Another Speaker Cable Thread
  • FittyFieFo
    FittyFieFo Posts: 482
    edited August 2009
    Very nice wire Freddy!
    Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
    Pre-Amp: Marantz AV7005 | Amp: Emotiva XPA-5 | Speaker wires: Signal Cables | Interconnects: Signal Cables
  • madmax
    madmax Posts: 12,434
    edited August 2009
    From a purely physics stand point, Bi-wiring lowers the resistance of the cables and allows for even less degradation of signal quality. Bi-wiring is essentially the same thing as increasing the gauge of a 2-conductor wire.
    It is similar but not the same thing. What is different with a single run is that when the bass is drawing a lot of current there is a reasonable voltage drop across the wire and the treble rides on this waveform. Although the treble frequencies do not see this same voltage drop the phase varies according to the amplitude of the bass peaks it is riding on. You could argue that the voltage drop is only half what it would have been and the phase difference would be half. Its still quite different though since the treble only takes 1/10th the power of the bass and would see almost no phase difference at all when wired seperately. Of course how noticeable it is depends on everything, as does everything else in audio. :)
    madmax
    Vinyl, the final frontier...
  • SoundArtillery
    SoundArtillery Posts: 39
    edited August 2009
    I use Belden cable from BJC. It's not bad for the money. That being said, I got another friend on this forum who's crazy for this hobby. His cables makes a difference in even my modest system.
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited August 2009
    What cables is he using?
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • SoundArtillery
    edited August 2009
    MIT Shotgun cables
    nooshinjohn Posts: 25,963
    edited August 2009
    MIT's are next for me, but I will need a new profession before I make that leap... Is there an online course in robbing banks?:eek:
    j/k:p
    treitz3 Posts: 20,057
    edited August 2009
    Face wrote: »
    It depends on who you ask.
    Not a damn thing here.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited August 2009
    j/k:p
    Used MIT's can be had for not very much money...
    Many different models can be had for 250-300 dollars.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • rubin
    rubin Posts: 565
    edited August 2009
    So what's so bad about a couple runs of 10 or 12 awg stranded copper? Cheap and thick enough for the job,isn't it?
