I -Touch
anhchungdoan
I'd like to learn a few things abt the Apple I-Touch.
1. I have a spare Pioneer A 35 R intergrated and apair of Def Tef SM 50, what's else to I need to get to hook up the I-touch to my Pio intergrated.
2. I currently use the high-speed DSL with AT @T, what's else do I need to listen to Internet radio ?
Thank you.
Thank you.
Post edited by anhchungdoan on
You need a 1/8" mini plug to RCA adapter.
Internet radio you can use many thing. The first thing that comes to mind is a computer.
A lot of people use a squeezebox as well.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
I found this: -
What is that? Picture is very small so it is hard to make out.Main Surround -
I guess it is a usb port input from Ipod, Mp3...coverting to regular RCA output jack @ music direct for $99.00.
A mini adaptor as you said is much cheaper way to go. Thanks. -
You can also get adapters from the ipod port (bottom) to RCA as well. Not sure if this will give you better quality or not.Main Surround -
anhchungdoan wrote: »I guess it is a usb port input from Ipod, Mp3...coverting to regular RCA output jack @ music direct for $99.00.
Yeah... cheaper, and won't sound as good.
What you showed is actually a halfway decent DAC.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »Yeah... cheaper, and won't sound as good.
Options, please. Does Benchmark DACs worth the $$$$? -
anhchungdoan wrote: »Options, please. Does Benchmark DACs worth the $$$$?
I would imagine so... but i don't have a ton of experience with DACs. Only that most will sound better than what's in the IPOD to start. Sorry.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Thank you though. For the Internet Radio, I may just find some cheaper DAC since this is not a critical listenning but more like background music.
You need 4 things to get excellent sounding music from the iTouch.
1. Lossless files, or lossless compression.
2. Wadia iTransport to extract the digital file off the iTouch.
http://www.wadia.com/products/transports/170i/
3. A great DAC. The Benchmark is fine, and was my first. I later upgraded to the Bryston which is better, and hope to move up to the Berkeley Audio at some point.
http://bryston.com/bda1_m.html
http://www.berkeleyaudiodesign.com/
4. A good digital interconnect
Of course, at this point the rest of your system is now inferior, so you need new electronics and speakers. :rolleyes:Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Yes, it's the irony of upgrading from one component to the rest of the system.
I am looking at the MF intergrated with USB for simplicity. -
anhchungdoan wrote: »Yes, it's the irony of upgrading from one component to the rest of the system.
Sorry, I meant the Bel Canto intergrated with USB. -
I think Bluefox information is the best solution. Even I also follow the same and would prefer that in future too.
Spam reported
