Volume levels (low voice but effects really loud)
jonc
Hello.
I justed hooked up my equipment for the first time over the weekend. This is the problem I seem to be having..
Center channel main speach volume is low, but then a explosion goes off and it is really loud. So at night, I'm turning it down so I dont wake the kids up but then I can't hear the dialog.
I haven't played with the speaker setting or the auto room setup which my receiver comes with.
Any suggestions?
Any suggestions?
- Center TC265i
- L/R F/B TC80i
- Sub DWS PRO 400
- Receiver ONKYO TX-SR876
- Projector Panasonic PT-AE2000u
- Screen Da-Lite 106"
Post edited by jonc on
It has an incredibly high dynamic range; sounds about right!
You can usually adjust the dynamic range between Hi/Med/Low for that reason. Low might be titled "night mode" or something of that nature...TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Page 109 in your manual."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Run the calibration so that the speaker levels are adjusted correctly.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
Hello.
Any suggestions?
suggestions, yes... play with the speaker settings and the auto room set up. since you havne't done that.. no wonder you can't hear the dialog and the effects channels are to loud.
run the auto room set up.. and play around with the settings.. i know it'll make a difference.
it's not uncommon after you run the auto set up.. to have to go into the receiver menu and raise the volume on your center channel to hear dialog better.PolkFest 2012, who's going>?
Hello.
Any suggestions?
I've highlighted your problem for you.
Run the auto setup and then report back. It should take care of your issues.
As Danger Boy said, it's not uncommon to have to go into the menu and adjust the center channel level to your personal tastes afterward. I've found that it's usually necessary to manually adjust the sub a bit as well, to tailor it to your own tastes.
By the way, welcome to Club Polk.:)The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Welcome to Club Polk jonc.
The guys gave good advice so do those things first, that failing you should run outside in a rain storm naked except for a small loin cloth and speak in audio tongues to the sound gods, alot of twisting and jumping and grunting noises usually works for me.
Welcome to CP.
RT1 -
reeltrouble1 wrote: »The guys gave good advice so do those things first, that failing you should run outside in a rain storm naked except for a small loin cloth and speak in audio tongues to the sound gods, alot of twisting and jumping and grunting noises usually works for me.
Welcome to CP.
RT1
I thought I was the only one who did that. It's raining right now I might go and do it right now for good audio karma
