tests and info on speaker wire
lbristow
lbristow Posts: 131
this site has a lot of good info on speaker wire. [url]www.audioholics.com.:D[/url] just type in speaker wire test in the search and a lot of good info comes up.
Post edited by lbristow on
    F1nut Posts: 51,692
    edited October 2009
    They think all amps, cables, etc. sound the same. Not a good site, IMNSHO.
  • mmadden28
    mmadden28 Posts: 4,283
    edited October 2009
    ____________________
    Pool: Atrium 60's/45's
  • Cpyder
    Cpyder Posts: 514
    edited October 2009
    Shhh... Don't talk about audioholics here. Wrong forum. Audioholics believe in blind testing. Seldom people here do.
    Conflicting viewpoints
    flame wars
    Here's a thread I started. It's gets ugly really fast. I suggest you just read the other thread than posting here, because a lot of people will hate you if you talk about Audioholics.
    http://www.polkaudio.com/forums/showthread.php?t=88509&highlight=audioholics
  • lbristow
    lbristow Posts: 131
    edited October 2009
    Cpyder wrote: »
    flame wars
    already did that earlier today, the post was deleted. It is good info, some just can't accept reality:)
  • thsmith
    thsmith Posts: 6,082
    edited October 2009
    Link does not work and can find no info on MITs cables there.
    Dang and I was looking for a good read.
    I wonder what that other sites opinions are on tubes, any bets they think they all sound the same.
    F1nut Posts: 51,692
    edited October 2009
    lbristow wrote: »
    You want to talk reality? Ok, tell me what cables you have listened to.
  • lbristow
    lbristow Posts: 131
    edited October 2009
    as i stated in the post that was deleted earlier today, that is the purpose of this site, they test them and give you the info to decide. not sure why people get so worked up about this, other than maybe they find out the grand they laid down for cable might have been a waste. if this is what people want to do, then ok by me. i just look at the info and go from there. I have mine hooked up to 14awg philips wire, sounds great.
  • thsmith
    edited October 2009
    I started with Monoprice 12g, sounded good, went to AQ T4 sounded better and finally went to MIT S3 shotguns and sounded the best so far.
    Thats all the proof I need.
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    Sometime's we want thing's to sound better because they cost more....
    With that being said:
    I beleive in better cable's just not one's that cost as much as a piece of equipment ;)
    Unless you own these cable's http://www.audiogon.com/cgi-bin/cls.pl?cablspkr&1261514601 your cable's suck and your system sound's like crap :p
    Sorry i missed the epic thread earlier i would've loved to have participated :)
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • lbristow
    lbristow Posts: 131
    edited October 2009
    Cpyder wrote: »
    flame wars
    i see what you mean, may not be as bad as the one i had going earlier today. i don't know, sure some cables sound different than others. i hooked up a monster y instead of the philips i normally use and it sounded different. i switched back to the philips. what amazes me is that when you take a speaker apart and see the wiring that is in there, it is nothing special. not silver, kryptonite, or anything else, not to mention it terminates to a simple metal clip. once you get to a point what else can you do:confused: the site does do a lot of actual measuring, and since this is part of a electrical system i would think this means quite a bit, but sure, some may sound different than others. this does not mean better or worse, just different. then again, some think they can hear better than a canine. this is why i do not care for the term audiophile, to me it means nut job. but i guess if i was sucker enough to pay what some have for a simple cable then i would be a little touchy too;)
  • sTiLlLeArNiNg
    edited October 2009
    C'mon guy's! We all know that "litzed" cat 5e is the wave of the future! :o
    Media Room 7.1
    HTPC
  • Fongolio
    Fongolio Posts: 3,516
    edited October 2009
    I steer clear of these discussions. Nothing good ever comes of it. However, I read the earlier thread and totally do not understand how the thread was deleted but the op of the thread NOT banned. Prolific abussive strong language aimed at specific individuals. It completely blows my mind that the individual was not banned for life. And yes lbristow I am talking about you. Please don't start that again.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
    F1nut Posts: 51,692
    edited October 2009
    lbristow wrote: »
    As I thought, you have no personal experience and therefore, no voice in the matter nor any idea of what reality is.
  • lbristow
    lbristow Posts: 131
    edited October 2009
    Fongolio wrote: »
    sorry, still here:D
  • ben62670
    ben62670 Posts: 15,969
    edited October 2009
    So Lance I thought you were cool, and now you are playing games...
