Paradigm PW-2200
Do your PW-2200 have the 400 watt RMS amp with 1500 watt peak or is it the older version?Main System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a -
The older version.
Do you think one of the new ones would do in a room 20x13x7?Main System:
Second System:
I'm sure the 2200 would do just fine. This is a very potent sub. Only bested by a handful of sub. And in this price range, a very good buy. I think that in Tom Nousains subwoofer list, the 2200 had a higher average spl than the servo 15. Maybe not as musical though. Careful not to set it too close to a wall. With a port that size, it really needs to breath. With your ht room being 20 ft. long, that shouldn't be a problem.
What do you think is a better sub, the Paradigm PW-2200 or the SVS PB1-ISD?Main System:
Second System:
Does anyone know what the surround materiel on the driver of the PW-2200 is? What about the PS Series Driver?
What kind of materiel is the best suited for a sub? Foam, rubber, I don't know.
Main System:
Second System:
Does anyone know how big the surround is on the PW ans PS series drivers?Main System:
Second System:
I just received an e-mail from Paradigm and he told me the surrounds on the PW-2200 are "a new formulation foam rubber that is treated to ensure long life."Main System:
Second System:
What does FWIW mean?
I do not know all the short terms.Main System:
Second System:
ThanksMain System:
Second System:
