Overstock cheap amps , would I be guilty of murdering money?
buymesome
buymesome Posts: 281
edited October 2009 in 2 Channel Audio
Post edited by buymesome on
    heiney9 Posts: 25,492
    edited October 2009
    buymesome wrote: »
    You can buy a used Adcom 545 for the same $$$ or less and it would be 1000 times better than any of those pieces of junk you linked to.
  • buymesome
    edited October 2009
    how much have you saw the 545 go for usualy?
    Would it be even better than the Behringer A500 ? . One guy said on amazon that he powerd martin logans and the value cant be beaten
  • buymesome
    edited October 2009
    the Behringer A500's can be had for $150 and they are bridgeable at 200 watts per channel after being measured by the pro's . $300 for 400 watts is good value
    edited October 2009
    545's anywhere from $140-200.
    Yes, better than Behringer, by leaps and bounds. Even a 535 would do the trick nicely.
    edited October 2009
    buymesome wrote: »
    But they sound terrible and won;t last. What are you wanting lots of power that sounds poor or a nice sounding reliable amp that sounds great?
  • coolsax
    coolsax Posts: 1,826
    edited October 2009
    based on reviews from parts express.. if you were looking to use it for PA work its probably pretty good but I doubt there's much musicality to the Behringer for HT and 2 channel use
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • buymesome
    edited October 2009
    heiney9 wrote: »
    One that sounds great for under $150 if thats even possible
    edited October 2009
  • buymesome
    edited October 2009
    good man heiney9
    I will bookmark that link and when the times right I will pounce on one
  • zingo
    zingo Posts: 11,258
    edited October 2009
    If you REALLY want to use a pro amp, get something decent like a Carver. It won't sound exactly like a HIFI amp, but it would be better than cheaper pro amp.
  • Poee7R
    Poee7R Posts: 906
    edited October 2009
    Quality, not quantity. As most things in life.
    +1 on the Adcom 545's, I think they sound better than their big brother, the 555.
    Dave
    Once again we meet at last.
    edited October 2009
    Poee7R wrote: »
    Dave
    I think it does too.
  • anhchungdoan
    anhchungdoan Posts: 760
    edited October 2009
    Please google for more feedbacks on Technical Pro products. Be careful with the inflated WPC from their products. The Behringer is not very reliable but much better than the TP stuff.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited October 2009
    You may want to rethink this...
    I have an Onkyo 606, and the way the Zone 2 works in it is a little different than usual. When you're using an external amp in Zone 2, the Onkyo won't control the volume level of the second Zone. You have to either use an integrated amp, or a pre-amp/power amp combo.
    I'm not sure if the 607 is the same or not, but I'd imagine it is.
    I'll also second the Adcom 545 suggestion...skip those pieces of junk you linked to. My 545 has driven my RTi8's, Monitor 7A's and SDA 2A's without even breaking a sweat. Don't be scared of the "only" 100 watt rating...it'll get plenty loud.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • buymesome
    edited October 2009
    Realy ?? Then whats the point of having zone2 in powerd mode?
    Doesnt integrated mean you dont need a pre thus eliminating the need for the onkyo ?
    I was aware you could only use analog
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2009
    Since you're adding an amp anyway, why don't you just pick up an inexpensive/used pre?
    What speakers will you be running in this bedroom setup?
    Think you're best ditching the idea of using the Onkyo and the Zone 2 thing. Just grab an integrated or pick up an adcom amp and even an adcom pre. It's always fun building a little modest setup without having to break the bank.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Monster Jam
    Monster Jam Posts: 919
    edited October 2009
    buymesome wrote: »
    ... as I plan on making love to hundreds of college girls this winter
    Hey, a guy's gotta keep warm somehow!
    Do you hear that buzzing noise? :confused:
  • ben62670
    ben62670 Posts: 15,969
    edited October 2009
    I like my 545 too;) A watt is not a watt is not a watt. Think sparkomatic or Kraco.
    Ben
  • comfortablycurt
    edited October 2009
    buymesome wrote: »
    I kind of wondered the same thing when I tried to do it with my 606. I searched through the manual many times though, and not once does it mention a way to adjust the volume of Zone 2 when you're using an external amplifier.
    You can adjust Zone 2 volume when you have the Zone 2 speakers hooked up to the Zone 2 speaker outputs on the AVR...but then youre losing the advantage of using an external amp.
    Supposing that you did use the Zone 2 outputs with an integrated amp, you'd still have the advantage of using the same source(cd player etc...) that you're using with your main system.
    It's still a viable option, but you'd need to look into getting a pre/power amp combo, or an integrated amp.
    edit-Check page 86 of your 607's user manual. It explains the process for using an amp in Zone 2...it says "Zone 2 volume must be set on Zone 2 amp."
    Seems like a stupid way of designing it to me...
  • messiah
    messiah Posts: 1,790
    edited October 2009
    Yep, those are all junk. Save your money, and browse your local CL.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • buymesome
    edited October 2009
    Thanks for the info guys
    My sights are set on this 545 especially since ben has one lol
    I'm curiously jumping the gun here now but what could I expect to pay for a modest adcom pre for rti a3's
  • sadbulquo
    sadbulquo Posts: 1
    edited October 2009
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited October 2009
    ^^reported
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • RandyBox
    RandyBox Posts: 125
    edited October 2009
    Cheap doesn't always suck...
    Folks here said a really cheap amp (Speakercraft) I recently purchased was junk for my HT 5.1, and it turns out to be totally awesome in every aspect.
    Regards,
    Randy
  • concealer404
    concealer404 Posts: 7,440
    edited October 2009
    buymesome wrote: »
    $75-$125.
    I have a couple lying around that i would let go in that price range. PM me if you're interested whenever you're ready, no rush. :)
  • coolsax
    edited October 2009
    $75-$125.
    Being new to the community, it gives me a kick about all these people who just have components lying around that they are not using.. I realize it can become the nature of the beast.. just a little amusing to me as well.
    Main 2ch -
    TV 3.1 system -
  • concealer404
    edited October 2009
    coolsax wrote: »
    I doubt i have a tenth of what most of the active members have around here, though. :p
    I just have a "bad habit" of trying any mid-fi gear i can get my hands on.
    Sooo... in Adcoms, i have: A GTP-600, GTP-400, SLC-505 and i think a GTP-500?
    Yep. Not using any of them at the moment. The SLC-505 is pretty interesting, though. :)
    I'm probably worse with speakers.
  • buymesome
    edited October 2009
    They dont call him Concealer for nothing ya know . Im sure he's got way more than that stuffed away in boxes hes like santa clause when it comes to quality components
    Thats also a very good price too for the pre . you wouldn't be willing to swap for video games?
    Tjhese forums kill me seriously, just 3 weeks ago I joined an rc forum to buy a cheap battery chargerfor my car and somhow got hooked on to lil model helicopters , I have spent $400 buying myself and 2 cousins earrly christmas presents
  • concealer404
    edited October 2009
    buymesome wrote: »
    Nah, i'm no santa claus. :p Don't have that kind of money, and this is honestly my "secondary" hobby. My cars take the majority of my money from me.
    But speaking of santa claus, i think i should take stock of everything and make a big sale thread to free up some cash for the holidays. :D
    Just let me know if/when you want to try one of those preamps. I may even have a 545 back here somewhere, now that i think about it. I'm not personally a fan of it, but there's a lot of variables that make the sound the sound, and it's only my opinion. And you know what they say about those... ;)
  • anhchungdoan
    edited October 2009
    RandyBox wrote: »
    Regards,
    Randy
    It would be unfair to make that assumption but we all know that there is no free lunch. A product is dirt- cheap for a reason. At the same token, there are some expensive hi-end products do perform extremely well and some do not .
    In the case of TECHPRO, WPC spec is outrageously inflated. Behringer has a pretty decent name for professional products but too many negative feedbacks concerning reliability issue.
    I do not have any experience with Speakercraft but AudioSource has some decent amps for background music that normally being used in department stores, offices or hotels...Critical listening, please at least get some mid-fi amps as Para, Rotel, Adcom , B &K.
