SDA SRS 2.3TL problem / questions
RCFGuitars
RCFGuitars Posts: 159
edited August 2009 in Vintage Speakers
I’ve been searching threads for answers to a similar problem, and I was able to get quite a bit of info from a recent post by vmaxer. However, I still have a couple of questions that I hope some of you SDA experts can help me answer, and/or offer some suggestions.
I’ve had these 2.3TL’s for a couple of weeks now. When I have run them 2 ch. stereo, as opposed to part of the HT setup, I have also run my subs, with the TL’s crossed over at 80Hz. I had no trouble producing high decibels without distortion.
Yesterday, I sold my 2 subs in anticipation of a new pair on the way. I set up my system to run without subs, with the full range going to the 2.3TL’s. They sounded fine until I started to turn it up to see how they performed at high volume on their own. When I reached a substantial volume level, but a level lower than the levels previously attained with the subs, all hell seemed to break loose. The mid drivers started popping, it sounded like tweeters were coming in and out, and the imaging was coming and going. It also seemed to me that the 15” passive was not moving in and out a great deal. When I turned up my SDA2’s, the 12” really moved. Talk about a sick feeling in my stomach.
Here’s what I’ve checked so far:
The Adcom amp is not clipping. Or if it is, the front indicator lights are not showing it. I realize that the Adcom is not common ground, but the neg. terminals of the fronts are strapped together per Adcoms instruction.
The auto set up on my Yamaha checks the phase / polarity, and it says that is all okay. I have faith in this feature because it detected mis-wired drivers in my SDA2’s.
EQ is flat.
I tried the 2.3TL’s with another (less powerful) amp, and the same problem.
I tried different recordings and different sources.
All of the drivers are moving freely. If I push in and hold the passive radiator, all the mids push out and go back in 2-3 seconds.
Finally, I plugged my SDA 2A’s in without changing any settings, and they sounded great. I was able to reproduce the popping noise of the mids, but at a higher volume level than the 2.3TL’s, and the noise was not as intense or pronounced.
I can only come up with 4 possible answers:
1. Even though the mid drivers are moving, one or more could be bad, or has a short at the wiring connection. But, I don’t think that explains the tweeters.
2. I have an aftermarket SDA cable. Could that have something to do with the imaging problem? It does, however sound good at lower volume. (Probably not an issue, but I don’t like to leave any stones unturned)
3. Crossover issue?
4. The Adcom 5503 does not have the power to run 2.3TL’s full range at high volume.
Any suggestions, help, or guidance would be greatly appreciated.
Primary System
Polk Audio SDA SRS 2.3TL (RDO198,Sonicap/Dayton/Mills,CardasCCGR,Mye Spikes,DynamatX,Driver Rings,Ben's IC,Bi-Wired)
Polk Audio CSiA4 x2 (C)
Polk Audio FXiA6 (S)
Polk Audio RTiA3 (RS)
Polk Audio FXiA4 (FX)
Epik Sentinel x2
Yamaha RX-V3900
Rotel RB-1090
Rotel RMB-1095
NAD C565 BEE
Technics/KAB SL-1210M5G w/ Denon DL-160
Parasound Halo P7
OPPO BDP-83
Panasonic TC-P65V10 65" Plasma
Post edited by RCFGuitars on
  • zarrdoss
    zarrdoss Posts: 2,562
    edited July 2009
    if both sets were doing it even at different levels your problem should not be in your 2.3's If you have a multi tester I would start by checking your 2.3's with that.
  • tcrossma
    tcrossma Posts: 1,301
    edited July 2009
    I've never owned SDA's, so take what I have to say with a grain of salt. I'm sure someone with more experience will chime in soon.
    What you are describing sounds like a power issue to me. The amp is being required to do a lot more now that you don't have a sub to help out. I know the SDA's can take a lot of power, and that Adcom amp can pump out plenty of power, but for some reason it seems to be lacking in this particular case.
    Good luck tracking it down.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited July 2009
    As the previous owner of your 2.3tls I always had them run in full range and never noticed any popping or tweeter issues. Running them off my Adcom 555II they sounded great and had more bass output than my Polk Micropro 4000 sub.
    Did you have the grounds tied together everytime you play the SDA's with the IC cable connected. I'm going to be down by you tomorrow if you like I can stop by and take a look for you. Did you try using the spare mid driver I gave you on the popping mids?
