Power Conditioner Failure... twice?
If I were the only one with such issues, that wouldn't explain why neighbors have dimming lights or why the guys next door need to have their central A/C compressor fixed so frequently...polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
It's Old or it's Junk... Who knows for sure.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Who cares...
I won't be living here in another year anyways. Either someone is going to buy the land or a new house will be built on this lot.polkaudio RT35 Bookshelves
Who cares...
Ok then, have someone or ourself put a new outlet with 2/12 wired backed to the main panel. I think that will fix all your troubles.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Put the power conditioner under your receiver, it needs to breath."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
disneyjoe7 wrote: »Ok then, have someone or ourself put a new outlet with 2/12 wired backed to the main panel. I think that will fix all your troubles.
Will do once I move in. I might be getting out of NY depending on which grad school I end up going to...polkaudio RT35 Bookshelves
If you live in the city, that is some really bad regulation by the utility.
If you live in the country, it's not unheard of. Personally, I wouldn't put up with it. -
What's so bad about having it on top of the Onkyo? It's not like the new 706/806 series that gets reallllly hot...polkaudio RT35 Bookshelves
The problem still occurs just like before and I am afraid the Onkyo will be toast from going into Protect mode.
Why the heck is the Onkyo going into protect mode anyways? Shouldn't protect mode be for shorted speaker cables, not high/low outlet voltage?
This, and the 4ohm speakers and long runs of cables aren't helping you either.What's so bad about having it on top of the Onkyo? It's not like the new 706/806 series that gets reallllly hot..."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Most receivers need a fair bit of space to breath, regardless of whether they are known to run very hot or not. My Yamaha RX-V2500 specifies 18" clearance above in the manual. I think 6" is more like it, but generally it's not a good idea to place anything on top of a receiver or amp.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
Sorry unless you fix that power issue nothing short of rewiring an outlet will fix your problem. And pluging anything in is going to break. Get serious, and get it fixed.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Get yourself an Inductrol and put it between you & the power co
http://www.geindustrial.com/cwc/Dispatcher?REQUEST=PRODUCTS&pnlid=5&famid=44&catid=50&id=inductro
Problem Solved -
disneyjoe7 wrote: »Sorry unless you fix that power issue nothing short of rewiring an outlet will fix your problem. And pluging anything in is going to break. Get serious, and get it fixed.
It's not just me. My neighbor 8 houses down the road checked his outlets with a voltmeter, and also got high voltage.polkaudio RT35 Bookshelves
Call the power company again, and if not.....
I PM you.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Dude since my neighbors' electronics are also experiencing the same problems we should all call. The guy who lost his scanner was pissed.polkaudio RT35 Bookshelves
Yes, since you're not alone with electrical issues. But I think both of you should call the same day, and maybe your other neighbor with the AC problems.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Take a rocket launcher to the nearest transformer in your neighborhood.Jay
Eaton makes UPS's that can handle voltages over 130v.
http://powerquality.eaton.com/Products-services/Backup-Power-UPS/Evolution-S.aspx
http://powerquality.eaton.com/Products-services/Backup-Power-UPS/9130-Rackmount.aspx"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I thought they made superchargers?
Corvette ZR1 anyone?polkaudio RT35 Bookshelves
Bad news...
The Monster HTS3600 seems to "choke" the amp at higher volumes - everything sounds dynamically compressed and there is no separation between instruments.
So I unplugged the Monster and plugged everything directly into the wall, and all the detail was back. With the Monster connected it sounded as if everything was ramming together - what a mess.
Is it common for power conditioners to choke an amp and make it sound more compressed? I did an A/B with the Monster vs. without and you can't even stand to listen to the rig with the Monster connected. It's just so compressed and awful sounding.polkaudio RT35 Bookshelves
Bad news...
I plug my amp directly into the wall. Everything else goes into my Monster 3500 conditioner. As far as I was aware, it's generally not recommended to plug an amp into a power strip / conditioner.Speakers: Polk LSi15
Okay but why did my APC SUA1500 work fine and not the Monster?
Everyone was telling me how a UPS designed for computers would not work well with audio gear, yet it sounds MUCH better than the Monster - 100%.
I kinda wish I had it back.polkaudio RT35 Bookshelves
Not sure. My 3500 provides good, clean power to my CD player and pre-amp, and have a very positive effect on them. But my amp requires too much juice for the Monster to handle. I don't have any experience with trying to use a computer UPS for an amp...Speakers: Polk LSi15
From what I have experienced, using a computer UPS with an amp works well. If the UPS continuously charges the battery and runs off the inverter, the power is cleaner. As long as the UPS is properly sized it should work fine.
However I am still upset that the Monster sounds so bad. I will return it.polkaudio RT35 Bookshelves
Monster "claims" their unit is rated up to 1800va, meanwhile your APC is rated up to 1500va. Must be their "cleaning" circuitry, it cleans the dynamics right out of your music.
You did use the high current jacks, correct?
Did you look at the Eaton conditioners that I posted?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Different design. I really like my APC. Subtle improvements and no downside. Again Rotel sources APC units for their power conditioners........same exact units and they charge more too.
Not saying the APC will work for everyone in every system, but it works for me....or rather it sort of stays out of the way, which is what you really want a conditioner to do.
Knowing APC design a little but not 100% so take this as a grain of salt.
UPS in general are switches which are placed in service on the fly. Being switches they bypass the DC inverter circuit until its needed, doing so they output what they have as input with in a voltage range. Range being over 90v to 130v or so, anything with in range is switched to output.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I'm returning the Monster and going back to APC. The sound was MUCH better with the APC.polkaudio RT35 Bookshelves
Found this over at AVS & thought it might apply. Easy to understand anyway. I think someone already hit on a neutral problem earlier in the thread. The poster is named offgasser inthe Tweaker section.
I am a lineman for the local power company. One thing you may want to consider with expensive electronics is a good ground connection. When the neutral connection provided by the power company fails, either at the meter box, transformer, or anywhere in between, you are subject to voltage problems. The reason is that the neutral balance the voltage between the two hot wires feeding your home. The transformer will give you 240v between these two wires, 120v per leg if the neautral is intact. If the neutral connection fails (and it does) the leg with the most demand on it will "hog the load' resulting in a higher voltage on that leg and a lower voltage on the other. Both of which can wreak havoc on electronics.
If you notice your lights dimming, getting brighter, or burning out frequently you may have a neutral problem. You should call your local power company and they will send someone to install a recording voltmeter at your home. This will tell them if you have a problem on their side of the meter and help them diagnose the problem. Believe me they would rather do this than replace your appliances and electronics.
The only defense you have is an alternate ground connection. This is accomplished in two ways. The first is by a water pipe ground, those of you who have your electric panel in the basement can probably see this connection, this takes advantage of the inherent low resistance of the water company's pipes. This has become less reliable with the more common use of non-metallic piping by the water companies. I have actually seen houses lose their lights when the water company cut the service pipes for maintenace. The other option is a driven ground (AKA ground rods). An electrician will drive ground rods at your home to provide an additional path for the electricity to go. This also helps to mitigate lightning damage.
One note, if you hire someone to drive rods ask them what resistance they are trying to achieve from the rods to ground (the lower the better). You can find out locally what is acceptable. Driving one rod and leaving will only cost you money. If they look confused find another electician.
No power conditioner can resolve this problem, and it is not uncommon trust me.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica
