsi series.
    I supplement the low bass (just a little) with a HSU STF-2 sub through a Dahlquist outboard subwoofer crossover.
    I am amazed how good this early/mid 70's speaker still sounds.
    Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player
  • wayne3burk
    wayne3burk Posts: 939
    edited April 2010
    Speakers: Polk Monitor 10bs
    Type: Full Range (speaker stand - standing)
    Sub: JBL PW10
    Audio Format Most Commonly Listened To: Vinyl 50% - Streaming Internet Radio (128bk MP3 or Flash) 50%
    Most Favorable Aspect: Smooth mids and highs, excellent bass - Listen primarily to Jazz
    -- wayne --.
    Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
    nooshinjohn Posts: 25,905
    edited April 2010
    Polk Audio SDA-SRS 2.3TL's
    Rogue Audio Perseus Tube Pre
    Sunfire Cinema Grand 425~5
    Yamaha PX-3 Turntable (80%) Carver SDa-490t cd player (20%)
    Most favourable... shear power, clean mids/highs with tight accurate bass, and the soundstage is MASSIVE.
  • concealer404
    concealer404 Posts: 7,440
    edited April 2010
    Speakers: Paradigm Esprit V.3
    Type: Floorstanders
    Sub: No
    Most Favorable Aspect: Everything. What now?
  • madmax
    madmax Posts: 12,434
    edited April 2010
    Speakers: Avantgarde Duo
    Type: Big **** Horns
    Sub: DecWare
    Most Favorable Aspect: Dynamics/High efficiency
    Vinyl, the final frontier...
  • muncybob
    muncybob Posts: 3,238
    edited April 2010
    Speakers; Vandersteen 2CE
    Type; floorstanders
    Sub: Mirage
    Format: mostly cd
    favorite aspect: detailed mids, good soundstage but I'm sure would be better if the room allowed it!
    Yep, my name really is Bob.
  • steveinaz
    steveinaz Posts: 19,545
    edited April 2010
    Speakers: Fritz Speakers Carbon 7 monitor
    Type: Stand mount monitors
    Sub: No (2-channel only)
    Audio Format Most Commonly Listened To: Digital from CD Transport to DAC
    Most Favorable Aspect: Seamless integration, tonal balance
  • thuffman03
    thuffman03 Posts: 1,325
    edited April 2010
    Speakers: Carver ALIII's
    Type: Full Range 6' tall floor speakers
    Sub: Sunfire True Sub MkII
    Audio Format Most Commonly Listened To: CD and streaming audio through Rhypsody.
    Most Favorable Aspect: Will get very loud and sound great at any level and has lots of base.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • yepimonfire
    yepimonfire Posts: 256
    edited April 2010
    Speakers: Sony SF-5000
    Type: 3-way Floor standing
    Sub: Polk PSW10
    Audio Format Most Commonly Listened To: AAC from an Ipod
    Most Favorable Aspect: Covers the entire audio range, system is a 4-way meaning each driver is only required to cover 3 octaves. Like the timbre of the Kevlar drivers in the mains, sounds tight, produces awesome mid-range that i have not been able to get from paper cones.
    mhardy6647 Posts: 34,982
    edited April 2010
    Speakers: Altec Santiago
    Type: High-sensitivity two-way, sealed box LF, Horn HF floorstanders
    Sub: Atlantic Technologies powered 10"
    Audio Format Most Commonly Listened To: Redbook CD and vinyl
    Most Favorable Aspect: Outstanding midrange reproduction
    Three pairs of loudspeakers are in regular rotation on the real hifi in the living room: the Santiagos (which replaced a pair of 846A Valencias because the Santiagos were in better cosmetic shape), Quad ESL-57s, and DIY mass loaded folded, tapered quarter-wave tubes loaded with Radio Shack 40-1354 twincone fullrange drivers (equipped with Dave Dlugos' phase plugs). All three of these loudspeakers "get the midrange right".
    Here's the scoop on the ML TQWTs, designed by Bob Brines, for anyone interested: http://brinesacoustics.com/Pages/Proposals.html
    I have a pair of purchased-new Polk Audio Monitor Series Model 7A in our family room that are in regular use for radio and TV/noncritical listening. They sounded great in 1978 and still do.
  • zingo
    zingo Posts: 11,258
    edited April 2010
    Speakers: Klipsch Forte
    Type: 3-way Floorstanders with horn highs and mids
    Sub: Don't need one :)
    Audio Format Most Commonly Listened To: SACD and PC based 96khz/24bit
    Most Favorable Aspect: High sensitivity for use with tubes and powerful presentation
  • Cpyder
    Cpyder Posts: 514
    edited April 2010
    I'm seeing a lot of sweet designs here. I'm interested in knowing how electrostatic speakers work and even more interested in how they sound.
