Emotiva ERC-1 Has anyone bought one?
danz1906
Hello,
Whats the scoop with the Emotiva ERC-1 player?
Is it worth buying? Who owns one?
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Post edited by danz1906 on
It look's like a solid player to me, i only wish it was a multi player and not just CD
Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
Dan:
I got a chance to play with the ERC-1 before it went off to a reviewer. For $399 it's one hell of a fine sounding player. The icing on the cake is the remote. You just don't find such a fine quality control anywhere near the price. read the review in the Oct. issue of A$$A.Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
Dan:
Mark,
Thanks for the info, it looks great and balanced outputs for $399.00Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
If you're open to used gear, there's much better value out there.... but that's just my personal opinion.
I was on the review chain. And it wasn't horrible, i guess.
Definitely can't fault the build quality and the beefy remote, though.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »If you're open to used gear, there's much better value out there.... but that's just my personal opinion.
Im going to use it as a Transport most of the time. I take it from your
comments that it didnt Wow you. How was the sound(bright-smooth)?
Is it comparable to say a Rotel 1072?Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
I haven't heard a Rotel 1072, but from what i've heard about it, i would imagine the Rotel would stomp it.
It definitely didn't wow me.
I directly compared it against a Pioneer DV50A (563A) and an Oppo 981HD, on both my system, and Nikolas812's. It wasn't worth $275 more than the Oppo, or $350 more than my Pio. (Personally, i even thought the Pioneer sounded better.)
It was bright, strident even. And even on my extremely warm system, gave me my very first taste of sibilance on my rig.
The plus side? It was VERY detailed, and the imaging was pretty decent. But from what i heard, that sucker would NEED tubes to make it listenable to my ears.
YMMV of course. They DO have a 30 day return policy, i'd say give it a try if you can afford it, your ears may like it.
(EDIT)
Oh hell, you're not far from me... Grab it, then we can get together and try it against all kinds of stuff!
concealer404 wrote: »I haven't heard a Rotel 1072, but from what i've heard about it, i would imagine the Rotel would stomp it.
(EDIT)
My Linn speakers are on the warm side,but the ERC-1 sounds a lil harsh.
I may pickup a used Denon 2910 sacd player instead.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
You can get a Rotel 1072 for under 400.
I got mine about a month ago for 300 shipped.Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
Hello,
Is it worth buying? Who owns one?My Linn speakers are on the warm side,but the ERC-1 sounds a lil harsh.
So you already own one or you just trying to stir a poo pot?
Media Room 7.1
HTPC
sTiLlLeArNiNg wrote: »So you already own one or you just trying to stir a poo pot?
Was thinking about getting one.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
TouchOfEvil wrote: »You can get a Rotel 1072 for under 400.
$300.00 for a Rotel 1072 is a great deal!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
danz1906 wrote:Hello,
I'll re-quote you again and maybe this time you can answer the Q? Am i missing something
Media Room 7.1
HTPC
I was thinking of buying a ERC-1, do you own one?
If so, what do you think of it?Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
No i don't own one but you are claiming that it "sound's" harsh, how did you come to this conclusion ~ 3hrs after your initial post? Were you fortunate enough to have someone local give you a listen? I'm just curious is all
Media Room 7.1
HTPC
sTiLlLeArNiNg wrote: »No i don't own one but you are claiming that it "sound's" harsh, how did you come to this conclusion ~ 3hrs after your initial post? Were you fortunate enough to have someone local give you a listen? I'm just curious is all
Reply #7 has heard the player, I was going by his Comment.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
What he's saying is that from my description, it sounds like a harsh cdp.
And frankly, it is. The only thing in my arsenal that i could find that was harsher on the ears was my POS 300CD changer made by Sony.
I have EXTREMELY warm speakers, run all matched Sidewinder interconnects, a B&K preamp (warm) and my onkyo cdp (warm) and the addition of this CDP with nothing else immediately turned my system into glass shards into the eardrums at higher volumes.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
So you base your knowledge on someone's word? IIRC concealer is alway's saying something bad about Emotiva gear....
