I -Touch
anhchungdoan
I'd like to learn a few things abt the Apple I-Touch.
1. I have a spare Pioneer A 35 R intergrated and apair of Def Tef SM 50, what's else to I need to get to hook up the I-touch to my Pio intergrated.
2. I currently use the high-speed DSL with AT @T, what's else do I need to listen to Internet radio ?
Thank you.
Thank you.
Post edited by anhchungdoan on
You need a 1/8" mini plug to RCA adapter.
Internet radio you can use many thing. The first thing that comes to mind is a computer.
A lot of people use a squeezebox as well.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
I found this: -
What is that? Picture is very small so it is hard to make out.Main Surround -
I guess it is a usb port input from Ipod, Mp3...coverting to regular RCA output jack @ music direct for $99.00.
A mini adaptor as you said is much cheaper way to go. Thanks. -
You can also get adapters from the ipod port (bottom) to RCA as well. Not sure if this will give you better quality or not.Main Surround -
anhchungdoan wrote: »I guess it is a usb port input from Ipod, Mp3...coverting to regular RCA output jack @ music direct for $99.00.
Yeah... cheaper, and won't sound as good.
What you showed is actually a halfway decent DAC.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »Yeah... cheaper, and won't sound as good.
Options, please. Does Benchmark DACs worth the $$$$? -
anhchungdoan wrote: »Options, please. Does Benchmark DACs worth the $$$$?
I would imagine so... but i don't have a ton of experience with DACs. Only that most will sound better than what's in the IPOD to start. Sorry.
Thank you though. For the Internet Radio, I may just find some cheaper DAC since this is not a critical listenning but more like background music.
You need 4 things to get excellent sounding music from the iTouch.
1. Lossless files, or lossless compression.
2. Wadia iTransport to extract the digital file off the iTouch.
http://www.wadia.com/products/transports/170i/
3. A great DAC. The Benchmark is fine, and was my first. I later upgraded to the Bryston which is better, and hope to move up to the Berkeley Audio at some point.
http://bryston.com/bda1_m.html
http://www.berkeleyaudiodesign.com/
4. A good digital interconnect
Of course, at this point the rest of your system is now inferior, so you need new electronics and speakers. :rolleyes:Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Yes, it's the irony of upgrading from one component to the rest of the system.
I am looking at the MF intergrated with USB for simplicity. -
anhchungdoan wrote: »Yes, it's the irony of upgrading from one component to the rest of the system.
Sorry, I meant the Bel Canto intergrated with USB.
I think Bluefox information is the best solution. Even I also follow the same and would prefer that in future too.
Spam reported
