Another Speaker Cable Thread
nooshinjohn
nooshinjohn Posts: 25,962
edited August 2009 in 2 Channel Audio
This has most likely been discussed at length... but thought I would take a swing at this for myself. I am looking for a 15ft pair of bi-wired speaker cables that would be a good match for my 1.2TL's and the Sunfire I have driving them. The rub is that I want to stay as far below 200.00 dollars as I can, and still have something that is of decent quality. I am one that believes in the merits of the speaker cable debate and believe you cannot expect lamp cord to be able to handle the load, so no comments please from those that feel otherwise, as this is not a debate.
Anyone with ideas please?:)
Post edited by nooshinjohn on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited August 2009
    15ft biwired speaker cables are very expensive. For that price it's not alot out their in the new department. Signal Cable might be your best bet or used Type 4's
    edited August 2009
    That's what I am finding out as well... hopefully one of our enlightened bretheren will have suggestions
  • dkg999
    dkg999 Posts: 5,647
    edited August 2009
    I haven't checked the prices, but either Signal Cable, AudioQuest Type 4, or Kimber 4TC would be my recommendation to look at. The other thought is that Canare S411 with some good nanners might be a good match. It's often overlooked and is a very good modest priced cable. You can go to Blue Jeans Cables website to check it out.
    DKG999
    edited August 2009
    those all look pretty good, but with exception to the Canare s411, all the cables suggested are twin lead. I am hoping to find a biwired/biamped set...
    Thanks so far with all the help...
    Jogb
  • dkg999
    dkg999 Posts: 5,647
    edited August 2009
    Call Frank at Signal Cable and discuss what you need with him. I have Signal Cable Ultra bi-wire cables and they are fantastic for the price.
    DKG999
  • george daniel
    george daniel Posts: 12,096
    edited August 2009
    Most likely gonna cost a little more than your budget,,but,,MIT T-2 "grey".
  • kawizx9r
    kawizx9r Posts: 5,150
    edited August 2009
    +1
    I got this same exact wire (well 14 ga.) for a on-the-cheap solution replacement to my surrounds/rear center. The stuff is great, cheap, and offered a type of quality feel you don't get from other 'plain' speaker wire. The jacket was thicker than other jackets of this gauge, and very flexible too. Off the spool it was easy to handle and didn't coil up like other wire generally does.
    As far as cables for your fronts, I'm running 12' pairs of Belden 5000 12ga. and love it. Noticed a slight punch in bass, and maybe you can call it a "placebo" affect but everything seemed just a tad bit cleaner. Terminated at the ends with nanners from BJC as well.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Face
    Face Posts: 14,340
    edited August 2009
    Or you could only go with a single run and use some extra wire to replace the crap jumpers.
  • vmaxer
    vmaxer Posts: 5,120
    edited August 2009
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Ricardo
    Ricardo Posts: 10,634
    edited August 2009
    Bi-wire is overrated. +1 on Signal Ultra and Type 4.
    SOPA
    edited August 2009
    the bi wire sets are all nice and I am grateful guy... I fell like a total idiot as I should have said biamped in my op....
  • dkg999
    dkg999 Posts: 5,647
    edited August 2009
    With bi-amping you may not want the same wire for the mid/bass and tweets so you could use your current wire for one or the other, and invest in some new wire that has either good high-end or good mid/bass characteristics, then at a later point invest in the other side.
    DKG999
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited August 2009
    That makes the mono stuff even easier to use. Bi-wire is harder to self terminate, if your using really thick wire. 4 x 12 AWG conductors, in a braid pattern, terminate with bananas (if you don't like monoprice nanners, use these:)
    http://www.speakerrepair.com/mm5/merchant.mvc?Screen=CTGY&Category_Code=AHH_Banana
    Voila. Out the door for way way less than $200.
  • Face
    Face Posts: 14,340
    edited August 2009
    I found that Monoprice bananas degrade sound quality.
    While building my DIY speakers, I used two pairs of Monoprice bananas, piggybacked into each other. In later stages of testing, I started to clean the wiring up, removing one pair of bananas and noticed a increase in sound quality. I immediately removed the second pair of Monoprice nanners and again was pleasantly surprised. Termination is very important, don't skimp out on it. If a nice pair of nanners or spades aren't in the budget for now, use bare wire for the time being.
  • madmax
    madmax Posts: 12,434
    edited August 2009
    AQ Type 4, single run, no bi-wire would be my only choice for under $200, and its not a bad choice. :)
    Vinyl, the final frontier...