I'm not trying to be a d|ck just stating "fact's"
I have never listened to the ERC-1 so i can NOT comment on itMedia Room 7.1
HTPC
sTiLlLeArNiNg wrote: »So you base your knowledge on someone's word? IIRC concealer is alway's saying something bad about Emotiva gear....
If I dont pickup the Denon 2910 sacd player, I may order one to check
it out.Emotiva has a 30 return policy:)
PeaceLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Like i said earlier if it was a multi player and not just a CD/HDCD/MP3 i'd snatch one up, i'll stick with my HTPC for the time being
If you do happen to pick it up please let us know how it is! Emotiva has GREAT customer service so even if you decide to return it you will have no issues
Cheer's!
Media Room 7.1
HTPC
Posted by Concealer...I haven't heard a Rotel 1072, but from what i've heard about it, i would imagine the Rotel would stomp it.
(EDIT)
He personally had his ears on the gear in question...sTiLlLeArNiNg wrote: »So you base your knowledge on someone's word? IIRC concealer is alway's saying something bad about Emotiva gear....
Concealer's knowlege comes from experience, and you have no clue.
I'm not trying to be a d|ck just stating "fact's";)The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »Posted by Concealer...
I personally had my ears on it too, with different gear (more on the neutral side IMO) and came to a different conclusion. You have no dog in this hunt, so why are you telling this guy he has no clue, or even getting involved?
You don't have to talk down to everyone who's **** you're not currently kissing. There is a middle ground, find it please. -
Yeah, you don't remember correctly.
And again. Learn to English.
He was saying that the Emotiva SOUNDS harsh. As in, by description, it sounds LIKE IT WOULD BE a "harsh" unit. Never once did he pass judgement on the player.
You're kinda slow.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
LessisNevermore wrote: »I personally had my ears on it too, with different gear (more on the neutral side IMO) and came to a different conclusion. You have no dog in this hunt, so why are you telling this guy he has no clue, or even getting involved?
And this is why we should never take anyone's word as law in this hobby.
Hell, even on my setup, it may have sounded great to someone else, but i also like a very warm sound.
So... as usual, ymmv, just my ears' opinion.
I won't say it's a BAD player, because it certainly isn't. Just not anything that i'm personally interested in. I know that most people in the demo liked it, so far.
concealer404 wrote: »And this is why we should never take anyone's word as law in this hobby.
Looks like ths Player is Ok to good, but not a Giant Killer. I will have to get
my ears on one. I too prefer the smooth-musical sound to a very detailed
sound.Thats the great thing about this Hobby-Whats great sounding to
one is Terrible to another;)Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Yes Dan, the only way you'll know, is to hear one. Those of us in the demo have agreed not to spill the beans on the open forum, until the demo is complete, but shoot me a pm, and I'll be happy to tell you what I heard. -
...deleted...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
LessisNevermore wrote: »Yes Dan, the only way you'll know, is to hear one. Those of us in the demo have agreed not to spill the beans on the open forum, until the demo is complete, but shoot me a pm, and I'll be happy to tell you what I heard.
Thanks alot............pm sentLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
I'm very curious as to what all the members of the demo group have to say. I was able to hear the ERC-1 for two evenings for about 90 minutes each. I was playing it through a Vista Audio integrated tube amp into my Eficion speakers.
The whole idea of reviews is to give the reader some basic sense, but until one hears gear in their own system they won't truly know. System synergy is a HUGE component of a fine sounding system. That is why most reviewers have a stable of gear to work with in order to be as fair as possible.Review Site_ (((AudioPursuit)))
2 Ch. System
Mark, as you may or may not know, the demo participants have agreed to hold off with their thoughts (publicly) until the demo is complete. It should be wrapping up here in the next few weeks, so stay tuned. I think most of us are willing to spill the beans via PM though....;) -
This sums it up pretty good, I also was in the demo loop and have my opinion. But from the small hints of others I have seen it looks like your statement above will be close to what we will see when everyone has had there time with it. Some will love it, others will yawn at it, and others would not have it on there rack for free. The 30 day return makes it easy to hear if it fits your ears and rig.
