Fun With Foam: SDA Driver Basket Insulation
13
  • Schurkey
    Schurkey Posts: 2,122
    edited February 2010
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=268-030
    Two and a half sheets (I ordered four sheets, but didn't need it all) of this stuff was enough for my 1Bs. Reasonably flexible; inexpensive; easy to work with. I did NOT mummify my drivers or PRs. I slapped a ~1" wide strip on each spoke, and a narrower strip or a dot anywhere else I could make it fit.
    They swear it's not asphalt-based. OK. I don't have an MSDS for the stuff.
    The new tweeters are still "breaking in"; I suppose the new caps in the crossovers are, too. I have no listening test results; or long-term damping-material adhesion results to report...yet.
    While a lot has been said about the brand name "Moretite", there are other products that are essentially the same thing--the stuff I bought was "ComfortSeal by Dennis"; with the words "Rope Caulk" prominent on the packaging. Should have gotten the black stuff instead of white.
    treitz3 Posts: 19,989
    Hmmm, I'm gonna have to try this on the Linbrooks one day. Thanks for the thread and continued observations.
  • hearingimpared
    hearingimpared Posts: 21,136
    Schurkey wrote: »
    I bought a whole box of Dynamat, I think it had four sheets, and only used 4/5ths of a sheet on my 1.2TLs. I covered all the spoke and the round rim before the magnets of the MWs. Same with the PRs.
    I didn't use Mortite. I used Parts Express speaker sealer which was really easy to apply and move around and once squashed it did a nice job. I even used it to seal up a two foot split in the side seam of the cabinet. The other thing I liked about it is that each "rope" was relatively thin so I could meter the amount, more or less as needed, for each hole and it is black in color.
    F1nut Posts: 51,756
    The meter was set to C weighting with slow response.
    Bare driver: Average 90 dB-C (rang like a bell).
    Foam treated driver: Average 82 dB-C (dull "thunk" sound).
    Dynamat Xtreme treated driver: Average 74 dB-C (quieter dull "thunk" sound).
    Only you Raife. ;)
    I must say 16 dB is significant.
  • hearingimpared
    Only you Raife. ;)
    LOL!!! I was thinking the same thing on both points.
  • Face
    Face Posts: 14,340
    treitz3 wrote: »
    Those baskets shouldn't need dampening.
  • hearingimpared
    treitz3 wrote: »
    Face wrote: »
    Interesting! What material is used on those baskets? I assume by your statement they are not just stamped out metal.
  • Face
    Face Posts: 14,340
    Correct.
  • hearingimpared
    Face wrote: »
    Correct.
    Wow that is really sleek looking . . . sexy!
    Tom are you seeing this? Maybe you should rethink the Dynamat thing or at least give a basket a thunk test.
    F1nut Posts: 51,756
    I agree, no Dynamat needed.
    Well, alrighty then. If I were to do the "thunk" test, what exactly would I be doing? Hitting it with a wood object, metal or fingernail? I take it that I'm just looking for resonance within the braces of the baskets? What would be acceptable? Thud or dead sound within a certain time frame?
  • hearingimpared
    treitz3 wrote: »
    Tap it gently with a screwdriver and see if it rings or thuds. If it thuds no Dynamat needed, if it rings, let me know and I'll send you the Dynamat.
  • Janne
    Janne Posts: 139
    edited April 2010
    Would Dynamating the inside of the cabinet be an improvement? I also ordered a bunch of Dynamats and it looks like there will be a few left after the basket tweak.
    HT/2 CH
    McIntosh MX120, MC500, MC206, MEN220
    polkaudio SDA SRS 1.2TL, XO, Inductor, Tweeter, Larry's rings, WBT Binding posts, Moretite and Dynamat mod. Built by Mollie Jones 27:th of February 1991, CS350-LS XO mod, LS-f/x, DSW MicroPro 4000
    MIT Shotgun S3.3 Bi-wire SC, Shotgun S3.3 SC, Shotgun S3.3 Proline IC, Shotgun S3.3 IC, Shotgun S3.3 Sub cable, AVT 1 Optical IC, EXP 3 Speaker interconnect.
    F1nut Posts: 51,756
    edited April 2010
    I would not recommend that.
    Did you order Dynamat or Dynamat Extreme?
  • Janne
    Janne Posts: 139
    edited April 2010
    I ordered the Extreme.
    My thoughts were that there are nothing behind the PR but plenty of glass fibre or whatever material behind the midrange and tweeters. :confused:
    HT/2 CH
    F1nut Posts: 51,756
    edited April 2010
    The Extreme, good!
    You don't want anything behind the PR as that would interfere with its operation.
  • Kline
    Kline Posts: 10
    edited August 2012
    What would be the difference if we did end up going for the Dynamat material? Partsexpress has a nice form of dynamat at a fraction of the cost!
