Cool broadband speed test site.
1246
  • vijayl
    vijayl Posts: 258
    edited October 2009
    Is it accurate for yall?
    Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07
    , logitech 880
    Def Tech Mythos ST :D Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
    2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
    Bed Room: Pioneer Elite VSX-52 , Monitor 50
    Storage-RTi8,CSi5,PSW505,Monitor50
  • mantis
    mantis Posts: 17,419
    edited October 2009
    Dan
  • TNRabbit
    TNRabbit Posts: 2,168
    edited October 2009
    Sherardp wrote: »
    Fiber Optic connect called FLETS. Here it is wired.
    HOLY **** that's FAST!
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • polrbehr
    polrbehr Posts: 2,842
    edited October 2009
    Sal, I am not sure why the test distance is so important. I figured the only thing that mattered was how fast your connection to your ISP was on your primary PC. What does speed on a home network have to do with my internet connection speed?
    Not trying to break your shoes, I just don't know what you were implying with those different tests, that's all. I mean, wouldn't you want the fastest [possible] speed you could get?
  • Sherardp
    Sherardp Posts: 8,038
    edited October 2009
    As requested. I did some speedtest to various regions far away from me to see what my connection would do. Not bad. I think many of you guys have good speed results as well, but I understand for the really fast stuff there is a premium to be paid in the USA. Next month Japan will release it's true 1GB fiber line for home use so I should be upgrading here shortly as it becomes available. Imagine that.............that should scream.
  • sophie
    sophie Posts: 511
    edited October 2009
    from my dorm with over 1000 people sharing the connection...
    will try it early tomorrow when no one els is using the connection. might try it from one of the nice computer labs and see if they have faster connections.
    Payton
    Polk monitor 10B's and 5 jr's
    Adcom gfa 5500 and HK/240
    Adcom gtp 400
    Adcom gcp 600
    MusicHall MMF 2.1 TT
  • nguyendot
    nguyendot Posts: 3,594
    edited October 2009
    What's funny is I'm in OKC. We have a fiber line direct to Round Rock Tx to their backbone. :)
    Main Surround -
  • jimmydep
    jimmydep Posts: 1,305
    edited October 2009
    Test from one side of the country to the other, seems pretty consistant
    Test to the other side of the world.....not so hot!!!
    Jimmy
  • maggiefan
    maggiefan Posts: 223
    edited October 2009
    Here's mine.
    Larry
  • KrazyMofo24
    KrazyMofo24 Posts: 1,210
    edited October 2009
    Lasareath wrote: »
    The closer you are to your testing area the faster the speed will be.
    Who cares how fast my connection is if I am viewing website hosted in NJ.
    I want to know how fast my connection will be if I am viewing a website in CA, or downloading from an ftp site in Italy.
    That is a true test of an ISP, one that can give you 20Megs from any point in the world.
    I just spoke about the home network speeds because some people don't realize that 20Megs from Verizon Fios is only 1/5 the speed that you get on your home network.
    That internet speeds for the general public have not met the speeds of internal networks.
    If you copy a file from your daughter's pc to your pc in your house over a wired network you are copying it at 100megs
    If you copy a file from an ftp site in NYC then most likely you are copying it at 2Megs or less. There's a Big difference.
    In order to get the fastest speeds at a longer distance it will go to the company who owns the most fiber in their backbone, and in the US that is Verizon, and then AT&T.
    Setup:
    2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
    PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
  • polktiger
    polktiger Posts: 556
    edited October 2009
    Here is what I get. First one is to washington although when I am downloading software from the evil empire I am actually no where close to this.
    Figure this is close to ESPN's host site for ESPN360
    Just and extra test.
    New Zeland - go figure
  • xj4094dg
    xj4094dg Posts: 1,158
    edited October 2009
    I was in the DC area for a couple of weeks. Here is one test I ran (wireless) while I was there at my sister's house in Silver Spring MD:
    "The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
  • polrbehr
    edited October 2009
    Lasareath wrote: »
    OK, I can understand a little better now, thanks for the info !
    Just for the Hell of it, I tried the connection test to other sites around the globe, and sure enough, much slower results, even from the main PC in my living room (wired connection). I guess that's why sometimes my daughters' linkups to Club Penguin is sometimes pathetically slow, even though other sites come up in a matter of seconds.
    Club Polk is usually pretty quick, though, I guess it's close by? :)
  • zingo
    zingo Posts: 11,258
    edited October 2009
  • concealer404
    concealer404 Posts: 7,440
    edited October 2009
    ARG!!!
    I beat your old upload, but can't quite squeek past the new one. :( Can i just blame it on the farther distance? :p
  • nguyendot
    edited October 2009
    polrbehr wrote: »
    Or because for the most part it's all text? It's not very graphic intensive and will usually load quickly on any non dial-up connection.
    My phone loads it up in a matter of seconds even :)
    Main Surround -
  • polktiger
    edited October 2009
    Just for fun...
    A couple in Africa
    But man, given that my level of service is only supposed to be 6mb, New Zeland is still smokin'
    Just for illustration, my closest test site.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited October 2009
  • themuskr
    themuskr Posts: 149
    edited October 2009
    2 Mirage OMD-5's (burled Maple)
    1 Mirage OMD-C1
    4 Mirage nanosat MX
    Mirage MM-6
    Def Tech Prosub 100
    Pioneer Elite vsx-40
    BJC cable
  • RSTERN
    RSTERN Posts: 287
    edited November 2009
    2867470.png Been along time since I got an A.
    mains: rt16
    center: csi40
    surrounds:fx 1000
    sub: SVS 20-39pc+
  • Mantas
    Mantas Posts: 9
    It appears to me that I have maxed out the test server, since I know that the connection speed is actually higher than that :P.
    Onkyo TX-SR806 - Receiver.
    RTi A9 - Fronts.
    CSi5 - Center.
    RTi A3 - Surrounds.
    DSW microPRO 4000 - Subwoofer.
  • danger boy
    danger boy Posts: 15,722
    my results using my laptop wireless home connection.
    PolkFest 2012, who's going>?
    You guys are driving me crazy...especially Sherardp....so close and so much faster...
    I have DSL in Beijing.....did the test
    Download 1.01Mb//s
    Upload 0.30MB/s
    Ping 89ms
    I am 550 miles from the main server in Changchun
    How's that for slow, boys?
    cnh
  • george daniel
    george daniel Posts: 12,096
  • Sherardp
    Shooting for 1gig line when I get back to Japan if the upgrades are available. They were supposed to be ready as of October/November.
  • lanion
    lanion Posts: 843
    cool
    My Iron Man training/charity blog.
    HT:
    32" Sharp LCD. H/K dpr 1001 to Outlaw Audio 7900 to Polk LSi + Paradigm Studio center. Hsu DualDrive ULS-15. PS3/Wii. Outlaw 7900.
  • sophie
    sophie Posts: 511
    still have to try this from a nice computer lab.
    Adcom gtp 400
    Adcom gcp 600
  • audiobliss
    audiobliss Posts: 12,518
    From my dorm room:
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • RuSsMaN
    RuSsMaN Posts: 17,986
    From my wireless laptop. Why the hell is upload so slow?
  • Mantas
    Mantas Posts: 9
    Lasareath wrote: »
    Nice Speed, try testing at various other locations that are farther away.
    Are you at work?
    How much does that connection cost?
    Work == Home.
    No that would be a connection from one of my servers. It's on a 1GigE line.
    My home connection speed is far more pathetic.
    RTi A9 - Fronts.
    CSi5 - Center.
    RTi A3 - Surrounds.
