Pio Elite AVR features
kevhed72
I have a Pioneer sc-05 AVR and overall love it. There is one feature I am unsure of though...there is a "phase-control" function. I have read the manual numerous times on this feature, but I am still unsure about it's usefulness. With both 2-channel and HD listening, turning the phase-control ON just gives a different color to the sound, not necessarily "better". Thoughts on the phase control function would be appreciated.....
Secondly, the AVR comes with a DIALOG ON / OFF function for HT. I usually have it ON to make HT dialog more easy to listen to. Last night I turned it OFF for a bit and found watching TV almost annoying due everything coming out of the center channel (CSiA6) was so flat. Thoughts / experiences with this function.....
(maybe my center channel would benefit from a separate AMP!)
Post edited by kevhed72 on
I was wondering the same thing about the phase control function. Hopefully someone can offer some input on this.panasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one -
superjunior wrote: »I was wondering the same thing about the phase control function. Hopefully someone can offer some input on this.
Send Mantis a PM. He's the resident expert -
Never tried either of these but will tonight and chime in sometime.Shoot the jumper.....................BALLIN.............!!!!!
Ok here's the bottom line in all things Phase.
Phase control in the Elite receivers think of this like a time alinement tool. It measures all phase of each channel of your speaker system using MCACC.
You do not use this feature manually , MCACC will do it all for yeah. Run MCACC and Phase will be set automatically.
Please read the manual fully about MCACC and use their guide lines.Dan
Thanks again Danpanasonic th-50pz85u
emotiva xpa-3
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
harmony one
