Dedicated outlets wiring
  • gdb
    gdb Posts: 6,012
    edited January 2010
    May be a dumb question but, why is your panel outdoors, and why so few spaces for such heavy amperage?? You might want to see if the electrician that does your "heavy-up" can run new SEC and mount the new Cutler Hammer panel inside the house. Re-setting a tripped breaker in a Fla. rainstorm is not something I'd be interested in doing!:eek:
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited January 2010
    If the electrical panel box is bigger, the grey box will be removed I don't use it. The panel can be moved to the right an electrical pipe which goes to my pool sub can be moved a little. So if needed the main panel can be moved to the right, that would be easier.
    In Florida I see a lot of electric main panel outside, it as a main break. The sub panel is usually in the garage.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited January 2010
    you seem to moving further to the right.......keep going, when you get to the garage look around for a, oh, ribbon project.........................
    RT1
  • bikerboy
    bikerboy Posts: 1,235
    edited January 2010
    Looks like a job for highly paid professionals! Get the biggest panel that in only your wildest dreams could be filled. Make it the last time you will even have to think about doubling up circuits. I ran 2 dedicated lines to the mancave and wish I had 3. PS Audio quintet, power amp, and a seperate digital line would have been nice. I can use the switched line to the lights in the area but a computer and other stuff are on it now. Its cheap to run more lines than you think you will need, its only the cost of the wire. Big pain in the @ss to do it later.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • disneyjoe7
    edited January 2010
    Anyone have an idea what this could cost?
    Pull permit and replace main panel with 20/40 GE panel, all new breakers. Whole house surge protection, and 3 dedicated 20amp receptacles in the family room.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • louhamilton
    louhamilton Posts: 209
    edited January 2010
    disneyjoe7 wrote: »
    Depends on which whole house surge you do. I've seen $500 dollar ones, but I've also seen ones that get upwards of $10K.
    For a decent setup, I would budget between $3-4K to be safe.
  • disneyjoe7
    edited January 2010
    Well I think the surge protection will work ok, but this is be no means the last device protecting electronics.
    http://www.intermatic.com/products/surge%20suppression/residential%20hardwired/ig1240%20and%20ig3240.aspx
    It's the IG1240 which I believe it's around $120.00 for the part.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
