To "sub" or not to "sub"?
13»
  • concealer404
    concealer404 Posts: 7,440
    edited October 2009
    vc69 wrote: »
    Selling point would be a 4 ohm rating.
    Just about any pos will drive an 8 ohm load.
    Takes a real amp to be stable at 4 ohms.
    True story.
    Luckily, the OP has a real amp that is stable at 4ohms.
    heiney9 Posts: 25,406
    edited October 2009
    Who cares.
    Bob, I was stating my opinion based on the fact you had some blown drivers. They Onk is a good amp and I'm sure it drives your 1C's fine to reasonable levels. All amps have the point where they clip............if that's what's causing your issue turn it down......if not untwist your panties and get working on those 1C upgrades,
    H8
  • vijayl
    vijayl Posts: 258
    edited October 2009
    reminded myself to read the signature from "obieone"
    Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07
    , logitech 880
    Def Tech Mythos ST :D Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
    2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
    Bed Room: Pioneer Elite VSX-52 , Monitor 50
    Storage-RTi8,CSi5,PSW505,Monitor50
  • vc69
    vc69 Posts: 2,500
    edited October 2009
    True story.
    I understand that fact. I also get the impression he's a little misinformed as to the load the speaker he is driving presents to his amp and the point at which his amp may clip, as well as to what may cause a driver to blow.
    bobt wrote: »
    It was a simple question......why it went to amps i have no clue.
    I know one thing, if you clip any amp - drivers will fail. You mentioned failed drivers.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • Systems
    Systems Posts: 14,873
    edited October 2009
    vc69 wrote: »
    If he is running the amp into hard clipping for extended periods (not just on brief transients)then his tweeters are the drivers most at risk.They are what get most of the nasty hi frequency harmonic content resulting from clipping.
    Bobt, on average where are the needles on your front panel power meters usually fluxuating around,mostly near the middle of the scale?the top?
    Testing
    Testing
    Testing
  • bigaltx24
    bigaltx24 Posts: 141
    edited October 2009
    I can't imagine ever needing a sub with my 1Bs. These things have some of the tightest, cleanest bass I've ever heard, and I've owned K-Horns, and large Altecs. The Onkyo is a great amp and should drive 1C's to ear splitting levels without breaking a sweat. One thing no one has mentioned is DC offset. When amps age, capacitors and resistors drift out of spec, transistors break down and need replacing. This is a gradual process and can go completely unnoticed, but high DC offset values can damage speakers quicker than anything. There's a good thread on this here.
    http://www.audiokarma.org/forums/showthread.php?t=5634
    Denon PMA-900V
    Linn Axis with Grado Red
    Cambridge Azur 650C
    Polk SDA-1BTL
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2009
    bigaltx24 wrote: »
    Great link there!
    Keep thinking...why add/replace gear before investing a little more in what you have. Think the $ that would've gone to the SDA's should go into the caps to replace in my amp.
    Btw, -1 on the sub for your SDA's. They have plenty of punch, did you do the cheap tweaks of applying mortite and damping the baskets?
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Systems
    edited October 2009
    bigaltx24 wrote: »
    Good point and yes it certainly can,I had such an incident.It's worthwhile grabbing a multimeter and checking for abnormally high levels(>100mv) of DC at the amps output.The tweeters would be protected but the woofers would be at risk.
    Testing
    Testing
    Testing
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited October 2009
    Bob,
    If you missed this thread here is something that may help you get to where you want to be.
    http://www.polkaudio.com/forums/showthread.php?t=89778
