Monitor 5 x-over upgrade
Very nice. Those big blues have me wanting. A little hot glue to tie the caps together would go a long way.
Enjoy.
Ben -
Nice, hurry and get the other one done and get listening
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Enjoy.
Ben
May be later. Now, tighten with string:) -
It costs me over 2 hours for one crossover. This is my frist modification project. The other one should be less difficult. I can compare the two for a while:) -
After comparing the mod and un-mod x-overs for a number of songs, the impression of the mod x-over:
1. much smooth (a little bright before)
2. have more bass and low frequency;
3. more detail
4. a little more sweet and warm
Will mod the other x-over today. How long for the burn-in? -
Burn in takes at least 80hrs before it starts showing full potential IMHO, but it can go as high as 400hrs to be fully cooked. You most likely experience degradation in SQ and then it will sound good again. It is a roller coaster ride at times.
Ben -
Ben
Now, the overall sound quality has improved. The SQ will degrade during the burn-in peroid
It won't ever sound as bad as stock. The SQ rises and falls till it is burned in. At times it may sound flat, or busy. Don't worry about it:)
Enjoy
Ben -
Enjoy
Ben
I am eager to hear the 2 mod x-overs. Thank you:) -
It's like Christmas. Like getting a new set of speakers after the mod.
Have fun!Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I used the 33uF SA series. But then I have the RDO-194's. This is still within 5%.
The size of Claritycap SA 33uF is quite large. How to connected and attached to the PCB
I am always thinking I should have used Claritycap SA 33uF instead of Solen 33uF.
I notice the original legs of capacitors and resistors are bent and connected to PCB. I just connected the legs straight to the PCB. It seems the contact of original connection is better. The other completed mod x-over and used solder : -
That looks pretty nice. I had bend the cap leads under so that I could center the cap on the board a little more and reduce the overhang.Stan
Main 2ch:
HT:
Other stuff:
Since the Claritycap is large and need not bend the cap leads under as shown in your picture. The overhang is due to there is no room for the Claritycap.:(
The original leads of capacitors and resistors are bent beneath the PCB for better connection.