  • HHStuart
    HHStuart Posts: 263
    edited April 2010
    See my sig for speakers.
    I am only listening to SACD's right now.
    Sound can be outstanding.
    Variety is quite limited though.
    Front - Polk LSiM 705, Center - Polk LSiM 704c, Rear - Polk LSi 7
    Subwoofer - Epik Legend
    Receiver (as Preamp) - Sony STR-DA3400 ES
    Amplifier - Outlaw 7125
    Television - 58" Samsung Plasma PN58B860
    Blu Ray - OPPO BDP 83
    edited April 2010
    Cpyder wrote: »
    There is a thin film of conductive plastic (Saran, in the case of the Quad ESL-57s) suspended between electrodes. The whole shooting match is in an electrostatic field (ca. 5 kV at minuscule current); application of an offset voltage derived from the input music signal makes the membrane "flutter" within the field, thus producing sound. It's similar in action to a ribbon or planar driver, but the "motor" is an electrostatic field instead of a magnetic field.
    They sound great!
    (EDIT: Those who know the vintage Quads well will recognize that mine are footless! They are carefully propped up to the correct angle for my listening chair in the photo... and I do have a pair of aftermarket stands for them)
  • 98Badger
    98Badger Posts: 317
    edited April 2010
    Speakers: Paradigm Signature S8's
    Type: Floorstanders
    Sub: JL Fathom F112
    Audio Format Most Commonly Listened To: Redbook CD or WAV from the computer
    Most Favorable Aspect: Female vocals from the Be tweeters
  • hearingimpared
    hearingimpared Posts: 21,136
    edited April 2010
    Cpyder wrote: »
    Type: Bookshelves
    Sub: No
    B]Speakers:[/B] Polk Audio SDA/SRS 1.2TL RD0198s, upgraded xovers with Sonicaps & Mills resistors, Dynamatted, drivers sealed, Myesound spiked and Cardas posts.
    Type: Huge Monkey Coffins
    Sub: I don't need no stinkin' sub!
    Audio Format Most Commonly Listened To: Vinyl/SACD
    Most Favorable Aspect: I can only say, EVERYTHING!
  • jm1
    jm1 Posts: 618
    edited April 2010
    Speakers: Dynaudio Confidence C1 (mass loaded Stand 4)
    Type: monitor
    Sub: (2) SVS PC-Ultra
    Crossover: Bryston 10B – Sub (1st/1st @80Hz)
    Audio Format Most Commonly Listened To: digital cable, CD, LP
    Most Favorable Aspect: The latest phase of room acoustic optimizations has ended with redistributing/refining the tube trap placement, then designing and implementing an enhancement to another treatment. The latest enhancement realized more benefits than expected which forced me to once again, more precisely locate the monitors (and subs) as well as refine the monitor/sub interface. I had to resort to a shadowing technique to visually see the small increments necessary for the gain and phase adjustments. Anyways, the acoustic refinements have provided startling results while attaining a new level of coherence. It will be interesting to hear the results of the next phase of treatments once the designs are finalized and construction completed.
    All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident.
    Arthur Schopenhauer
  • hearingimpared
    edited April 2010
    jm1 wrote: »
    Type: monitor
    John, if I post the longitude and & latitude of my home would you come here and help achieve the above?;):D
  • jmwest1970
    jmwest1970 Posts: 846
    edited April 2010
    Speakers: Totem Rainmaker
    Type: Bookshelf
    Sub: None, but I'd love to try a Totem Storm.
    Audio format most commonly listened to: CD/SACD/FLAC
    Most Favorable Aspect: No fatigue. When listening to SACD I have to ask myself if I'm in the room with the artist during the recording.
  • jimreeves
    jimreeves Posts: 57
    edited April 2010
    Speakers: Infinty Quantum Linesource
    Type: Monoliths
    Sub: yes, but not for two channel
    Most Favorable Aspect: Effortless BIG soundstage:D
    Infinity QLS1, Polk SDA-1A, OLAdvent Econowave, Yamaha RXV-1300, CDC-685, P2200, AB International 9220A, Rane ME15B, Cambridge Audio 640P, Grant Fidelity B-283, Luxman PD277-AT7V, Pioneer PL707-Denon DL-207, DL-160....And projects on the bench!
