Still Need Help
Davidb0123
Davidb0123 Posts: 11
edited November 2009 in Speakers
Have Sony Sub SA-WX700
Understand there is a known problem with this model. R830 & C860 burns out on Power Amp board. Located R830 but can not find C860. What is the white glue like substance all over the components. i think this substance might be covering C860
Post edited by Davidb0123 on
  • kawizx9r
    kawizx9r Posts: 5,150
    C860 being a capacitor? If so, that thing is done for and has leaked over itself.
    I'd personally buy a new sub, btw welcome to CP!
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Davidb0123
    kawizx9r wrote: »
    -Freddy
    Fred
    this White Glue like substance was from factory. Almost like they put it on components to keep them from vibrating
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    It could be for helping with heat dissipation like on a motherboard for cpu's. When you mention that and that it keeps blowing out I want to say it is a mosfet. If that is the case make sure to replace them all. I second getting a new sub.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • kawizx9r
    Davidb0123 wrote: »
    Fred
    Is it a glue? I know I've seen that around power transformers and the sort, but that's me assuming that it looks like some type of hot glue.
    At first I thought it was the type of battery acid looking stuff that you get from batteries when leaving them inside an object too long.
    Honestly though, ready for a new subwoofer? :)
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Davidb0123
    i am thinking of doing just that. Only thing that rubs the wrong way is I only used this sub a little while & packed it up for two yeras while building a new house. i ourchased new TC80i's for in ceiling but would have liked to get a few years out of the Sony Sub
  • dudeinaroom
    dudeinaroom Posts: 3,609
    R830 with same resistance but higher wattage & C860 with the same capacitance but a higher voltage. If it is polarized or bipolar make sure you replace with the same type. Just be prepared for some thing to blow farther down the circuit path. You never know, if one part fails what does it say about the rest of the components. Or it could be totally fine after that.