  • george daniel
    george daniel Posts: 12,096
    edited July 2009
    Hmmm, same issue,,different speakers,,, I'm thinking,,AMP,,, be thankful that you did not blow anything, hopefully.It's been my experience with 2.3's, that the more current,and power,,current being the key word,,the better they sound,, not being familar with that particular adcom,,have you ruled out the "non common grounding issues?,,Good luck,,can you try another amp?
  • RCFGuitars
    edited July 2009
    leroyjr1 wrote: »
    Thank you Lee. Yes, every time I've used the 5503, I've had the grounds together. I haven't tried swapping drivers yet. It actually sounded like more than one. If we can get our schedules to work tomorrow, it would be great if you could take a listen. Another CP member in my area with 2.3tl's also offered to let me try my speakers with a bigger amp to see if that's the issue. I guess at this point I'm starting to think it's an amp/power issue.
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
  • RCFGuitars
    edited July 2009
    I did try running them with my Yamaha AVR, 140wpc/8ohm, and had the same issue.
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
  • RCFGuitars
    edited July 2009
    zarrdoss wrote: »
    I do have a multi tester. Should I start by checking the impedance of each driver?
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
  • zarrdoss
    edited July 2009
    RCFGuitars wrote: »
    Start with the impedance of both speakers and if you get any discrepancies then start pulling individual drivers. I really don't know what could happen to a crossover all the sudden like that do do what you say it did. You might also pull the jumpers (to bi-amp them) and that way you can troubleshoot the hi and low frequencies separate.
  • zarrdoss
    edited July 2009
    also you might have a bad speaker cable / wire. or a connection in the crossovers. I would also try a completely different rig (source, pre, and amp) with different wires and IC's and check all your connection real well.
  • RCFGuitars
    edited July 2009
    zarrdoss wrote: »
    That's a good idea. I'll try bi-amping them when I get home tonight. I can do that with my AVR if I disconnect my rear surrounds. If it's a power issue, that should also make a difference.
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
  • zarrdoss
    edited July 2009
    also do you still have the original pollyswitches on them? could account your tweeters going in and out at high levels.
  • RCFGuitars
    edited July 2009
    zarrdoss wrote: »
    As far as I know, the internals are 100% stock. Are the pollyswitches part of the tweeter itself? I am planning to install RDO-198's in the very near future.
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
  • zarrdoss
    edited July 2009
    no pollyswitches are on the crossover the 2.3tl's have 4 they're a self resetting switch that if it gets too much current it will heat up and shut off the supply to the tweeter, good idea only problem is after 20 years they start to go out at lower current than they're supposed to and tweets will cut in and out or go out altogether. They are a thin yellow round disc about 1/4" width two legs coming out.
    You can take them out and by-pass them or Polk will send you new ones for free.
  • RCFGuitars
    edited July 2009
    zarrdoss wrote: »
    That is great info! Thank you. I'll check those out as well. I think it's inevitable that at some point I will be getting the crossover mods that many here already have, but first things first.
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
  • vmaxer
    vmaxer Posts: 5,120
    edited July 2009
    Good luck with the issue. I am waiting to get my new tweeters to continue the troubleshooting process.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • zarrdoss
    edited July 2009
    RCFGuitars wrote: »
    Your welcome crossover upgrades will help the sq but pollyswitch failure is fairly common on these.
  • RCFGuitars
    edited July 2009
    vmaxer wrote: »
    Thank you, and best of luck to you as well. This forum is great, and the folks here have a lot of knowledge. I'm confident that with all the help, we'll both get our SDA's sounding the way they are supposed to.
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
  • WastelandWand'r
    WastelandWand'r Posts: 466
    edited July 2009
    The 5503 is good for 200X3 if i remember correctly without checking my sources (internet) on it. If anything has quit on you in the guts of it, it may be seeing a 'tiring' current demand, crapping out on you and sending your 2.3's an ugly square shaped signal that your drivers are dutifully trying to reproduce, with the predictable results. Rattling/slapping drivers, tweeters going into protect mode and trying to tell you that things are not all good in the world.
    The easiest thing would be to try a different amp to see if that eliminate the problem. If it doesn't fix it you are teetering on the slippery slope of troubleshooting.
    The condition described sounds exactly like my Monitor 10's when I asked too much of the AVR. In a drunken stupor I thought it 'awesome' to overdrive things. Turn it down, problem solved. With my ADCOM 555II it will drive them to some pretty healthy pressure levels without sweating.
