Will this work? (Lsi9 Help)
  • PSOVLSK
    PSOVLSK Posts: 5,452
    edited November 2009
    I went from an Adcom 545 to a Carver tfm-45 powering my LSi 15's and I'm happy with the sound. I've since moved the tfm-45 to my 1C's and am now powering the 15's with a tfm-55. I have an Emotiva XPA-5 powering a pair of LSi 9's in my HT. While I've never done any A/B type comparison, I probably prefer the Carver's to the Emotiva.
  • Cpyder
    Cpyder Posts: 514
    Any complaints on the Carver? Or does it do the 15s the justice they deserve?
  • Bernal
    Bernal Posts: 991
    The best performance of "LSi9" is a "Sunfire":D.
    http://www.sunfire.com/brochures/SF401B_RevB_lores.pdf
  • McLoki
    McLoki Posts: 5,231
    Bernal wrote: »
    A more accurate quote is this:
    The best performance of "LSix" is given by whatever amp you own:D.
  • PSOVLSK
    I haven't had a lot of experience with external amplification, but the Carver sounds great to me. Although I'm still not completely satisfied with the bass, there was a definite improvement over the Adcom in the low end. I could be wrong, but I think a tfm-45 can be had for less than the tfm-55. If so, that's the way I'd lean between the two Carvers.
    I think others here haven't been too fond of the Carver/LSi pairing. Maybe they will chime in to give you another perspective.
  • vc69
    vc69 Posts: 2,500
    I have a TFM-35 paired with some LS90's. Not the same, or even very close, but it doesn't sound bad either. I have found my -35 sounds best at a certain volume. I believe mine could use a going through. Still, I paid 300 for it and it sounds acceptable. Good even. Just not good enough.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • POIDOG
    POIDOG Posts: 391
    vc69 wrote: »
    WTH, how's that fence on your *ss :eek: feel.
  • vc69
    vc69 Posts: 2,500
    POIDOG wrote: »
    Well I could have just said it sounds like *ss and been done with it. :p
    It's not acceptable to me. Some might find it quite adequate. I'm living with it.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • POIDOG
    POIDOG Posts: 391
    vc69 wrote: »
    Maybe, with a little luck, Ida will take care of it for you :cool:
