The Bittersweet Sound of Jitter
    nooshinjohn Posts: 26,133
    edited October 2009
    I present the laser turntable...
    http://www.elpj.com/
  • megasat16
    megasat16 Posts: 3,521
    edited October 2009
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • BlueFox
    BlueFox Posts: 15,250
    edited October 2009
    Cpyder wrote: »
    If this is true, the laser would still need to sample the information. Which means its not analog anymore.
    Not being a rocket scientist, I do not see why the variation of reflected light could not be directly translated into an analog waveform.
  • Cpyder
    Cpyder Posts: 514
    edited October 2009
    BlueFox wrote: »
    I believe I agree with you. I was wrong.
  • Cpyder
    Cpyder Posts: 514
    edited October 2009
    I am blown away by the idea of a laser turntable. It's a pretty smart idea. I wonder if they are selling a lot?
  • vc69
    vc69 Posts: 2,500
    edited October 2009
    I would be very interested in hearing one of these things.
    http://www.elpj.com/about/index.html
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • CoolJazz
    CoolJazz Posts: 573
    edited October 2009
    One of the Laser LP players is setting on Audiogon at a bargain price if somebody is itching....
    http://cgi.audiogon.com/cgi-bin/auc.pl?anlgtabl&1256955373
    The Stereophile Test CD 2 cut, BTW, is a 11khz ear splitting sine wave which they add jitter to. :p
    Crpyder....here is more on jitter from Robert Harley and Stereophile from 16 years ago...
    http://www.stereophile.com/features/368/index.html#
    CoolJazz
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • sucks2beme
    sucks2beme Posts: 5,701
    edited October 2009
    The real problem more than jitter is the fact that the cd was supposed to be a short term product. The encoding scheme is set up for best effort delivery
    with no error correction and limited resolution. This was done to limit the size
    of the required media. 650mb off a sigle disc was seen to be a limiting
    factor. Now that we have lots of room on discs(DVD, etc.) The concept of
    a hard copy is fading, and many want smaller file sizes for their IPOD or other
    device. The fact that most music is being downloaded in a low-res format
    is killing the possability of a new format. Also, many CDP's have a poor analog section hurts the format. This is more relevant than jitter in my opinion.
  • Face
    Face Posts: 14,340
    edited October 2009
    sucks2beme wrote: »
    Do we really need anymore formats? We already have plenty, some that even exceed CD quality, WAV, FLAC, AIFF, PCM, M4A, etc...
  • Systems
    Systems Posts: 14,872
    edited October 2009
    Cpyder wrote: »
    It's been around since the late 80's or early 90's and first developed by Finial,whom I believe later sold the design.I know in it's original form it was plauged with problem's and was very costly to manufacture.I doubt it was much of a market sucess.
    sucks2beme wrote: »
    I agree, regardless of jitter levels a subpar analog stage and power supply design will be a bigger limiting factor.
    Testing
    Testing
    Testing
    heiney9 Posts: 25,671
    edited October 2009
    gv#27 wrote: »
    i agree, regardless of jitter levels a subpar analog stage and power supply design will be a bigger limiting factor.
    x 1000
    h9
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2009
    I believe your all a bunch of geeks.
    RT1
  • Face
    Face Posts: 14,340
    edited October 2009
  • CoolJazz
    CoolJazz Posts: 573
    edited October 2009
    How can you say that with such a straight face...ah...Face?? :rolleyes:
  • megasat16
    edited October 2009
    Cool! I am in the game for the last 4 words. :D
  • sucks2beme
    edited October 2009
    Face wrote: »
    I'm speakong more of the delivery format, rather than encoding.
    The industry would like to kill off all hard formats, and make downloading
    the only option. Expect all thos easy to use WAV and FLAC formats to die.
    If it doesn't include DRM, they aren't going to support it.
    Which means you try to copy it or back it up-poof! You HAD some songs
    on your system.
  • madmax
    madmax Posts: 12,434
    edited October 2009
    sucks2beme wrote: »
    From my understanding the data is present 3 times in a row on the disc. The player reads the three and throws out an odd read. Isn't that error correction?
    madmax
    Vinyl, the final frontier...
  • WilliamM2
    WilliamM2 Posts: 4,812
    edited October 2009
    madmax wrote: »
    madmax
    The data is not on the Cd three times. Cd's use Reed-Solomon error correction.
  • madmax
    edited October 2009
    WilliamM2 wrote: »
    Cool, found this. The other garbage I read must have been just that, garbage. :eek:
    From Wiki: "Reed–Solomon coding is a key component of the compact disc. It was the first use of strong error correction coding in a mass-produced consumer product, and DAT and DVD use similar schemes. In the CD, two layers of Reed–Solomon coding separated by a 28-way convolutional interleaver yields a scheme called Cross-Interleaved Reed Solomon Coding (CIRC). The first element of a CIRC decoder is a relatively weak inner (32,28) Reed–Solomon code, shortened from a (255,251) code with 8-bit symbols. This code can correct up to 2 byte errors per 32-byte block. More importantly, it flags as erasures any uncorrectable blocks, i.e., blocks with more than 2 byte errors. The decoded 28-byte blocks, with erasure indications, are then spread by the deinterleaver to different blocks of the (28,24) outer code. Thanks to the deinterleaving, an erased 28-byte block from the inner code becomes a single erased byte in each of 28 outer code blocks. The outer code easily corrects this, since it can handle up to 4 such erasures per block.
    The result is a CIRC that can completely correct error bursts up to 4000 bits, or about 2.5 mm on the disc surface. This code is so strong that most CD playback errors are almost certainly caused by tracking errors that cause the laser to jump track, not by uncorrectable error bursts"
  • CoolJazz
    CoolJazz Posts: 573
    edited October 2009
    madmax wrote: »
    None of which has the slightest thing to do with jitter however. Just to make sure that left turn was followed by the casual reader...
  • sucks2beme
    edited October 2009
    madmax wrote: »
    There's a subject of some debate. :D
    But it still never re-reads the data. Either way, though, the format
    has taken a lot of heat over it's shortcomings. Like sand Vs. Glass,
    The debate won't be settled here. I don't know how much jitter is
    really there. Nor do I care. I know that better CDP's and Better DACS
    seem to have good power supplies and good analog design.
    I think that if a transport of a CDP is of a certain minimum quality,
    the analog section of the CDP/DAC output is where all the real difference
    in sound comes from. Even older DACS chips coupled with good design
    at the analog level sound good. I get WAAAY to much in the way of
    tech headaches every day to get too deep into this.
