Windows 7 upgrade info
  • Systems
    Systems Posts: 14,872
    edited October 2009
    Hello again...
    I got my free Win 7 upgrade disc today, thought that was pretty quick of them. Anyway, I got the "coupon" when I bought Vista 64.
    As you can see, it looks like its okay to do a clean install with the upgrade disc. I just had some questions for anyone thats done it this way...
    When you boot from the upgrade disc is there options in the menu to do a format and a clean install? Does it "see" a previous copy on the hard drive or does it ask for the Vista disc to verify? The copy of Vista 64 I have on the machine right now is an OEM version, not the full retail copy....
    Just getting my ducks in a row before I take off on it...
    Testing
    Testing
    Testing
  • Systems
    edited October 2009
    I'm back, well I went ahead and did the install. It acted just like a normal boot to the disc install. Everything is back up and running just fine. Will report back more after messing around with it a little more....
    Testing
    Testing
    Testing
  • Systems
    edited October 2009
    Well I found one bummer so far. You can't back up, using the Win 7 back up, to a network share, such as my NAS box....
    Heres the direct quote from the help and support file:
    You can only save your backups on a network location on Windows 7 Professional, Windows 7 Ultimate, and Windows 7 Enterprise.
    Not too happy about that....
    Testing
    Testing
    Testing
  • polkatese
    polkatese Posts: 6,767
    edited October 2009
    So I take it you have Windows 7 Home Premium 64 then?
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • Systems
    edited October 2009
    polkatese wrote: »
    Yes, I do....sorry should have mentioned that I guess:)
    Testing
    Testing
    Testing
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited October 2009
    Can someone help me out here.
    I own a previous version of Windows, Vista. However I want to do a clean install with the Windows 7 upgrade disc on a new hard drive on a system that does not have Vista installed.
    I assume that since this is an upgrade version, I'm going to have to prove somehow that I own the version of Vista that I have. The question is, how does this work if I don't have the OS installed? Can I plug in the license number from Vista, or do I actually have to install Vista then install Windows 7?
    I keep hearing that the upgrade dis doesn't require the previous operating system to be installed, but that can't be right or else it would just be the full retail disc...
  • vc69
    vc69 Posts: 2,500
    edited October 2009
    I have yet to do this in a Vista -->Win7 upgrade so... grain of salt.
    If you have the install media for "any" previous version, get that handy.
    Start the install and when it complains about not finding a previous version, point it to the install media for your previous version. That has always worked in the past. Not sure with win7 but it's worth a try.
    Sorry I can't be more certain.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • PhantomOG
    PhantomOG Posts: 2,409
    edited October 2009
    everything I've read says something along the lines of this:
    1. install from the upgrade disk, however, when you get to the prompt for your new Key, skip that step, and a trial-type install will occur with a time limit (30 days or something like that).
    2. re-install from the upgrade disk, now that you have an OS on the drive.
    haven't done it myself, I'm sure someone here knows for sure.
  • AsSiMiLaTeD
    edited October 2009
    Yeah that defeats the purpose of what i'm trying to do. I'm not trying to screw MS out of the retail price by using the upgrade when I don't own a previous OS.
    I have the OS, I just don't want to go through the trouble of installing two times.
    I found a workaround that includes your first step, but then running a tool to then activate afterwards, but that's apparently illegal, even though I do own vista.
  • vc69
    vc69 Posts: 2,500
    edited October 2009
    Again, I am unclear. Does it have to be an activated copy? Can't you just use the install disk of an upgrade-eligible OS as proof as with former versions? No need to install the former OS, just present the install DVD/CD when asked.
    Am I wrong?
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • PhantomOG
    edited October 2009
    You can google it yourself, but I remember that being a method that MS itself condoned. They are well aware of the "loophole". Just think about how easy it would be for them to close it if they wanted to.
    Besides, since you DO own a previous copy, how are you **** MS?
  • AsSiMiLaTeD
    edited October 2009
    I found a method that appears to be legal according to Microsoft, as long as you DO own a previous OS legally.
    First, the idea of just putting in the install CD of an older OS doesn't work, and I don't think it's worked since Windows XP, so that's out.
    Second, as mentioned the mothod below has been confirmed by Microsoft to be LEGAL, as long as you own a full copy of either Windows XP or Windows Vista. The method can logistically be used regardless of what you own, but can only be used legally if you own a previous OS.
    I do not condone software pirating, and do own a full copy of both Windows Vista AND Windows XP, both full retail copies. So I'm relaying the information below on the assumption that it will be used appropriately.
    http://community.winsupersite.com/blogs/paul/archive/2009/10/23/clean-install-windows-7-with-upgrade-media-the-answer.aspx
  • vc69
    vc69 Posts: 2,500
    edited October 2009
    Thanks for the update. I have to admit that I have not installed Vista more that 10 times and always from the boxes' owner's copy. I do an assload of end user support as a side business and almost exclusively, my customers had me downgrade to XP so I was unaware that the install upgrade-check had changed. :o
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • Systems
    edited November 2009
    vc69 wrote: »
    Theres a great podcast called Windows Weekly on Itunes, this last one addressed all the upgrade questions about Windows 7.
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    Face wrote: »
    I'm running regular 32 bit XP with 6 gigs of ram, i7 920, etc... It should be a nice difference once I can get 64 bit Win7 to work.
    Pauly wrote: »
    You dont even know. Im running a Quad AMD and 4 Gigs and was running XP 32 for a month until the 64 RC came out and that was night and day, now i have Ultimate and got all updated drivers and running even better. I am very pleased with this ver. Best yet IMO. Im from the DOS, pkzip, Pascal, C:, 3.1 etc days....
    Pauly
    You ain't kidding! I upgraded to a solid state drive and Win7x64 tonight, I can't believe the difference!
    The only issue I'm having so far is that my fan controller isn't compatable, so the PC is a little loud at the moment. Otherwise, no issues so far.
  • [Deleted User]
    [Deleted User] Posts: 1,394
    Face wrote: »
    What was the difference? Windows 7? or the solid state? I really want to know, serious.
    Halen
  • Face
    Face Posts: 14,340
    I did both at the same time.
  • Sherardp
    Sherardp Posts: 8,038
    Almost done with a fresh install of Win 7, very nice indeed.
  • Face
    Face Posts: 14,340
    Almost done?
    It should only take a few minutes.
  • Sherardp
    Face wrote: »
    Almost done?
    Yeah it was very short, now Im just reinstalling all my programs, and overclock. Other than that, pretty painless.
