Neat Little Gadget
There are no more clamps available.
TO ALL WHO HAVE PURCHASED THE CLAMPS, YOU OWN ONE OF ONLY 25 IN CIRCULATION THAT I AM AWARE OF IN THE NEW MILLENNIUM!!!
Should you ever decide to sell your clamp I ask that you give me the first shot at purchasing it.
Thanks to all you guys and I am sure this is the last record clamp you will ever need to purchase. -
I'm sorry, but you'll have to pry it from my cold, dead hands.hearingimpared wrote:Should you ever decide to sell your clamp I ask that you give me the first shot at purchasing it.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Honestly Joe, I don't know how or why anyone would own a turntable without one.
Because he doesn't make them anymore?Ludicrous gibs! -
That was my personal clamp. I am now using the spare which is the very last clamp I had made. I've been trying to drum up the necessary funds and investers to have more made but it is a very expensive venture.
I'm glad you like it Mike. -
Mike you can turn that cap more than half-way if you come across some stubborn warps.
Try going half a turn, it will couple the record tighter to the platter.
In the mean time, reviving that thread was like a blade; "Going through the reading from 2006 - 2007 to find out the clamp going from 130$ + Shipping to 400$ + shipping and suddenly not being available no more". I then tought, how did this wind-up in my daily reading, very confusing! Anyway, I wish I could have been a member then.I'm trying to convince him to go back into production.
This is all for the positive anyway as likely I've been going through all of the possible info on cleaning etc... This is also an eye opener on a good tweek (as a DJ many years ago, I noticed the problem that a not well secured vinyl could do to the audio outcome/end result).
With the re-gaining popularity of the "retro-vinyl" technology, I hope it works out for you. Maybe some of the Polkies that bought and love the product would be willing to venture with youI've been trying to drum up the necessary funds and investers to have more made but it is a very expensive venture.
Cheers!
TKDARE TO SOAR:
Clamp this!
Joe and his fire water, snake oil salemanship! -
Clamp this!
SHUT UP Russ!
http://www.youtube.com/watch?v=_-8dytUtjlQ -
hearingimpared wrote: »
love itPio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Get on 'em Joe!!!~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Shuddup Russ!
Put some snake oil on your bungus. You'll feel better.
:eek::eek::eek: There's a bungus amongus!:D -
A note to Joe: I have owned this clamp for a quarter century or so, and love it. I had not seen other clamps with the features this has, which I see as essential. I'm an acoustician and mechanical engineer so I have a perspective that allows me to appreciate the execution as well as the sonic results. I had trouble recalling the name and the source, but a fellow on Head-Fi filled me in. Just want to thank you and encourage you or someone to take up the manufacture of this or a derivative. If not, thanks for all the music. PS: I use it on a Merrill Heirloom with lead platter. I've wedged the peripheral clamp onto the platter using electrical tape to fill the gap... this removes a ringing of the peripheral clamp (at least my generation of it). The Clamp is successful in making the peripheral weight moot.
Thanks. But I don't recommend the ETII with a subchassis such as this... it can bounce if your floor isn't solid. Also, with my high-compliance AQ 7000 cartridge, it is hard to set up to get deep bass. I may try again soon.
Thanks. But I don't recommend the ETII with a subchassis such as this... it can bounce if your floor isn't solid.....
I hear you! My lead filled rack sits on a suspended floor, not the best for a turntable, either rigid or suspended chassis. A Gingko Cloud solved all my problems with pivoted arms. However with the linear air bearing arm, if the Gingko platform is moving in the same plane as the arm, I can get skips with foot falls by the rack. With the air arm and heavy plinth I shouldn't have to worry about isolation, but the larger Gingko base keeps me from bumping the table when I place the acrylic cover over it (or our cat gets on it).Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I too have owned one of Joe's clamps for about six years or so. I recently glanced at an eBay ad, it appear that this seller has copied Joe's clamp in form and function. He may have actually improved it, I am not affiliated with this seller. Take a look at the link and pay attention to the very last picture. That IS Joe's clamp, no doubt about it!!! Look HereCarl
