How to stop sub from moving on the floor?
DMara
DMara Posts: 1,434
I have just purchased a DSW microPRO 4000 for my living room. Geez, amazing bass! However, it shook and moved little by little on the wood floor. What should I use to make it stop moving? :D
Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000
Post edited by DMara on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited November 2009
    Add some weight to the top of it to hold it down.
    Sounds like a good idea..
    Couldn't you also just get some rubber padding...what do they call that substance which is used to absorb the thump subs send to rooms below them...I can't recall at the moment..but you guys know what I mean.....help me out here..I'm drawing a blank..
    cnh
  • maandjojo
    maandjojo Posts: 293
    Have your wife sit on it, this will make her feel part of your home theatre. If you have no wife it would give you a good reason to go out and find one.
    Joe
    Joe
  • louhamilton
    louhamilton Posts: 209
    Try an Auralex SubDude or any of their other products.
    If you have skillz, you can always build your own DIY sub riser. It can help tighten your bass as well as isolate it from your floor. I have my SVS sub on a temporary 6" sub riser and am quite pleased with the results.
  • kawizx9r
    kawizx9r Posts: 5,150
    maandjojo wrote: »
    have your wife sit on it, this will make her feel part of your home theatre. If you have no wife it would give you a good reason to go out and find one.
    Joe
    lmao!
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
    Thanks Lou...
    That's the stuff...works fine...and an easy fix...
    cnh
  • TNRabbit
    TNRabbit Posts: 2,168
    Duct Tape.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • MrGlobe
    MrGlobe Posts: 401
  • DMara
    DMara Posts: 1,434
    Thanks so much for quick responses from leroyjr1, Lasareath, maandjojo, louhamilton, TNRabbit, and MrGlobe :) I went ahead and followed louhamilton's suggestion of the Auralex Subdude foam. The wife would not allow me to drill the floor/baseboards, I could not think of anything I got to put on top of the sub while preserving the good look of the environment, and I did not have the nerve to share maandjojo's suggestion to her :D, therefore I actually bought the HD version of the Auralex Subdude riser to match the sub's color. It's $59.97 w/ FS on eBay.
    Once again, I really appreciate your advice :)
    Living room:
    Bedroom:
    Other rooms:
  • MrGlobe
    MrGlobe Posts: 401
    I had that same problem with a very low power Boston Accoustics sub. It just wouldn't stay put on my hardwood floors, and actually moved enough to knock the surge protector out of the socket and shut urrything down
  • TouchOfEvil
    TouchOfEvil Posts: 967
    I gotta do something about mine, it walks all over the place.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • DMara
    DMara Posts: 1,434
    The wife or the sub? :D
    Living room:
    Bedroom:
    Other rooms:
  • rtart
    rtart Posts: 848
    Turn down the volume??
    My 7.4.4 DIY 4k Home Theater:
    Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
    Polk LSiM 702s x 4 on the Ceiling Atmos speakers
    Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
    2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
    Denon X3700H Emotiva XPA11 Gen 3
    XBox One X 4k & BD and streaming
    Panasonic UB-420 4k player
    HD-A35 HD DVD
    Oppo BD-103D for hirez audio
    Technics SL-D2 TT, Grado Gold Cartridge
    JVC DLA-RS2100/NZ7 projector
    Silver Ticket 135" microperf AT screen
    Berkline 090 electric recliners with Aura Bass Shakers
  • Squishy Tia
    Squishy Tia Posts: 79
    The walking all over the place has to do with the bass radiator and the fact that it can hit the floor at louder volumes (or during a super heavy bass hit/rumble). It can walk across heavily carpeted floors in addition to wood floors. I'd not advise putting the MP4K on top of something that isn't level with the ground, lest it move itself off the SubDude and come crashing to the floor (or tilt enough to damage the bass radiator - remember, the sub isn't exactly light).
