Turntable mat questions
Montoya
I currently am running a music hall mmf-5 with the stock felt mat I feel this mat is transfering particles onto my records. Any suggestions on a better mat?
Post edited by Montoya on
I have a Herbie's turntable mat and enjoy it very much. Look HereCarl
Montoya, if you do upgrade the mat can I purchase/get yours please?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I gots to get me one.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Herbie's mat is great, I've got one as well.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
You can have it I won't be getting the mat till mid January but consider it yours.Montoya, if you do upgrade the mat can I purchase/get yours please?
I have the Herbie's mat on my MMF 5.1, works great! Everything I've tried from Herbie's works great. The Herbie's brass/vibration dampening material pucks underneath your feet on your TT will do wonders.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
I personally have the Extreme Phono Speed Mat on my MMF-7 and have been very pleased with it. Snagged it a few years back while @ Music Direct in Chicago. Was fortunate enough to have a knowledgeable sales person talk me out of the far more expensive ringmat.HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
Tom, why would you want that mat? It is less than desirable for coupling a record to the platter. -
I used to have a mmf 5 which I later exchanged for the 5.1 The stock mats aren't bad. Dust will settle on the surface no matter what type of mat you use.
I found that using a Swiffer cloth before play and before storing back in the sleeves work great at removing large and very fine particles. It worked better for me than the record brush which I think can shove very fine particles deep into the groove. With the cloth you don't really add pressure, you just let the static attract the dust. Life is tougher without a cleaning machine lol. -
...because it's gentle on the other side of the LP and I'd like a spare.hearingimpared wrote: »Tom, why would you want that mat? It is less than desirable for coupling a record to the platter.
I'm working on other aspects of my rig at the moment. I'll get to the mat when the time comes. It sounds great as it is.....well, was. The TT is down right now because I chipped the glass platter trying to repair the tonearm. DOH!~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
After some research I'm going to go with the acrylic platter upgrade and not use a mat. That stock supplied mat causes a crapload of static electricity.
That is the way I use my VPI and my records make intimate contact with the delrin platter for maximum damping and record stabilization. -
hearingimpared wrote: »That is the way I use my VPI and my records make intimate contact with the delrin platter for maximum damping and record stabilization.
I clamp my records directly to the platter, never really thought about a mat. I wonder if I should try one? What is the purpose?Vinyl, the final frontier...
I'm a platter clamper too,,no mat,,VPI scout.JC approves....he told me so. (F-1 nut)
I would think for platters that aren't acrylic or delrin a good mat would be a plus. Also would probably be good on the lower end tables that use metal platters. Coupling a record to a glass platter can damage the record grooves so there is another application that would benefit from a good mat.
I know Rich (SCompRacer) uses a carbon fiber mat and loves it but I'm pretty sure his platter is made of MDF or a non-cousin of vinyl. -
I'm another happy Herbies mat user. I use a clamp with mine. I get less background noise while using the clamp.
Hi Joe! The platter is 20 pounds of alloy and the Mat 1 is carbon graphite.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote: »Hi Joe! The platter is 20 pounds of alloy and the Mat 1 is carbon graphite.
I was close but no cigar.:D
