Any shifters here that skip gears?
When I had my LandCruiser I would normally skip first gear, starting off in second unless I was pointing uphill.Political Correctness'.........defined
President of Club Polk -
In most v8 trucks, Ill skip 1st gear all the time.
No skipping gears here, my car is too much of a piece of **** to do that, with exception of starting while on steep hill, then its useless to use first and sometimes second. And since I live in Pittsburgh this is not a rare occurence.
Down shifting is a different story though, whenever I have to stop rather quickly due to a light changing or whatever, I usually go from 5 to 3 or 4 to 2. I don't do this too often though and clutch still good as new after 70k. I think I found a good mix between using the clutch and brakes to slow the car, when I first got a manual I never downshifted and destroyed the brakes:pAVR: H/K AVR240
Fronts: Monitor 50s
Center: CSI3
surrounds: R15s
Sub:Velodyne DPS10
Dvd/Cd: Samsung HD upconverter (for now)
TV: 50" Sammy Plasma
game hardware: 360 and gcn.
Gamertag: kovster27 -
Often when skipping gears the rpms will be too low and there tends to be some slippage with the clutch. Good engagement of the clutch causes much less wear than any slipping.
I did a little test today...
I took 1st to 3000rpms and then into 2nd, the rpms dropped to 2500. Next, I took 1st to 3000rpms to 3rd, the rpms dropped to 1800. Lastly, I took 1st to 3500rpms and then into 3rd, the rpms dropped to 2500. So, even if I hit 3000 in first the rpms only drop to 1800 which, at least in this car is plenty high.If...
Ron loves a film = don't even rent. -
comfortablycurt wrote: »That's all getting changed within the next year or so.
Before I read this I was going to say your gearbox is then wrong for the car, you will need to change gearing.
Ron-P wrote:I did a little test today...
I never said it couldn't be done. I said it was harder on the clutch and causes more wear when not done at the optimal rpm. Also, you may be better than most that drive a stick. Another thing most don't realize is when you are stopped, instead of keeping the car in 1st and the clutch disengaged, it causes much less wear to keep it in neutral and let the clutch out and only shift into gear when ready to move."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
SWEET monte!
what does she run in the quarter? Media Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask
My bucket truck hates first gear without a loaded trailer behind it. Second, third and fourth.
When they stay together, yes.Aren't VW automatics not, technically, automatics at all? I think they use a Direct-Shift Gearbox (DSG), which is described as really dual manual gearboxes, in one housing, with dual electronically controlled clutches (one for each gearbox). The main advantage is the elimination of the need for a torque converter. Best of both worlds, maybe?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
sTiLlLeArNiNg wrote: »SWEET monte!
It's mainly a street car...plus right now you can't really lay into it because it's got the stock rear end. If you were to bang the gear in it you'd be grenading the rear end...lol
It generally runs low to mid 12's. Once the rear end and suspension are upgraded, it'll be running a lot faster than that though.My bucket truck hates first gear without a loaded trailer behind it. Second, third and fourth.
Yeah, I forgot to mention that. First gear in my bucket truck almost never gets used except occasionally when we're moving around a yard. Always start it off in 2nd.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Dude... Brakes are a lot cheaper than drive train components. If you are going to downshift at least give the throttle a blip before letting the clutch out to match revs. ... Work on it enough and before you know it you'll be heal/toe downshifting like a race car driver. You really don't have to downshift to slow the car down and it scrubs a lot of clutch material off if you let the clutch do the rev matching.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
I have always been told not to skip gears, so no, I never do, neither going up or down (except that when slowing down, I brake and stop when in second, not first). Also, it's supposed to be very bad to leave your hand resting on the stick while driving, BTW.
Nothing wrong with skipping gears. As long as you have enough torque to do what you want to do in the next gear, have at it. Your automatic skips gears all the time. Most sporty cars that have a 6 speed transmission are geared so that you can remain in a narrow rev range at a particular speed for optimal power, but you don't have to be in that range if you don't want to.
The only reason it's bad to leave your hand on the shifter is because then you're not using that hand to steer. In a track environment your right hand only leaves the steering wheel long enough to get you into the next gear.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
For performance, the DSG gearbox is the ultimate choice. Shifts happen in a very small fraction of a second and you get manual transmission drive train losses rather than losses that you get through a torque converter. Not all VW's have DSG. I was hoping that Nissan was going to add DSG as an option to the new 370Z, but not yet.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
I never downshift, never. It's does nothing but put extra wear and tear on the clutch. When I prepare to stop I keep it in gear and when the rpm's start to dip below 1500 I take the car out of gear and coast with light pressure on the brakes.
I also always sit in neutral, never do I sit stopped with the clutch to the floor and the car in gear.If...
On wearing out the clutch...if this keeps you up at night, learn to powershift and/or rev match(double clutch). Nuff said.
On downshifting...I downshift if I have lots of time to stop or if I need to stop quick(mix of downshift and brake). Otherwise I don't find it's worth the time.
On skipping gears...yes. I've driven a lot of underpowered cars and have to say, driving stickshift has saved me many times. Blown gears, gaining speed on ramps, and foresight. An automatic car doesn't know that you're about to shift and then cruise at that speed. I tell the gearbox that's what I'm doing when it happens(which is over 10x a day). -
Is there any point to this, one way or the other? -
Sitting with the clutch to the floor wears out the throw out bearing.
As for double clutching.. there's no point unless your driving a semi. Double clutching rev matches the gears in the gearbox so that they mesh when you move the shifter. Our cars all have synchros which slow/speed up the gears so they mesh. Has nothing to do with the clutch.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Actually, if you like that one.. I sit in nuetral with my foot off the brake AND clutch if the road is level enough. Hot brakes clamped around the rotor will create "hot spots" (deposited brake material) on the rotor and cause your rotors to pulse, not to mention heat up your brake fluid.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Like you Lowell, I also sit with my foot off the brake. If I get rear-ended, I'm getting a serious push into the car in front of me, or into the intersection.If...
Most of the time, but depends on the driving mood you're in.
I was 50/50 on switching to neutral and letting out the clutch rather than holding the clutch in when sitting still, I will now do it more often. Great tip, I had forgotten about this.
Very nice machinecomfortablycurt wrote: »
Oh I know what 500+ ft lbs of torque feels like:eek: Panasonic 50" Plasma + Pioneer 6010
Toshiba XA2 HD-DVD
Panasonic BD30 Blu-Ray
Pioneer 1014
Polk RTi12 (front)...Polk CSi5 (center)
Polk RTi4 (rear)...Velodyne DLS 5000-R Sub
3 Outlaw M-200 Amps -
What's the reason they told you? -
True but you have to keep in mind too much torque on the gears is a bad thing, they wear out much quicker. -
Not reallyHT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
audiobliss wrote: »That's just as it should be, my good man. Props to you!
Now let's see some pics and vids!!
Ditto -
I skip from 3rd to 5th in the Mazda, since it's capable of going from 30mph to the speed where they skip the ticket and go straight to the rubber hose beating in about... 2 seconds in 3rd gear.
The Celica, i don't skip gears. The ratios are too screwy. I take every gear up to 3000rpms then shift. ~18mph in 1st, 28mph in 2nd, 45mph in 3rd, 55mph in 4th, 70 in 7th.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
It says right in my car manual not to ever rest your hand on the stick, it creates wear on the forks for the gears and can wear it out.What's the reason they told you?If...