    Shawn.
    PS audio Delta 200/PS Audio 6.0
    Polk SDA SRS 2.3
    12" DVC sub/Rocketfish RBKIT
    Kenwood Basic M2A/DBX 120X-DS
    Oppo DV-970HD/Modded Adcom GDA-600
    F1nut Posts: 51,756
    edited August 2012
    There's always a reason for things like that.
  • teekay0007
    teekay0007 Posts: 2,289
    edited August 2012
    Kline wrote: »
    Shawn.
    You can get plenty more than enough (a 4 sq-ft sheet) Dynamat Xtreme to do your speakers on Ebay for around $25 shipped. I recently paid $24.50 and it was more than I needed to do my SDA-2Bs and Monitor 10Bs.
  • StuartB
    StuartB Posts: 87
    edited August 2012
    Kline wrote: »
    Shawn.
    Hi Shawn. I recently upgraded a pair of Monitor 5B speakers. I rebuilt the crossovers, upgraded to RDO tweeters, installed hurricane nuts, used Armaflex for gaskets and used Parts Express Sonic Barrier to dampen the frames on the Midwoofer and Passive Radiator. I read the threads about Sonic Barrier and Dynamat Extreme.....for me it was a cost/benefit issue. I am completely satisfied with the lower cost Sound Barrier.nit was easy to use and definitely did its job. I am sure that Dynamat is somewhat more effective , but for me Sonic Barrier was the best choice. Good luck and have fun!
  • Dawgfish
    Dawgfish Posts: 2,554
    edited August 2012
    I just want to add to SRS 2 owners out there to be careful with the sonic barrier. I read about all of the improvments with the sonic barrier and followed the advice giving about just placing thin strips of the material on the back of the cabinet directly behind the MWs and not in the passive radiator area of the cabinet. I had a similiar effect with just the thin strips added to what others here on the board had when they added too much of the sonic barrier. It sucked the bass slam and dynamics right out of the speaker. I didn't really notice any increase in resolution either. I tried it for a couple of days, but took it out after that. I even tried just using one three inch wide by 12 inch long stip in each cabinet and even that didn't sound as good as stock to me. The only thing I can figure is that since the SRS 2s have the MWs mounted much higher up in the cabinet than the 1Cs, there is a lot of bracing in the upper portion of the cabinets of the SRS2s that is not present in the 1Cs. Therefore the SRS 2 cabinet is probably not as resonant as the 1C cabinets. It's been a couple of years since I owned some 1Cs, so I cant confirm this for sure, but I believe this is the case. Any others out there with SRS 2s have any experience with this?
    F1nut Posts: 51,756
    edited August 2012
    Sonic Barrier and Dynamat Extreme work differently. Therefore, one should not be substituted for the other.
  • Dawgfish
    edited August 2012
    Just to be clear I did put Dynamat Exteme on my MW and PR baskets with good success. I applied the Sonic Barrier to the inside of the cabinets on the back wall directly behind the MWs. I did not have good results with the Sonic Barrier in this application with the SRS 2s.
    F1nut Posts: 51,756
    edited August 2012
    Dawgfish, no worries. My comment was directed towards StuartB or anyone else thinking about what he did.
  • TennMan
    TennMan Posts: 1,267
    edited August 2012
    The Extreme, good!
    Is that true for all Polks? My 10Bs have the stock white sound absorbing material all the way from top to bottom on the back wall of the speaker. Should I remove it from the MW down to the bottom behind the PR? Thanks.
  • Dawgfish
    edited August 2012
    Thanks Jesse! It's all good.
  • StuartB
    StuartB Posts: 87
    edited August 2012
    So not sure I understand. I used Sonic Barrier only to dampen the frames of the WM and PR when I had everything apart. I did not apply to the cabinet at all. It clearly reduced any ring I got when tapping on the frame. Are you saying that this was an incorrect application of this product? I thought I had read that this had been done with success by members of this group. I would guess that Dynamat may be more effective but I also thought that both products had similar purpose.
    F1nut Posts: 51,756
    edited August 2012
    TennMan wrote: »
    It tends to fall down over time. Simply shove it back up behind the MW's. You can put a staple or two in it to hold it in place.
    F1nut Posts: 51,756
    edited August 2012
    StuartB wrote: »
    That's what I'm saying.
    Sonic Barrier is designed to dampen sound waves inside an enclosure. Dynamat Extreme is designed to dampen sound waves/vibration from getting into an enclosure. In this case, where we're trying to dampen the ringing of the stamped steel baskets, Dynamat Extreme is the appropriate product for the job at hand.
  • TennMan
    edited August 2012
    Thanks for the advice. I appreciate it.
