Thoughts on NAD M25 multi-channel amp.
pearsall001
I've been giving a lot of thought about a multi-channel amp lately. As Cfrizz would say...buy a good one once & you're done!!! I've done a lot of research at read a ton of reviews on quite a few amps from various manufactures. I have to admit I am a bit biased towards NAD because I like their "house sound", conservative power ratings, performance & their customer service has been top notch for me. I thought about a 5 channel amp but now I'm leaning to a 7 channel amp & use the two unused channels to bi-amp my mains. I know it's not identical to using a separate amp to bi-amp but it still is a nice feature.
http://nadelectronics.com/products/home-theatre-amplifiers/M25-7-Channel-Amplifier/details
I know there's plenty of great multi-channel amps out there to choose from but the NAD is tops on my list. I'm buying used vs new.
Post edited by pearsall001 on
Sounds like a good call for you then. The amp appears to be a modular "card-type" design. Can you get any pictures if the inside of the amp?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I haven't come across any pics of the unit's inside layout yet.
I have not heard this amp in person but we have the 2 channel integrated on the floor and it sounds amazing. Your welcome to stop by and listen to it , it should give you a good idea on how this awesome amp performs. I'll ask the guys and see if anyone has Installed it.Dan
pearsall001 wrote: »I haven't come across any pics of the unit's inside layout yet.
Why would you need to see the inside layout? Would that make or break your decision?
Dave -
Phil, you already answered your question. NAD is NAD and you won't get much better until you get into the higher end multi-channel amps which will come with a price tag to match.
dave shepard wrote: »Why would you need to see the inside layout? Would that make or break your decision?
Dave
I was the one that asked.:)
I have some suspicions as to the lineage of the amp that the OP is asking about.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I found an interior shot of the amp. It uses a module type design as I suspected. Not saying this is good or bad, but I prefer a massive power supply rather than individual amp cards.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
As do the vast majority of multi ch amps,though all channels share a single common supply.nooshinjohn wrote: »It uses a module type design as I suspected.
With that hefty transformer in the front of the chassis, the power supply looks to be plenty capable.Idealy each channel module would have its own independent transformer but that would push the price up substantially.but I prefer a massive power supply rather than individual amp cards. -
Nice write up Kex. I've always been a fan of NAD for all the reasons you've just stated. Plenty of real world performance, not a lot of useless bells & whistles & the ability to run 4ohm loads all day long without breaking a sweat. Even a 2ohm load can be handled with their dynamic power. But I must confess though that the M25 is still tops on my list. I think the M25 takes even their great multi-channel amps to a whole new level. Not to mention how gorgeous it looks.
pearsall001 wrote: »I've been giving a lot of thought about a multi-channel amp lately. As Cfrizz would say...buy a good one once & you're done!!!
I totally support and agree with what Cfrizz stated, the same goes with speakers. Those two items are the last to be upgraded and you would only have a need to do so when your looking for a change.
Dave -
Yes, very nice practical write-up Kex. I followed your logic when putting together my system--although maybe the result was driven moreso from budget vs. free choice--and I can say I'm pleased. but, wow, the thought of throwing an M25 into the mix would just be a tough one to handle. oh, the agony...HA!
good point on the chassis space. I also wonder about the physics here...isn't one 2-channel C270/272/275 amp nearly the same physical dimensions as an 755/765/785/ etc AVR or multi-channel amp such as 955 or 975? if so, then from simplistic engineering perspective, it would seem that a 2-channel amp is designed to dissipate heat better...and 2 external amps even better yet (i.e. 4 channel power in twice the volume of both space and metal). mabe forced cooling negates the need for larger sinks & space.
Anyway, i'm new to all this and your forum. threads like this are great, especially us long-time NAD loyalists.
Good luck with the decision Pearsall...its gonna be sweet anyway you go I'm betting!Thanks!
Searay40dad
Family Room HT/2 CH
NAD T765hd AV Receiver
NAD T550 CD/DVD
NAD C270 Amp (L Ch/HF bridged)
NAD C270 Amp (R Ch/HF bridged)
Polk Rti12 mains
Polk CSi5 center
Polk PSW505 & PSW303 subs
Polk FXi A6 surrounds
Dish 722HD/DVR
Samsung 50" plasma
Sony Blu-Ray
Weight Room (aka vintage sound rm)
NAD 3130 Int Amp
Denon DCD-810
NAD 4150 Tuner
Polk 10B monitors (still sound amazing) -
I've had good experiences with new and used/demo NAD gear from these guys. I like to check in on their "recent addition" gear in the USED link. Seems like they have Masters Series demo specials semi-often.
http://www.saturdayaudio.com/Thanks!
Searay40dad
Family Room HT/2 CH
NAD T550 CD/DVD
Polk Rti12 mains
Polk CSi5 center
Dish 722HD/DVR
Samsung 50" plasma
Sony Blu-Ray
NAD 3130 Int Amp
Denon DCD-810
NAD 4150 Tuner
No doubt NAD makes some nice gear although it can be a little colored at times. You're best bet is an Emotiva XPA-5. Reference quality sound for only $799 new.
:rolleyes:I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
NAD is known for their warm house sound, there is no "at times" here. You either like the sound, which I know for a fact that Phil does, or you don't. I don't know if comparing NAD gear to Emotiva gear is sound advice as I've never heard Emotiva gear, but everyone is entitled to their opinion.
