Tales of the Furutech Flattener
There is also nowhere in the manual that it says you put your right in front of you left, but that is how you do it.
I seem to recall the manual stating you can flatten records with an edge guard, so 45's have edge guards, I guess we should check but if you use a flat type 45 center holder cannot see why it would not work.
RT1 -
I'm pretty sure my 7" 45's have no edge gaurd. 12" ones do for sure.Vinyl, the final frontier...
all those old 45's I have have guards, that was the thing afterall, you played em and let the auto changer do its thing. Maybe some did not, but I have a about 100 of them at the house, definetly have the edge thing.
RT1