  • DMara
    DMara Posts: 1,434
    Auralex SubDude HD arrived :D Sharing some pics:
    1. Living room front sets: Polk Audio LSi9's - Polk Audio LSiC - Polk Audio DSW microPro 4000 (The DSW microPro 4000 sub is sitting on an Auralex SubDude HD to stop its wandering while performing :D)
    http://farm3.static.flickr.com/2612/4134388186_938a992727_o.jpg
    2. Living room corner: surround speakers are Polk Audio LSiFX's (too limited space for them :()
    http://farm3.static.flickr.com/2574/4134388416_3efa46f97c_o.jpg
    3. Bedroom - while awaiting the arrival of new furniture: Zone 2: Polk Audio LSi9's - Polk Audio DSW microPro 1000 (the DSW microPro 1000 sub is sitting on an old laptop --- this little sub can also walk the walk :D)
    http://farm3.static.flickr.com/2611/4134388688_2106b53a2f_o.jpg
    4. Shared components for both living room and bedroom: Denon AVR 2808ci - Oppo BDP83 - DirecTV HR23 - old Yamaha LaserDisc/Karaoke player - Emotiva XPA5 (this amp is for driving the living room's 5 speakers)
    http://farm3.static.flickr.com/2651/4133627327_430aa2a7d1_o.jpg
    To celebrate my remodeled living room, I popped in the Andrea Bocelli's Vivere live in Tuscany bluray disc: the sound is DIVINE icon14.gif
    Living room:
    Bedroom:
    Other rooms:
  • DMara
    DMara Posts: 1,434
    DMara wrote: »
    Clarification: Living room front speakers are LSi15's :D. The center speakers is sitting on some binders while awaiting the arrival of its new stand :D
    Living room:
    Bedroom:
    Other rooms:
  • dorokusai
    dorokusai Posts: 25,576
    Dmara - LOVE IT! Thanks for posting pics :D
  • opus
    opus Posts: 1,252
    Damn, Dmara nice setup.
    The Flea rig
    Hitachi 50VG825 LCD
    Rotel RSP 1066 (pre) :)-flea market
    B&K St-202 (mains)-flea market
    Carver M 200t (x2) (center and surrounds)-flea market
    Blu-Ray..PS3 (dvd player)
    Polk RTA-11t-flea market
    LsiC, Fxi30's
    Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
    Behringer Feedback Destroyer
    -flea market
    AudioAlchemy DDE v1.0 DAC-flea market
    Cambridge Audio Azur 640 CDP-flea market
    Signal Cable and Kimber Kable
  • 20hz
    20hz Posts: 636
    I am kinda against insulating your sub from the floor , (eats bass)
    but what about that thin rubber stuff they sell on rolls , its used under carpets so they dont slide , 3m and contact paper sell it in rolls I have seen it at hardware stores and even in supermarkets to go in drawers to stop stuff from sliding .
    It may sound silly but I try and use a cheap fix befofe I go out and buy a subdude (isolator pad) $50 ebay .
  • kawizx9r
    20hz wrote: »
    You can build your own type of 'subdude' with some mdf and other parts for on the cheap. I'm thinking about making one myself with the extra mdf I've got laying around and 3M adhesive spray.
    My cheap fix on my hardwood floors was a piece of carpet cut out to size.
    Oh and regarding the "eats bass"...it just kills some of the "boominess" (artificial bass) and lets you hear the true accurate bass the micropro can produce.
    Btw, nice clean setup DMara!
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • leroyjr1
    Nice setup you got there.
  • danz1906
    danz1906 Posts: 5,144
    DMara wrote: »
    Welcome to the Club!
    Very nice system,great looking room!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    My Velodyne came with some rubber "nubs" that you just peel n' stick to the bottm, never had the sub walk on me in 4 - 5 month's of use :o Maybe you could try and find some? :confused:
    Does raising the sub off the floor really make a difference?
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • mantis
    mantis Posts: 17,388
    Big Rubber speaker feet is what I use on my walking subs. Works every single time. We have many powerful Subs and they love to walk around. So this is the best thing I have found. Any good quality rubber will stop a sub from wondering.
    Dan
  • DMara
    DMara Posts: 1,434
    danz1906 wrote: »
    Thank you very much for everybody's compliments :) I and the wife worked our asses off for a month and a half remodeling the dining room - living room - master bedroom from A to Z: painting - laying wood floor - running baseboards and quarter rounds - setting up AV wires. We are proud that we could finish it ourselves without having to contract anybody :D. Now it's time to enjoy the holidays :D. I really love the Club! I have been learning a lot by reading incredible amount of knowledge here :)
    Living room:
    Bedroom:
    Other rooms:
  • pablo_rodz
    pablo_rodz Posts: 331
    edited December 2009
    Looks good DMara...
    I work in Katy, maybe one day we can meet. I'd love to hear that Emo......
    HT:
    Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
    Living Room:
    Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7
  • Cogito
    Cogito Posts: 122
    maandjojo wrote: »
    Joe
    I can't think of a single good reason to go out and find a wife, not even for anchoring down a big sub! :eek:
    Hearing is believing.
