Still Need Help
Davidb0123
Have Sony Sub SA-WX700
Understand there is a known problem with this model. R830 & C860 burns out on Power Amp board. Located R830 but can not find C860. What is the white glue like substance all over the components. i think this substance might be covering C860
Post edited by Davidb0123 on
C860 being a capacitor? If so, that thing is done for and has leaked over itself.
I'd personally buy a new sub, btw welcome to CP!
-FreddyTruck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
-Freddy
Fred
this White Glue like substance was from factory. Almost like they put it on components to keep them from vibrating -
It could be for helping with heat dissipation like on a motherboard for cpu's. When you mention that and that it keeps blowing out I want to say it is a mosfet. If that is the case make sure to replace them all. I second getting a new sub.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Davidb0123 wrote: »Fred
Is it a glue? I know I've seen that around power transformers and the sort, but that's me assuming that it looks like some type of hot glue.
At first I thought it was the type of battery acid looking stuff that you get from batteries when leaving them inside an object too long.
Honestly though, ready for a new subwoofer?
Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
i am thinking of doing just that. Only thing that rubs the wrong way is I only used this sub a little while & packed it up for two yeras while building a new house. i ourchased new TC80i's for in ceiling but would have liked to get a few years out of the Sony Sub
R830 with same resistance but higher wattage & C860 with the same capacitance but a higher voltage. If it is polarized or bipolar make sure you replace with the same type. Just be prepared for some thing to blow farther down the circuit path. You never know, if one part fails what does it say about the rest of the components. Or it could be totally fine after that.
