Turntable mat questions
Montoya
Montoya Posts: 506
edited December 2009 in 2 Channel Audio
I currently am running a music hall mmf-5 with the stock felt mat I feel this mat is transfering particles onto my records. Any suggestions on a better mat?
Post edited by Montoya on
  • schwarcw
    schwarcw Posts: 7,358
    I have a Herbie's turntable mat and enjoy it very much. Look Here
    Carl
    treitz3 Posts: 20,121
    Montoya, if you do upgrade the mat can I purchase/get yours please?
  • ben62670
    ben62670 Posts: 15,969
    schwarcw wrote: »
    I gots to get me one.
    Ben
  • Fongolio
    Fongolio Posts: 3,516
    Herbie's mat is great, I've got one as well.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • Montoya
    Montoya Posts: 506
    You can have it I won't be getting the mat till mid January but consider it yours.
    treitz3 wrote: »
  • dkg999
    dkg999 Posts: 5,647
    I have the Herbie's mat on my MMF 5.1, works great! Everything I've tried from Herbie's works great. The Herbie's brass/vibration dampening material pucks underneath your feet on your TT will do wonders.
    DKG999
  • cmy330go
    cmy330go Posts: 2,341
    I personally have the Extreme Phono Speed Mat on my MMF-7 and have been very pleased with it. Snagged it a few years back while @ Music Direct in Chicago. Was fortunate enough to have a knowledgeable sales person talk me out of the far more expensive ringmat.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • hearingimpared
    hearingimpared Posts: 21,136
    treitz3 wrote: »
    Tom, why would you want that mat? It is less than desirable for coupling a record to the platter.
  • organ
    organ Posts: 4,969
    I used to have a mmf 5 which I later exchanged for the 5.1 The stock mats aren't bad. Dust will settle on the surface no matter what type of mat you use.
    I found that using a Swiffer cloth before play and before storing back in the sleeves work great at removing large and very fine particles. It worked better for me than the record brush which I think can shove very fine particles deep into the groove. With the cloth you don't really add pressure, you just let the static attract the dust. Life is tougher without a cleaning machine lol.
    ...because it's gentle on the other side of the LP and I'd like a spare.
    I'm working on other aspects of my rig at the moment. I'll get to the mat when the time comes. It sounds great as it is.....well, was. The TT is down right now because I chipped the glass platter trying to repair the tonearm. DOH!
  • Montoya
    Montoya Posts: 506
    After some research I'm going to go with the acrylic platter upgrade and not use a mat. That stock supplied mat causes a crapload of static electricity.
  • hearingimpared
    Montoya wrote: »
    That is the way I use my VPI and my records make intimate contact with the delrin platter for maximum damping and record stabilization.
  • madmax
    madmax Posts: 12,434
    I clamp my records directly to the platter, never really thought about a mat. I wonder if I should try one? What is the purpose?
    Vinyl, the final frontier...
  • george daniel
    george daniel Posts: 12,096
    I'm a platter clamper too,,no mat,,VPI scout.
  • hearingimpared
    madmax wrote: »
    I would think for platters that aren't acrylic or delrin a good mat would be a plus. Also would probably be good on the lower end tables that use metal platters. Coupling a record to a glass platter can damage the record grooves so there is another application that would benefit from a good mat.
    I know Rich (SCompRacer) uses a carbon fiber mat and loves it but I'm pretty sure his platter is made of MDF or a non-cousin of vinyl.
  • Dawgfish
    Dawgfish Posts: 2,554
    I'm another happy Herbies mat user. I use a clamp with mine. I get less background noise while using the clamp.
    SCompRacer Posts: 9,123
    Hi Joe! The platter is 20 pounds of alloy and the Mat 1 is carbon graphite.
  • hearingimpared
    SCompRacer wrote: »
    I was close but no cigar.:D
