sub with 2 channel
13»
  • Krazyz1
    Krazyz1 Posts: 256
    edited February 2010
    COOL set up!!!! In the photo looked like all the goodies were plugged into a power rail. Any consideration on dedicated services and power conditioning?. Just being nosy.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    Krazyz1 wrote: »
    The house was new when we bought it so I had them install a dedicated 20amp circuit behind the center cabinet.
    I have an ancient Audio Power Industries "Powerwedge I" power conditioner - beast weighs a ton, but probably time to upgrade it.
  • classic carl
    classic carl Posts: 691
    My full range towers go down to 33 Hz. I have my sub crossed over at 40 Hz. There isn't much overlap and the subs output is very subtle, but it makes a big difference in the overall sound. I have 2 outputs on my preamp. One to the power amp and the other to another pre that I'm using passively to control the volume of my sub.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ (2x) Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2
    Teac R-919X ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Winter Residence 2.1 (laptop system):
    Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
  • Krazyz1
    Krazyz1 Posts: 256
    My system very similar. My Rotel pre. has 2 sets of outputs. So 1 set go to main amp , other gives me dedicated L. R. for subs.