    Ben
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2009
    Can't provide scientific facts that speaker cables make the difference but if my wife and I both hear the difference then what's it matter to me? What should it matter to anyone else how I spend my $ anyway right?
    lbristow if you're happy with your current speaker wire then keep using it, some of us like spending some dollar on what we believe will give us better performance. And as I stated on the other thread, can't wait to get my MIT terminators from a fellow Polkie on here.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • lbristow
    lbristow Posts: 131
    edited October 2009
    as i stated in the first post, this is just a site that runs tests that is of interest to me and maybe others that are not set in their ways. like i said, i could care less if someone spends $4500 for cables, maybe if they read up on it they may make a better decision;) I believe some cables are a little better then others, and the dog may appreciate what that small difference makes,but once you have reached this point that is it, everything else is just hype. do some sound a little different:confused: yes. does that make them better, depends if you like the way it sounds. anyone that thinks you have to spend the kind of money some of this crap costs to get good sound quality is just a fool. get into the same argument on another site about motor oil. it can only get so good, then the rest is just marketing and b.s. have guy's changing the oil every 1k, yes they are nuts, but they will argue all day about it. so, let them if they sleep better at night.:) but i guess you are god and i must agree with you.
  • lbristow
    lbristow Posts: 131
    edited October 2009
    kawizx9r wrote: »
    do not recall saying that i cared at all. i don't. this was just a link for information . deal with it people;) i personally like to know what will give me better performance:D
  • lbristow
    lbristow Posts: 131
    edited October 2009
    ben62670 wrote: »
    do not know how posting a link to a site is playing games. i just can't believe that some people get so worked up over this. if they do not like the results of some of the testing that was done then fine, i did not do it. just thought it may be of interest to some:D
  • BlueFox
    BlueFox Posts: 15,251
    edited October 2009
    lbristow wrote: »
    ...as i stated in the first post, this is just a site that runs tests that is of interest to me....
    Do you know their opinion on vibration isolation gear, especially on solid state equipment? Lately, I have been reading that reducing and/or eliminating vibrations in electronic equipment improves the sound. For whatever reason, I am having a hard time believing music vibrations in equipment can degrade the sound.
  • lbristow
    lbristow Posts: 131
    edited October 2009
    BlueFox wrote: »
    when you say "their opinion", are you talking about the other site, or members here on the forum:confused: no, i do not believe in it, maybe if you were having a 6.5 on the richter scale:eek: I have not searched for it so i am not sure if they have any info on that or not. they are in to everything else, so maybe if you search for it on the site it may come up with something. this is the purpose of a link like this, so people like you and i can see if this has been tested and what the outcome is. hard to believe that people get worked up about such a thing.
  • ben62670
    edited October 2009
    You lacking attention in the real world?
    Ben
  • lbristow
    lbristow Posts: 131
    edited October 2009
    ben62670 wrote: »
    what world would that be:confused: like i said, all i have done is post a link. if some can not handle that then i believe they need a little help. hell, we are talking about speaker wire here, not life or death. the post i had earlier was the same thing and i got ganged up on like a grade school kid on the wrong side of the tracks. only thing was that i do not put up with such nonsense, and some did not like it. well,they should not have started it then.
  • BlueFox
    edited October 2009
    lbristow wrote: »
    I meant the other web-site, but you are right, the question also applies here. I can sort of understand how a speaker wire can improve the end sound since it has electrical characteristics that influence the load on the amp. And, I can understand how tube vibrations can affect the sound, but solid state vibrations are harder to understand and accept.
    Yet, solid state vibration isolation seems to work. At least it does for me. Also, originally my stereo used hardware store stranded copper 12 gauge speaker wire, and it sounded great. However, later I spent $400 dollars, upgraded to a pair of 8’ wires, and was amazed at the improvement.
  • lbristow
    lbristow Posts: 131
    edited October 2009
    BlueFox wrote: »
    i agree, i am sure some wires do sound better than others, but to what end:confused: it has to end somewhere. i just do not believe that you have to spend a insane amount of money to see the improvement. i agree with the gauge, seems you can't go wrong with lower gauge. I would just like to get some of these guy's in a blind listening test and get the real results, then laugh. if they get this upset over a link i could just imagine how that would be:eek: i am in the medical industry, you would be amazed how people think something is better, but it is not. generic over name brand drugs for example. they will argue all day about name brand being better. it is the same thing of course. have had some that think they are in pain, get a order for a placebo instead of morphine and they feel great. all in the mind.
  • ben62670
    edited October 2009
    Gage is way over rated. One of my favorite cheap cables is AQ type 4. It is very low gage as in thin. It is more about purity, construction, and the dielectric absorption of the insulation than just using a big fat cable.
    Ben
  • lbristow
    lbristow Posts: 131
    edited October 2009
    ben62670 wrote: »
    yep, not all about gauge, but seems to be a requirement for longer runs. that is why i have posted this link, it discusses this type of thing. I did buy a monster y cable that has very thin gauge wire and i did not like the way it sounded. went back to the philips and sounds better to me.:) if i remember the link had a fairly interesting article on audioquest wires too.
    F1nut Posts: 51,692
    edited October 2009
    lbristow wrote: »
    sorry, still here
    Not anymore...
    This message is hidden because lbristow is on your BOZO list.
    Life is good! :D
  • mmadden28
    edited October 2009
  • lbristow
    lbristow Posts: 131
    edited October 2009
    mmadden28 wrote: »
    this would be the type of thing i am talking about. pretty good back in 6th grade. I guess some people are so biased that they just act like this for no reason. pretty picture though:D
