Canare 4S11 Blue Jeans Speaker Cable
  • Murray1
    Murray1 Posts: 193
    edited January 2010
    Think I will call Polk technical and get their thoughts regarding bi-wiring.
  • Face
    Face Posts: 14,340
    edited January 2010
    William is correct.
    Mr. Blue, go back to electronics 101.
  • Murray1
    Murray1 Posts: 193
    edited January 2010
    WilliamM2 wrote: »
    Instead of coupling them with the jumper, you are coupling them together at the amp's binding post. The cicuit has not been changed at all, the load is the same. Think about it.
    If I understand correctly, bi-wiring is the same as a jumper cable between speaker binding posts.
    edited January 2010
    Murray1 wrote: »
    Considering purchasing raw cable and doing the terminations myself. I am choosing this cable because my new RTiA5's and CSiA6 are bi-wired speakers. I will be connecting speakers to HK 3600 AVR. Blue Jeans website states canare 4s11 is 14 gauge. Will this gauge wire fit into my speaker binding posts. If not, I am thinking spades for speakers and possibly bananas for receiver. Has anyone already gone thru the process using the same speakers. If so, any suggestions would be greatly appreciated. Seems like bi wiring is questionable on other threads. I asked Joe Abrahms who sells MIT cables and he recommended bi wire cables since my Polks are bi wired speakers. Are there any special setting I need to make on my receiver for bi wiring speakers. Do I remove jumper plates on speakers if I bi wire. Any help appreciated. Thanks
    Too bad speaker wire threads need to go off on tangents all over the place.
    Joe Abrams is a good guy and you would do well to listen to him. In regards to your post,yes,when bi-wiring, remove the brass jumpers that came with the speakers. No special settings needed in the receiver. Only use the brass jumpers when using single runs of regular cable.As far as the benefit goes,thats debatable,but for my ears,I can hear the difference.
  • CoolJazz
    CoolJazz Posts: 572
    edited January 2010
    WilliamM2 wrote: »
    Don't know why some would say that. The amp is still sending the full range on both wires when bi-wiring.
    Sending, yes. But on the high side, the crossover is going to be very high impedance to the lows and current flow is going to be far less!
    As a very rough rule of thumb and for the sake of explanation, you could consider the power required for a 2-way speaker split at 3K to be about a 10 to 1 power split requirement. When you say it's all the same presented to the amp, your looking at the wrong place. It matters what the drive to the speaker is! It's all about the source impedance of the amp.
    A perfect theoretical generator would have a source impedance of zero. Nothing about the load would matter. But our generator (amplifier) in this case is real world and has some source impedance. And that increases at the other end of the wire. That change is what we're interested in here.
    Yet again, the example of two identical extension cords and two loads. Plug both cords into the same wall outlet...the low source impedance point. Now compare at the far end of the cords what happens when you plug a heavy load (vacuum) and a light load (light bulb) on the other end of the same cord versus one on each cord. What you'll find is that when you seperate them, the application of the heavy load won't modulate the light load nearly as much when they are separated!! This is a good illustration of the same principle as bi-wiring!
    CoolJazz
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited January 2010
    CoolJazz wrote: »
    The crossover has not changed. All that has happened is that the signal has moved from the jumper to a piece of wire. The load on the amp has not changed. The load at the speaker end has not changed. No matter how you look at it.
  • CoolJazz
    CoolJazz Posts: 572
    edited January 2010
    WilliamM2 wrote: »
    F!!
    You now have to go back a grade! Try the extension cord load test and report back!
  • WilliamM2
    edited January 2010
    CoolJazz wrote: »
    F!!
    You should probably read a beginner's book in electronics before trying to discuss this further.
  • CoolJazz
    CoolJazz Posts: 572
    edited January 2010
    Common...do it! We need to try to get you out of grade school once and for all. :eek: Your startin' to scare the other kids! :( Not to mention you look awful funny all hunched over, crammed into that little tiny desk!
  • WilliamM2
    edited January 2010
    CoolJazz wrote: »
    The insults don't change the fact that you are completely wrong. Nice try though.
    When the jumper is in place, the high and low circuits are connected together. When the jumper is removed, and the leads are connected at the amp, the two circuits are connected together. I'm not sure why you can't see that, and that electrically it is unchanged.
    heiney9 Posts: 25,482
    edited January 2010
    CJ, WM2 will keep telling you you are wrong and he will never try anything for himself........he has a completely closed mind on the subject and apparently thinks he knows all when it comes to cabling/chords, etc.
