Will this work? (Lsi9 Help)
Cpyder
Cpyder Posts: 514
edited November 2009 in 2 Channel Audio
So I'm pushing a pair of Lsi9s with a Marantz SR5003 receiver. I know this is not an optimal setup with the Lsis being 4 ohms and the receiver being safe only to 6, I believe. I'm looking into an external amp but then I got a new idea. Instead of an amp, could I just get a powered sub and put the speaker setting on small? The lowest impedance is around the 50Hz region. Would excluding the lower frequencies save my receiver from blowing when I play movies blarringly loud?
http://www.soundstagemagazine.com/measurements/polkaudio_lsi9/
Post edited by Cpyder on
  • kawizx9r
    kawizx9r Posts: 5,150
    You're still playing the speakers off your receiver, adding a powered sub just fills in the low-end department but doesn't mean you can drive your LSi's to a higher volume.
    Personally, I'd still get an external amp. You do listen to music in 2-channel right? That amp will help you in every way for both HT and 2-channel listening.
    Just my .02
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • concealer404
    concealer404 Posts: 7,440
    Cpyder wrote: »
    It'll help, not sure how much.
    But your first step should be powering those LSi9s correctly rather than worry about a sub. :)
  • McLoki
    McLoki Posts: 5,231
    Your crossover setting is a slope, not a cliff. Even if you set the crossover at 100hz, it will still be getting 50hz signals, just at a lower volume level.
    I am sure it will help, but if you plan to listen at decent levels, an amp is really what you want to invest in. You can try it, but there is no way we can tell you if it will work or not. (and I am sure some movies will cause more problems than others - just depends on the volume and frequencies that are needed to be reproduced.)
    Good luck,
    Michael
    Just admitting you play movies loud should answer your own question. Get an amp first,then a sub. Resale value on blown gear is not too good these days.
  • Cpyder
    Cpyder Posts: 514
    Thank for the valuable input guys! For the amp, I was looking at an Emotiva UPA-2 or XPA-2. The price point looks good along with the rated wattage. I also love the appearance. :) Any other suggestions as far as 2 channel amps go would be great!
    Once again, Thanks a lot!
  • kawizx9r
    Cpyder wrote: »
    Whats your budget?
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Cpyder
    Cpyder Posts: 514
    I'd like to stay around half a grand. I know that doesn't give a whole lot to work with, but I've got other bills to pay :(
  • concealer404
    Cpyder wrote: »
    That'll give you PLENTY to work with to at least start out right. :)
    You open to used stuff? In that price, you're looking at big nasty Adcoms, Carvers, maybe Rotel, Hafler, etc etc etc...
    Tons of possibilities in that price range. I'll bow out from here, as my only experience with "high power" 2-channel amps come with the XPA-2, and i can only speak for how it sounded on my gear, which will probably be radically different from what you've got.
  • Cpyder
    Cpyder Posts: 514
    How do you like the XPA-2? And do you know if I can find one used anywhere?
  • concealer404
    Cpyder wrote: »
    I didn't like it. :p YMMV, of course. It didn't play nice with my gear. It was harsh, too forward for my tastes, and bright. Your ears are probably different, and your gear is probably MUCH different from mine. I won't say it's a bad product.
    I think there's a used one on Audiogon right now, but i think it's still going for almost $600.
    The 'Gon or Ebay is where they usually show up. Or try the Emotiva forums.
    If you REALLY want to try one, i'd get one direct from emotiva on the 30 day trial. You'd have to pay shipping back if you don't like it, which sucks, because it's built like a concrete block, but it's relatively risk free.
    heiney9 Posts: 25,487
    Cpyder wrote: »
    You've crapped on enough amp threads with your Emo love so you should know what other amp suggestions are out there.
    You have an obvious love for Emo gear because of the way you ravenously defend it at every turn in almost every amp thread, even if it's off topic. So I'd think that's what you should purchase. It's time to put your money where your mouth is!
    I think I just saw a XPA 2 on Audiogon, not sure if it's still available.
    http://www.audiogon.com/cgi-bin/cls.pl?ampstran&1261862407&/Emotiva-XPA-2-Amplifier
    I find this whole thread very humorous.......by way of you asking for amp suggestions when you've been vigorously waving an Emo flag at every chance. Get the Emo and be happy like you've said all along. :)
  • kawizx9r
    heiney9 wrote: »
    Or I can recommend getting a modified Moscode 300, the stock 300's will fit your wallet but a Stephen Sank modified one (if you can EVER find one) will take care of you for plenty of years to come but that'll run you a good grand +. It'll also have lots of room so you can put 100 bright-blue LEDs if you start having withdrawals....just to give you the impression that you have an EMO amp in your room, but the amount of current this thing provides will make you long forget that brand ever existed.
