Receiver stuck in protect! +naked Megan Fox pictures
Cpyder
Cpyder Posts: 514
edited September 2009 in 2 Channel Audio
I lied. No Megan Fox pictures. Sorry. But now that I have your attention...
So I was having an awesome listening session and becoming way more familiar with my new 2 channel rig. I was noticing huge differences between my iPod (using lossless) connected through the 3.5mm jack and digital optical from my computer. Also was playing around with Audissey EQ settings and bass and treble controls. I was listening pretty damn loud and was in such a good mood! *
Then I decided to watch some scenes from the first Transformers. I just love the sound effects in this movie. For example, in the opening scene where the Decepticon transforms from a helicopter and attacks the military bass is awesome!
Then, after watching for awhile, with the volume very loud, my Marantz SR5003 receiver shuts down and goes into protect mode. I figure it just overheated. So after a while I try to turn it back on. But find it won't come out of protect. Disconnected everything, same deal!
What did I break?!*
The speakers are 4-ohm LSi 9s. I know the 5003 is 6-ohm rated but most sources say a decent receiver like this will handle 4 just fine.*
I know it wasn't brilliant to push my receiver that hard driving low impedance speakers, but come, did I actually blow it? What would have broken? I figured a mid priced receiver would have a fuse or transister blow first before severe damage took place...
What did I do?
Post edited by Cpyder on
  • WilliamM2
    WilliamM2 Posts: 4,807
    Don't know if you broke it or not, but quite possible. Even Marantz' seperate power amps can't handle 4ohm loads, at least not the new MM8003, or even my 10 year old MM9000.
  • Face
    Face Posts: 14,340
    LSi9's dip down to 2ohms.
  • thuffman03
    thuffman03 Posts: 1,325
    You might have let out the white magic smoke. That does not sound very good IMO. I don't know a lot of AVR's that are good on a 4ohm speakers.
    Remember 4 ohm means average resistance. It can drop to 2ohm which in your case it might have and caused what you now have since you say it can do 6 ohm which might would be fine at low level listening.
    Not sure how good you are with a volt meter or with electronic's but it might need a trip to the repair shop.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • dkg999
    dkg999 Posts: 5,647
    Did you unplug it completely from the outlet and let it sit for a few hours? A tech told me that's why people get frustrated when they bring in AVR's for service and they then fire up and work fine, to bring it in was the first time it was disconnected totally from the incoming power, which then triggered the reset.
    DKG999
  • thuffman03
    Good advice on having it unplugged for a few hours.
    If that fixes it and you still want concert level sound from your system look to invest in an external amp.
  • kcoc321
    kcoc321 Posts: 1,788
    +1 on the "Hard boot"
    Also you might check the manual.
    My B&K has a 'factory rest' key sequence, 3 button you push at the same time....I would think that would get it out of 'protect mode'.
    Oh and here is that Megan Fox pic....
  • kawizx9r
    kawizx9r Posts: 5,150
    kcoc321 wrote: »
    Isn't that from an FHM mag? Looks so familiar...regardless though nice eye candy ;)
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • kcoc321
    kawizx9r wrote: »
    IDK..'Bing' search images
    http://www.bing.com/images/search?q=megan+fox&FORM=IGRE
  • TouchOfEvil
    TouchOfEvil Posts: 967
    kcoc321 wrote: »
    this link is good.:D
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • Cpyder
    Cpyder Posts: 514
    dkg999 wrote: »
    I had it unplugged for at least a night and have tried turning it on many times. Also tried resetting it through holding down 2 buttons for 3 seconds or whatever the manual said. Nothing seemed to help.
  • Cpyder
    Cpyder Posts: 514
    thuffman03 wrote: »
    Speaking of external amps. Can anyone comment on the Niles SI-2125 amp?
    http://www.nilesaudio.com/product.php?prodID=SI-2125&recordID=Stereo%20Power%20Amplifiers&categoryID=System%20Integration%20Amplifiers&catcdID=4&prdcdID=FG01055
    Oh and thank you for not suggesting to "just turn it down." Because I do want concert level sound! I hate when I hear people say, "well just don't turn it up that loud." That's like buying a Lambo and never going over the posted speed limits.