    Ignore him
  • BlueFox
    BlueFox Posts: 15,250
    edited January 2010
    WilliamM2 wrote: »
    Although not directed to me, it is still good advice for the poster. :rolleyes:
    I might be misunderstanding this circuit, and if I am all it takes is a simple explanation as to why. Yet, so far you have not provided a specific piece of information to support your position. All you do is talk, and expect others to just accept what you say without any verification or validation. Unfortunately, your posts regarding speaker wire show you have little credibility, so you need to provide data.
    I provided the schematic for the LSi15 which clearly shows the LSi15 consists of two separate speaker circuits. The tweeter, and the upper/lower driver, woofer combination. When the jumper is installed between the “+” and “-“ posts these two circuits become one. When the jumper is removed they are two distinct circuits with no path for current flow between them. As mentioned earlier, with the jumpers removed, this is the same as if there are two separate, distinct, and unrelated speakers attached to the amp.
    Install the jumpers on the LSi15 and use a multi-meter to measure the DC resistance between both sets of the “+” and “-“ terminals. This value will be for all the circuitry of both speaker pairs, and will give the same value irrespective of which pair of terminals is used. Remove the jumpers from the LSi15, and measure the DC resistance between both sets of “+” and “-“ terminals. This will be two different values, because there are now two separate circuits (speakers).
    Whether an individual amp acts the same with two separate loads on its output versus a single load is unknown, but it certainly is not the same as moving the jumper from the speaker to the amp.
    It appears what you are trying to say, is if the jumpers are removed, both sets of speakers are attached via two pairs of wire to the same amp output terminals, and the multi-meter is placed on the amp output terminals, then the same value will be measured, as if there were only one set of wire, and the jumpers are installed on the speaker.
    Obviously, this is not true. At the very least the addition of the 2nd pair of speaker wires has now added additional resistance, capacitance, and inductance into each circuit. The amp is now seeing a different load with the two separate speakers than it sees with the single speaker. The electrical characteristics of the circuit are now changed.
    If the circuit is now different then it cannot be the same as if we just moved the jumper from the speaker to the amp.
    It might similar, but it is not the same.
    It might be close, but it is not the same.
    Consequently, there is the possibility that removing the jumper, and biwiring the speaker, a different audible output can result, and depending on the amp, it could be better or worse than the single wired version.
    Granted, we might be splitting hairs here, but in electrical engineering if something is changed and the circuit is different then it is not the same as before.
    I suspect it is these minor, nuance changes in electrical characteristics that are responsible for the different results heard when various speaker wires are used. Each wire has its own electrical characteristics, and combined with the amp and speaker, could produce a different circuit with different audible characteristics.
    Experiment time:
    Out of curiosity, I just did an experiment to verify what I said above. If what I am saying is true then it should be measurable. I have a pair of LSi7s that are idle so I measured the DC resistance with jumpers installed, jumpers removed, jumpers removed with 2 pair of 8 foot 12 gauge twisted copper wire attached to each terminal, and with the other +/- ends twisted together as it would be on an amp.
    Results:
    Jumpers installed: 4 ohms between each +/- terminals. 4 ohms measured at the end of an 8’ length of 12 gauge twisted copper wire.
    Jumpers removed: Infinite DC resistance between the top +/- terminals (there is a cap in series which blocks DC). 3.9 ohms on the lower +/- terminals
    Two pair of 8’ 12 gauge wire added, far end twisted together: 4.1 ohms measured between +/- terminals
    http://www.polkaudio.com/forums/attachment.php?attachmentid=18676&d=1155780535
    This seems to indicate that biwring a speaker is not the same as moving the jumper to the amp.
    It is sort of funny this discussion started because I corrected myself on an earlier statement I made. I said if the two pair of speaker wires are going to an unjumpered speaker they were like two resistors in parallel. This is wrong because for resistors to be in parallel the start point and the end point must be the same for each resistor. However, since an unjumpered speaker consists of 2 separate speakers then, obviously, while the start point is the same, the end point if different.
    If the jumpers are not removed, and two pair of speaker wires are used, then the wires are acting like two resistors in parallel, since the start and end points are now the same.
  • WilliamM2
    edited January 2010
    Face wrote: »
    William is correct.
    heiney9 wrote: »
    Ignore him
    It has nothing to do with opinions on wire, it's just an electrical connection. Ignoring facts sure won't change that.
    I would have thought you knew enough to understand, regardless of opinions on whether it changes the sound or not, all that is changed is where you couple the two circuits together.
  • Murray1
    Murray1 Posts: 193
    edited January 2010
    So.........getting back to my original post, what should I do????? Ha Ha!!!! I have decided to go ahead and use Canare 4S11 and bi-wire my speakers. I will bare wire them with no connectors. Non terminated cable is super cheap so what the heck. I might even put braiding on them if I want to get fancy. Now boys, let's all behave and agree to disagree on this one. Got a feeling everyone has already made up their minds. Have a great 2010 enjoying all your new toys. I know I will. Thanks again.
  • gp4jesus
    gp4jesus Posts: 2,019
    edited January 2010
    I agree w/face & kcoc321.
    About 6 months ago I read in another forum, replacing those jumpers* with a short piece of your favorite** speaker wire yields improvements***.
    * inferior materials to lamp cord
    ** tee-hee; as far as I'll go in this debate
    ***confirmed by several other in same
    I'll go along with the lower resistance argument for bi-wiring; potential for slight change in sound quality. Hope I didn't "stir the pot" much here.
    If your serious you'll upgrade the wire inside. If you're insane, like me, you'll bypass the internal XO & bi-amp! LOLLOL!
    *all connected w/Premiere ICs
  • gp4jesus
    edited January 2010
    Opps! forgot to mention Remember: connecting the wire directly to your BPs at either end has one (or two!) less connection(s) than bananas or spades
  • gp4jesus
    edited January 2010
    One more ooops! per the Polk manual, if you have enough channels you could run a separate length of wire* to each set of BPs from separate channels. I did this**, early-on with my CSiA6. Not quite the same as true bi-amping; will NOT produce the same results as an electronic XO handling filtering duties.
    * your favorite of course!
    ** I have the channels so why not!
    On another note: cheers to Blue note for your efforts! To ignore his test results would be... well... ignorant!
  • jinjuku
    jinjuku Posts: 1,523
    edited January 2010
    BlueFox wrote: »
    Results:
    A question that I would like to ask an Amp designer: Are your measurements taken at the correct place? Would the parallel connections (meaning at least double the wire) be summed (series now) inside the amp?
    I think the amp in a bi-wire scenario is going to see almost the same load power supply side (ignoring the fact that double the cable is used).
    edited January 2010
    jinjuku wrote: »
    Head over to www.DIYAUDIO.COM there are many, many amp designers and ask your question. They will answer it in more detail than you can probably understand.
  • jinjuku
    edited January 2010
    heiney9 wrote: »
    You are an **** as always. Too bad you suck at left handed comments. Now I know why you named yourself 'heiney'.
    The cool thing about DIYAUDIO? Even Nelson Pass posts there:)
    To the OP try bi-wiring your setup. Bi-amping if you can is where you want to be at if you can.
    In pro-audio (which I did for 7 years, but alas there is more $$ in software dev) we always multi-amped setups with active crossovers. In home audio if you can run speakers on truly separate amp circuits you are negating the problems of EMF being introduced to other transducers in the x-over circuit.
    Arguably bi-wiring is of minimal improvement:
    1. You are effectively doubling the wire gauge. But 12 gauge is plenty for short speaker runs.
    2. You are at least attempting to isolate tweeter or tweeter/mid from the woofer section by X number of feet. So you have some isolation just by the simple length of wire. Whether that is enough to make a difference, well if you look at other boards the general consensus is that it doesn't. But YMMV. Give it a shot and use your ears.
    If bi-wiring on the same amp section, your amp is most likely going to see the same load.
    edited January 2010
    jinjuku wrote: »
    Sorry you took my comment negatively..........it wasn't meant to be. And yes I've corresponded with Nelson before. I was serious as a heart attack about going over there to get knowledgeable answers to technical questions. On the whole more detailed and experienced answers than you will get here about electronic theory.
  • jinjuku
    edited January 2010
    heiney9 wrote: »
    I'm sorry that I had to take it that way. To bad the HK AVR3600 doesn't allow for bi-amp.
