I -Touch
anhchungdoan
anhchungdoan Posts: 760
edited May 2011 in Electronics
I'd like to learn a few things abt the Apple I-Touch.
1. I have a spare Pioneer A 35 R intergrated and apair of Def Tef SM 50, what's else to I need to get to hook up the I-touch to my Pio intergrated.
2. I currently use the high-speed DSL with AT @T, what's else do I need to listen to Internet radio ?
Thank you.
Post edited by anhchungdoan on
  • nguyendot
    nguyendot Posts: 3,594
    edited December 2009
    You need a 1/8" mini plug to RCA adapter.
    Internet radio you can use many thing. The first thing that comes to mind is a computer.
    A lot of people use a squeezebox as well.
    Main Surround -
  • anhchungdoan
    nguyendot wrote: »
    I found this:
  • nguyendot
    What is that? Picture is very small so it is hard to make out.
    Main Surround -
  • anhchungdoan
    nguyendot wrote: »
    I guess it is a usb port input from Ipod, Mp3...coverting to regular RCA output jack @ music direct for $99.00.
    A mini adaptor as you said is much cheaper way to go. Thanks.
  • nguyendot
    You can also get adapters from the ipod port (bottom) to RCA as well. Not sure if this will give you better quality or not.
    Main Surround -
  • anhchungdoan
    It'a D&A conveter . maybe this px is better.
  • concealer404
    concealer404 Posts: 7,440
    Yeah... cheaper, and won't sound as good.
    What you showed is actually a halfway decent DAC.
  • anhchungdoan
    Options, please. Does Benchmark DACs worth the $$$$?
  • concealer404
    I would imagine so... but i don't have a ton of experience with DACs. Only that most will sound better than what's in the IPOD to start. Sorry. :(
  • anhchungdoan
    Thank you though. For the Internet Radio, I may just find some cheaper DAC since this is not a critical listenning but more like background music.
  • BlueFox
    BlueFox Posts: 15,250
    You need 4 things to get excellent sounding music from the iTouch.
    1. Lossless files, or lossless compression.
    2. Wadia iTransport to extract the digital file off the iTouch.
    http://www.wadia.com/products/transports/170i/
    3. A great DAC. The Benchmark is fine, and was my first. I later upgraded to the Bryston which is better, and hope to move up to the Berkeley Audio at some point.
    http://bryston.com/bda1_m.html
    http://www.berkeleyaudiodesign.com/
    4. A good digital interconnect
    Of course, at this point the rest of your system is now inferior, so you need new electronics and speakers. :rolleyes:
  • anhchungdoan
    BlueFox wrote: »
    Yes, it's the irony of upgrading from one component to the rest of the system.
    I am looking at the MF intergrated with USB for simplicity.
  • anhchungdoan
    Sorry, I meant the Bel Canto intergrated with USB. :D
  • Destiny Brown
    Destiny Brown Posts: 1
    edited May 2011
    I think Bluefox information is the best solution. Even I also follow the same and would prefer that in future too.
  • Outfitter03
    Outfitter03 Posts: 563
    edited May 2011