  • Cpyder
    Cpyder Posts: 514
    Or recommend any amp? Pref stereo, ~200watts/ch, 4-ohm stable...
  • megasat16
    megasat16 Posts: 3,521
    I would look at the Parasound Amps offered in the CP flea Market!
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • Shicks18
    Shicks18 Posts: 397
    Is your Marantz a new or refurbished unit?!?
    - More than likely the heat sink needs to be replaced.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Front Amp: Parasound HCA-1000A
    Center Amp: Marantz MA500
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
    Games: Xbox360 and PS3
  • ViperZ
    ViperZ Posts: 2,046
    Cpyder wrote: »
    I might have missed it, but have you tried disconnecting everything from the receiver (speakers and sources)? You could have a short somewhere in the system. If the receiver will continue to behave the same way, you'll have to get it serviced... :(
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • Knucklehead
    Knucklehead Posts: 3,602
    Lasareath wrote: »
    Who the hell is Megan Fox?
    I think she was the chick in Transformers.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • Knucklehead
    Keiko wrote: »
    Never understood the reason why some feel the need to push a piece of gear past it's limit and then have the ignorance to ask, "WTF."
    Thats what I love about my Pio-, goes into overload and shuts itself off. For the record Ive only done this once, and yes I was a little nervous.:D
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • mantis
    mantis Posts: 17,453
    Cpyder wrote: »
    Niles makes whole house amps. this amp I have used many times and find it to be pretty good with speakers not very demanding. 8 ohm loads run excellent off this amp with good clean power and high SPL. It's well built and will last a very long time. All of Niles products are very good.
    Dan
  • sucks2beme
    sucks2beme Posts: 5,686
    Shicks18 wrote: »
    First time I've ever heard of a piece of aluminum going bad.
    Do you mean check to see if it's missing or not proberly re-installed?
    If a hard reset doesn't work, and you've checked connections, then it's off to
    the shop. Sounds like you're ready to go to an external amp.
    LSI series speakers are murder on modern AVR stuff. The old Tweeter stores
    had AVRS hooking up to the wall of speakers, and the LSI9's would
    put them into protection with any real volume. I never understood mixing
    4, 6 and 8 ohm speakers in those setups, but it was very common in all
    stores. Only the real stereo shops were smart enough to dedicate
    demo gear to 4 ohm speakers.
  • George Grand
    George Grand Posts: 12,258
    Awesome legs on that honey!
    I know you got some kind of stereo problem, but it's not as big as my problem right now.
  • phuz
    phuz Posts: 2,372
    Gold!
    It's the little things like this that keep me coming back here. :D
  • sucks2beme
    Don't look at that new spam post thread. That's at a whole new level!
  • cfrizz
    cfrizz Posts: 13,415
    Since you like playing so loud you had better look at an amp that pushes 200wpc @ 8ohms. As you noted you already sent it into protection once. and the LSI's dip down into 2ohm. So the more power the better.
    Now if you don't want to come up with the money for that much power, than I suggest you turn it down.
    I hope it's your receiver that's broken & not your speakers!
    Cpyder wrote: »
  • Cpyder
    Cpyder Posts: 514
    cfrizz wrote: »
    Don't you mean 200wpc @ 4ohms?
  • Shicks18
    Shicks18 Posts: 397
    Cpyder is your unit refurbished or not?
    I purchased a refurbished Marantz AVR, using as a preamp only and the thing randomly went into protect. Sent it off for repairs, and its fixed now. They told me they had to replace the heat sink. Its been working fine now for months with no problems.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • sucks2beme
    Cpyder wrote: »
    Or 200 wpc at 8, 400 at 4. That would get the job done.
  • cfrizz
    No, I mean exactly what I said. 200wpc @8ohm. The more power you give them at 8ohm is the more power you will give them at 4ohm. And the LSI's as you have found out the hard way need LOTS of power.
    Cpyder wrote: »
  • Cpyder
    Cpyder Posts: 514
    Shicks18 wrote: »
    Nope brand new
  • cfrizz