  • NJPOLKER
    NJPOLKER Posts: 3,475
    edited August 2009
    What does bi-wiring do to better the sound quality?
    None of my speakers can be bi-wired but I do wonder what its all about.
  • Face
    Face Posts: 14,340
    edited August 2009
    NJPOLKER wrote: »
    It depends on who you ask.
  • madmax
    edited August 2009
    NJPOLKER wrote: »
    It allows the bass and treble not to affect each other as the currents and voltages of each change. Sometimes it makes a nice change by opening up the sound, sometimes it causes a problem by making the bass and treble not sound coherent. I'm guessing your sunfire has the two outputs per channel? I believe they are labeled as current and voltage? If so you got a lot of testing to do to figure out what sounds the best. :D
    madmax
  • NJPOLKER
    edited August 2009
    Max, Not me. Thanks for the explanation.
  • JohnLocke88
    edited August 2009
    NJPOLKER wrote: »
    From a purely physics stand point, Bi-wiring lowers the resistance of the cables and allows for even less degradation of signal quality. Bi-wiring is essentially the same thing as increasing the gauge of a 2-conductor wire.
  • W WALDECKER
    W WALDECKER Posts: 900
    edited August 2009
    You can get Element cable 10 AWG EC doublerun in shotgun configuration biwired for $209.00 a 15 ft pair. these are very well made cables and well worth the money.good luck....WCW III
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
  • RCFGuitars
    RCFGuitars Posts: 159
    edited August 2009
    I recently switched to a bi-wire set-up for my 2.3TL's using this 10G wire:
    http://www.knukonceptz.com/productDetail.cfm?prodID=KASA10PRL
    And these ends:
    http://www.knukonceptz.com/productDetail.cfm?prodID=eKs-BP
    I have 10ft runs, and while I am still tweeking and evaluating, I am very pleased with the cables thus far. Your 15ft runs would be right around that $200 mark.
    Primary System
    Polk Audio SDA SRS 2.3TL (RDO198,Sonicap/Dayton/Mills,CardasCCGR,Mye Spikes,DynamatX,Driver Rings,Ben's IC,Bi-Wired)
    Polk Audio CSiA4 x2 (C)
    Polk Audio FXiA6 (S)
    Polk Audio RTiA3 (RS)
    Polk Audio FXiA4 (FX)
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Technics/KAB SL-1210M5G w/ Denon DL-160
    Parasound Halo P7
    OPPO BDP-83
    Panasonic TC-P65V10 65" Plasma
    edited August 2009
    I decided to give these a try... Canare 4S11 (Star Quad cable, 14 AWG) from BlueJeans Cables... I already have terminal ends that will get me by for now, and I think for less than 60 bucks shipped that I will be fine for a while with them. I hope to try some higher end stuff when the budget allows.
    thanks for keeping the thread civil, even though a few have chosen to tag the thread in the usual BS way:)
    John
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited August 2009
    Get rid of tags and the frickin' cowards, too.
    Cowards....
  • messiah
    messiah Posts: 1,790
    edited August 2009
    Hey John. You might want to consider grabbing the audioquest 14/4 cables. Mantis swears by them, and I have some and they sound great. They are bulk cables, and are cheap.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • leroyjr1
    edited August 2009
    John you should seriously save up a little more money and jump into the MIT club. I have a guy at my job that's suppose to be buying my 2nd set of shotguns if he backs out I'll let you demo them. They're only 8 ft.
    edited August 2009
    leroyjr1 wrote: »
    my initial measurement was off, and actually need closer to twenty feet for one of the runs, but to demo shotguns, I think I can find a way to make it work:) Thanks, and let me know what happens.
  • kawizx9r
    edited August 2009
    Hey John, I really dont mean to threadjack but I think you (and others reading this) could benefit from what others have to say about my post. Others have recommended you to use BJC, and yes we all know MIT and other such brands provide way better quality but I'm talking about an alternative budget friendly method.
    Will running a DIY cable like the one I'm displaying here (that I just made 10minutes ago) outperform something like basic signal cable or even my belden 5000 12awg? DIY is done using monoprice 14awg wire - http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023902&p_id=2748&seq=1&format=2
    I ask because if it will, especially considering I used a "braiding" method thats preferred for DIY speaker wire, I'd like to go ahead and finish terminating it along with covering it all up using Techflex expandable sleeves.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