    You know that the 600 had enough current that it powered a blender? Fun fact for ya!
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Cpyder
    Cpyder Posts: 514
    heiney9 wrote: »
    Def: Thread crapping: Making off-topic posts in a thread on a message board.
    I'm the one thread crapping?
    My post isn't off topic I even posted a link to help you find an amp. Sorry if I call it like I see it. If it bothers you put me on ignore.
    Cheers
  • Cpyder
    Cpyder Posts: 514
    I appreciate the link but my idea of helpfulness is not shooting someone down and then offering a hand. I'm not sure what that's called.
    But as far as me defending Emotiva amps in "almost every" amp thread, "even if its off topic", I would love for you to back up this claim.
    Unless I post messages in my sleep, the only other thread I've even talked about Emotiva amps in was a thread discussion "best bang for the buck components" in which I stated a lot of people enjoy Emotiva products. For its power rating to price ratio, it is a pretty good bang for the buck product. Was that off topic? Was my own thread discussion what amp I want to purchase off topic too?
  • vc69
    vc69 Posts: 2,500
    I am so laughing my **** off right now.
    Cpyder, I think you post this crap for kicks. You certainly offer plenty of opinion about amplification and what is "good" on the forum. I think buying Emotiva is an awesome idea. Let us know what you think.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • concealer404
    Get the Emotiva!
    Try it, maybe you'll like it.
  • Cpyder
    Cpyder Posts: 514
    Heiney9 - How fast you run when someone calls you out on your crap. Do you just post to hear yourself talk? Here's another example of you just saying foolish BS:
    On 1-23-2006
    heiney9 wrote: »
    Fluance are those really crappy white van speakers. Stay as far away from those as possible. Absoulte $h*t. All the on-line reviews are bogus. I've heard cheap boom-box's that sound better.
    On 3-11-2009
    heiney9 wrote: »
    White Van speakers.........totally *crap*.
    On 3-12-2009
    heiney9 wrote: »
    Not really. I've known someone who got duped into buying some pieces and it's white van stuff. Granted I haven't heard it myself, but there are dozens of companies like this all over e-bay and it's really low quality stuff, CRAP
    Just to name a few others that are white van speakers the same as FLUANCE. It's junk!!!
    So in 2006, you heard Fluance speakers and they sounded like a cheap boom box, but then in 2009 you claim you've never heard the speakers. Hmmm... I guess I'll have to say I'm a little confused by the ability to un-hear something.
    Finding these ignorant words of yours took me less than 2 minutes. Imagine what other fictitious claims one might find if they searched through your clutter of misguided posts.
    Lol................you're a trip Cpyder. I see a straight jacket in your future. Now your crapping in your own thread.
    Keep digging the hole...........very entertaining, but the adults have to get back to work now.
  • concealer404
    Oh dear.
    So uhmmm... what amp do you think you're going to get?
  • kawizx9r
    Oh dear.
    Let's hope the folks at Volk Audio come out with an Elmo-tiva amp, with LOTS of blue LED's on the front panel :D
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Cpyder
    Cpyder Posts: 514
    Oh dear.
    Not quite sure. I'd like to audition a few, but there's a lack of home audio stores in the near vicinity.
    heiney9 wrote: »
    Haha!
  • McLoki
    McLoki Posts: 5,231
    So, were you staying with new then or are you willing to go used?
  • Cpyder
    Cpyder Posts: 514
    I'm willing to look at used assuming it hasn't been beaten up or left sitting for years.
    As far as pushing LSi9s, would something around 200W x 2 @ 4 ohms be ideal?
  • kawizx9r
    Used would get him alot for under a grand.
    New will get a little less, but with a warranty.
    Hmm....
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • kawizx9r
    Cpyder wrote: »
    That's subjective, don't look at power ratings alone. It's best to get your ears on such things with your own gear if and whenever possible imo.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Cpyder
    Cpyder Posts: 514
    kawizx9r wrote: »
    What are you using? What pleases your ears?
  • kawizx9r
    I'm using a Moscode 300 Hybrid amp thats partially modified. Its an extremely high-current amplifier and supports crazy 1 or 2ohm loads. It's meant more for electro-static/planar speakers since they're the hardest to drive, so LSi's would be a walk in the park.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Face
    Face Posts: 14,340
    FYI, LSi9's dip down to 2ohms, so your receiver is not doing them any justice. Setting them to small won't help either, since the dip is higher in the frequency spectrum.
  • Cpyder
    Cpyder Posts: 514
    Face wrote: »
    Yeah, that's why I'm thinking I need a separate amp sooner than later, right?