    I really hope it is something easy and you are back to enjoying them right quick. My fingers are crossed for you.
    Good Luck,
    Nathan
    Home Rig
    SDA 2.3TL's front and center
    Polk 1000p Center
    Pioneer Elite SC35 Receiver (Pre/Surround
    Sunfire Cinema Grand 5X200-Back in the mix.
    OPPO BDP-93
    Squeezebox
    Stepped up to name brand Speaker Cables and interconnects!
    Monitor 4, 5, 7, 10's, SDA 1B's, 2B's, 2.3TL's, RTA 15TL's all in storage waiting for me.
    Sales Rating #1!!
  • george daniel
    edited July 2009
    I'm still thinking,,amp.
    F1nut Posts: 51,770
    edited July 2009
    What is high volume.....more than half on the volume knob?
  • RCFGuitars
    edited July 2009
    Sorry, I should have included that info in the OP.
    I don't think my volume knob has any markings on it, but I'm sure it's got to be over half. I'm using my AVR as the pre, and the range on its volume read out is -80.0dB to +16.5dB. Running 2 channel, with the subs hooked up, 0.0dB was clean and loud. With the TL's full range, depending upon the source, things started to go crazy around -8.0dB. When I hooked up the SDA2's full range, they stayed clean until -3.0dB.
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
    F1nut Posts: 51,770
    edited July 2009
    Ok, the SDA SRS 2 and the SDA 2A (not sure which you have) both have an efficiency of 92dB, while the SDA SRS 2.3TL is 90 dB. So, you'll get more volume before clipping from the SDA SRS 2 or the SDA 2A.
    Half or more than half volume will put your amp into clipping, which from what you have described is what is happening. Turn it down before you do serious damage.
  • leroyjr1
    edited July 2009
    RCFGuitars wrote: »
    0.0db is very high. What to you have your bass set at?
    nooshinjohn Posts: 25,925
    edited July 2009
    I have set my pre to not allow anything beyond 0db. Typically I will go no louder than -10.0db when running my TL's
  • RCFGuitars
    edited July 2009
    My second set of speakers that I have been using for testing are SDA 2A's. The Adcom has lights on the front to indicate clipping, and in this situation even the yellow warning lights are not lighting at all. Right now, the EQ is flat, no boost or cut to any frequencies.
    I don't know now, maybe the speakers are okay, and I just need more amp. There's a McIntosh MC2600 on ebay right now - maybe I should pick that up. 600wpc should be enough:D
    Or, maybe my idea of serious SPL's is different that most, and I'm expecting too much from this rig. Could have something to do with standing in front of Marshall and Hiwatt stacks for the past 20 years:)
    I'm going to start by bi-amping with more power, and see what happens from there.
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
    F1nut Posts: 51,770
    edited July 2009
    I don't care what the lights are telling you, it's clipping. As for SPL's, keep in mind that for every 3dB increase it takes double the power.
    Your 2.3TL's......
    90dB -1 watt
    93dB - 2 watts
    96dB - 4 watts
    99dB - 8 watts
    102dB - 16 watts
    105dB - 32 watts
    108dB - 64 watts
    111dB - 128 watts
    114dB - 256 watts
    117dB - 512 watts
    120dB - 1024 watts
  • vmaxer
    vmaxer Posts: 5,120
    edited July 2009
    Your 2.3TL's......
    90dB -1 watt
    93dB - 2 watts
    96dB - 4 watts
    99dB - 8 watts
    102dB - 16 watts
    105dB - 32 watts
    108dB - 64 watts
    111dB - 128 watts
    114dB - 256 watts
    117dB - 512 watts
    120dB - 1024 watts
    Is this at a distance of 1 meter??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    Tony M Posts: 11,623
    edited July 2009
    I think I was having the same distortion problems with my SDA-SRS2's .
    After I replaced my interconnect sockets and bought a new cable from Polk cust.serv. the sound is incredible now!
    I feel I have to turn the volume knob more than I ever had to before. I don't know if this part of having to drive them loud or not.
    Dose anybody else have to turn their volume knob to 12:00 to play these big guys loud?:confused:
    F1nut Posts: 51,770
    edited July 2009
    vmaxer wrote: »
    Yes.
    edited July 2009
    That's good to know:D. I don't feel short changed now. Their sound is awsome at regular volumes too but sometimes we've just got to hear it loud.:D
