The Good vs. Bad cable debate rages on...
12346»
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited November 2009
    Really, you run a LSI15 in each corner?
    I hope that is for movies only not music.:eek:
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • BlueFox
    BlueFox Posts: 15,250
    Not to get into this BS 'discussion' but DSOTM SACD sounds fantastic from 4 LSi15s. Other classical SACDs also sound great in multi-channel.
  • megasat16
    megasat16 Posts: 3,521
    BlueFox wrote: »
    That's coz DSOTM SACD is encoded in 5.1. It's fantastic for me too. But playing stereo tracks over 5 channel or 7 channel stereo is not the same thing.
    Depending on the track and recording, I found some stereo tracks play well in 5 or 7 channel stereo mode too.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • messiah
    messiah Posts: 1,790
    Thank God Vader is back, missed you Bro. Get this figured out you will!! ;)
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • messiah
    xcapri79 wrote: »
    Using basic acoustics is part of system synergy. Synergy is about using each component in an optimal manner to maximize the end result.
    A hockey analogy is using the side boards to bounce a puck off to get around an opponent.
    Dude, wrong. You have absolutely no idea what synergy is. Synergy is not how well each piece performs alone, it's how well all of the parts perform TOGETHER.
    On a separate note, please don't use "hockey analogies" anymore. Not only is this not an analogy, but I am an ex player, and huge fan, and you are making us look stupid. Not cool.
  • quadzilla
    quadzilla Posts: 1,543
    So I'll just weigh in to say (not that I actually believe that anyone much cares what I think) that cables are a lot more than just "wire". Even wire is a lot more than just "wire". For example, Ohno single cast copper crystal wire does not have exactly the same electrical properties as OFC, or just regular copper, all of which will have different properties when compared to silver, aluminum, or any other conductor. And that's before we even get into dielectric properties, ways of twisting or braiding the conductors, fine stranded vs. single conductor, etc.
    So for those that can't hear any difference, I actually envy you a bit, because you can head down to home depot and pick up some .39/ft zip cord and be every bit as happy as I am with my 10.00/ft anti-cables, or the guy that bought some 55,000/pr Modena speaker cables by Allan Shane.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