I'm just curious. Have you compared NAD gear to Emotiva gear? What experience do you with either? Can you post the differences and your like and dislikes. I'm very curious as I've yet to see anyone here speak NAD and Emotiva in the same sentence so you insight and experiences would be appreciated.:) -
I've never heard anyone suggest NAD sound was "colored at times" before, so that's a first, and it's certainly not my opinion. I would describe NAD sound as leaning slightly toward the warm side of neutral, and it's very consistent, even over twenty years of different product generations. In any case, either you are of the belief that all amps have a "house sound" and could therefore be described as "colored at times", or all amps are equal, and the more watts the better.
As for comparing NAD and Emotiva, I have owned both, and clearly the modest numbers from NAD appeal to my ears and listening tastes more than the big numbers Emotiva likes to boast about. Personally, I would spend $1,000 on a C275BEE long before I would spend $825 on an XPA-5. You only have to try a NAD integrated rated at 40-50w/ch, or a JoLida integrated rated at 30w/ch to make sense of this IMO. YMMV, of course.
Maybe I just don't have what it takes to appreciate "Reference quality sound".
My 50wpc NAD C320BEE is still one of my favorite amplifiers I've heard, and is easily my favorite if you consider price. You need to far surpass the $400 MSRP to get a good increase in SQ, and that's what NAD is all about. Plus, they handle the 4 ohm load of my LSi7's without breaking a sweat; its never gotten more than slightly warm.
I doubt I will upgrade until I can afford the M3 integrated
- Jeremy
Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
Speakers: Polk Monitor 7A's, KEF Reference 104aB
Sources: ProJect Debut Carbon, Sonos streaming FLAC -
WAAAAAAAAAAAAAAA @ your reason for editing!!!
BTW, excellent points made above and it's basically saying what I wrote in a previous post. -
Ah! So the truth will out! If it's because of "how gorgeous it looks", then your fate is sealed, my good Sir, and there's no point in trying to use the analytical approach to convince you otherwise! I think you had better just get one and be done with it in that case!
There are two for just under $2,000 on AudiogoN right now (before shipping, but maybe you could negotiate that, or even split it, since they weigh over 100lbs boxed). One sold recently for $1,700 "firm", and it was gone in a flash BTW. I think it's unlikely you'll find them for less, but sometimes I've seen bargains on eBay for some other NAD gear. I don't think the discreet NAD look, and lack of flashy buttons or lights, always goes down very well with the average eBay buyer.
Spearit Sound also sells used gear and former demo units in one section of their website, which at least gives you the option to ask all the right questions to a true professional before purchasing, but you'd have to watch constantly and wait for one to become available.
http://www.spearitsound.com/specials.htm#Multi-Channel_Power_Amplifiers_
Now I wouldn't go that far even though the M25 is a looker for sure. I do base my decision on performance first, cost, then if the piece happens to be high on the eye candy chart then that's a plus.
spearitsound & saturdayaudio are approved NAD online dealers (got that straight from an email to NAD).
As Joe has mentioned I do like the NAD "house sound" & that is a big factor in choosing my purchase. At the M25's price point there is stiff competition but for now the M25 is still #1 on my list. -
Emo is even more colored. NAD everytime over Emo.
Emotiva makes very neutrel sounding amps. www.emotiva.com. -
You could grab a Mcintosh MC7205 in that price range as well...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I'm sure Emo makes a good amp...I've looked at them & I'm not really interested. I'm looking for feedback on the NAD M25 amp & possibly others in that same price range.
I'll have to check into that Mac MC7205 also. Thanks for the info. -
"Neutral" is not a word that most people who have heard them AND other gear would use to describe Emo amps.
Regardless. This is not an Emo thread. This is a NAD thread. Please feel free to start another thread telling everyone to buy Emo amps.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
pearsall001 wrote: »I'm sure Emo makes a good amp...I've looked at them & I'm not really interested. I'm looking for feedback on the NAD M25 amp & possibly others in that same price range.
Nothing wrong with that. NAD makes great gear too. If you like a colored sounding amp then you can't do much better than NAD. -
Seems like a lot to spend for a HT set-up, unless you're looking for the Ultimate set-up. Certainly miles better than Emo or Outlaw. Of course Rotel makes a multi-channel amp as well as Adcom, Parasound, Lexicon, Sunfire, Cineova.
I would think a NAD T-975 would be more than sufficient. What processor are you running with it? Why not look into the powerhouse NAD receiver? How much do you need for HT especially if you're running a powered sub?
Just throwing some idea's out there.
But it's ok to talk about MacIntosh?:rolleyes:
Let's be fair ok?
Last I checked, the OP is open to other considerations, and to be fair, Mcintosh trumps Emo every single time.;)
What I fail to understand is why every single thread discussing amps must be infected with Emo. Can't you guys just give it a rest already?
:mad: The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
^^ Pretty much. The OP stated the E word is not on his list.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
*yawn*"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
That's exactly what I'm focusing on doing. I want the multi-channel amp to handle the HT end of things & also my two channel venue. From what I've read the M25 excells in both areas. This also gives me the flexibility of moving to a dedicated pre for both HT & two channel also. Right now I'm using the NAD T765 AVR for both duties & it does a superb job.
Here again NAD has a tremendous piece...the M15 HD AV which is also on my radar. As far as the subs go, that end is very well covered with dual Velo SPL-1200R subs. I like the flexibility of a combined HT & two channel system. It works great to fit my needs & room.
The other companies you mentioned have fantastic multi-channel amps & I've looked at many of them. -
Well, if your looking for 2ch duty as well, then it's probably a very good choice. So initially you're going to use your NAD T765 as a pre/pro?
