New SDA top caps
Mike Reeter
Mike Reeter Posts: 4,315
edited June 2009 in DIY, Mods & Tweaks
When I recently picked up our pair of "perfect" 2.3 TL's,I discovered the tops were not soo "perfect"...No way to sand out the water ring being as the tops are veneered.
Well,after I got over being pissed off,I elected to have new caps made from solid Oak...After finishing and installing,I decided to do the same for a pair of 1C's (last pic)
I have always prefered the look of solid caps over veneer...
I can't take credit for making the new caps,but I did stain/finish and install them...This small tweek has given the SDA's a new look for sure.
Post edited by Mike Reeter on
  • madmax
    madmax Posts: 12,434
    edited November 2006
    Very nice! I have a 1c I need to do the same to. It has a water ring but not nearly as dark as yours was. I love oak, so easy to get and work with.
    madmax
    Vinyl, the final frontier...
  • Mike Reeter
    You know,after this little facelift,I think they sound better:D
  • Ricardo
    Ricardo Posts: 10,634
    They look absolutely beautiful.
    Don't forget to give those caps some brake in time :)
    SOPA
  • Mike Reeter
    Have had the day off from work,and have been braken' in the new caps most of the day!!!
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Beautiful job. I prefer the look of solid caps over veneer also.
  • amulford
    amulford Posts: 5,020
    Me also. You just can't get that cohesive grain pattern with veneer.
    Sweet look.
  • unc2701
    unc2701 Posts: 3,587
    How'd you get the old caps off?
    Backburner:Krell KAV-300i
    F1nut Posts: 51,962
    For future reference, the black ring or any black mark like that on wood can be easily removed without sanding it out, which won't work anyway. The black color comes from a reaction with the tannin (Tannic acid) in the wood usually caused by water or some other liquid. You start by stripping the finish off the wood, clean off the stripper residue with paint thinner, let dry and then apply generous amounts of Oxalic acid mixed with water. After it dries, you clean off the Oxalic acid residue by wiping with a clean wet cloth until all residue is gone. Be careful not to breath the fine white power as it will cause a massive sneezing fit. If one application doesn't do the trick, a second one will. Let the piece dry for a day or two, then lightly scuff sand with 220 grit serrated sandpaper to knock off the raised grain. Apply color and finish, rub out and you're done.
    A few reasons why veneer is a better choice than solid wood. With veneer there won't be any end grain exposed, the left and right edges of those tops show end grain. With veneer you can book match the grain for the tops, so that they look the same. It's very hard to do that with solid wood. MDF veneered pieces will not warp, crack or check like solid wood. Solid wood never stops moving, up to a 1/4" annually. That is to say, in dry months the wood shrinks, in times of high humidity the wood swells. Veneered MDF is inert, solid wood resonates and each piece will resonate differently.
    As I said, for future reference.....
  • DarqueKnight
    Exactly. Which is why Polk abandoned solid wood end caps for SDA's after the original SRS.
  • Mike Reeter
    On the larger SDA's the caps are bolted on,you have to remove the top mid-drivers to reach up into the cabinet to reach the taps that hold the tops in place.
    On the 1C's the caps are glued and stapled on,they are a little more difficult to remove,I used a construction adhesive to mount the replacements.
  • Mike Reeter
    The original caps had more problems than just the water ring,small scratches,dings,etc.
    I understand the concept of the wood vs. veneered mdf. It was less expensive to use all solid wood as opposed to buying an entire sheet of veneer.
    It was simply easier to come up with solid oak than it would have been to find the proper density mdf plus veneer.
    I had the cabinet shop install 3 biscuits in the glue joint in 21"...the joint itself will never come apart...with todays climate controlled living space,I'm not concerned about seperation
    F1nut Posts: 51,962
    I'm not trying to be a jerk about this, but just share some of my opinions and experiences from working with wood for longer than I care to remember. I see what works and what doesn't on a daily basis.
    The original tops could have been reveneered. A heat gun and a putty knife would remove the veneer in minutes allowing the original MDF to be reused. New sheets of PSA oak veneer are pretty cheap these days and come in sizes as small as 2' x 2' for about $12.00.
    Biscuits are one of the worst ways to join wood, a step above a butt joint because of the lack of surface area contact. Even with todays climate controlled living spaces, solid wood still moves. I'm not saying that yours are going to fall apart or whatever, just that there are better ways to do things for future reference.
    VR3 Posts: 29,539
    I gotta agree with F1 on this one ;)
    Biscuit joints seem to have as much point to them as toasting burnt bread...
    Other than that, I like the caps - look good...
  • Mike Reeter
    I should have known better than to trust the opinion of the Master Cabinet builder that put the caps together for me.
    F1nut Posts: 51,962
    Hey, what can say. There's done right and then there's done easy.
  • janmike
    janmike Posts: 6,146
    When in doubt ask the expert. They do look nice.
    Michael ;)
    NORTH of 60°
  • Deadof_knight
    Deadof_knight Posts: 980
    Mike ,
    The caps are the bomb and if your caps move up too a 1/4 inch annually hehe try a lil solid gold wood oil on them that'll keepem lubed up during the dry months....... They look sweet
    Real wood moves when not taken care and will move a great deal as will mdf and any veneer. its like taking care of anything else............
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
    F1nut Posts: 51,962
    DOF, before anyone takes your advice as something worth listening to, let me set the record straight.
    Oil will not stop solid wood from it's normal expansion and contraction. In fact, if a clear coat finish is used to seal the surface, oil can not penatrate the finish, period. MDF does not move and veneer will move a helluva lot less than solid wood, but it depends on what it's applied over. If applied over MDF or particleboard it will not move. If applied over solid wood, a layer of cross banding is used first, which counteracts the movement of the wood making any movement of the veneer layer all but a mute point.
  • Deadof_knight
    I completely respect what your saying F1, mdf and particle board does not warp in a nice environment. Yes if the wood is sealed off with something. you cant get the required oil back into the wood. I have oak asbsulutely everywhere in my home. My dining table my breakfast table. my entertainment center, kitchen cabinets, trim and doors and yes some of it is solid core and some is veneered throughout the house. My father retores antiques and such, items that have been well cared for in a house in a controlled environment still look wonderful. items that have been in someones storage or garage where the temperatures go up and down a great deal the wood shows it in warpage or separation. If he preps the wood well before install the new caps should provide years of service without warpage is all I was getting at. By then you can have another set made
  • unc2701
    OK, maybe I'm wrong on this, but I thought the rule of thumb for wood movement was <=1/16 per foot, perpendicular to the grain. So the dimension he's got to worry about is front-to-back, or about one foot... but the real problem distance is going to be the space between the bolts, which is more like 6-8 inches... so call it 1/32 of movement.
    So, you've got the two bolts that it's pressing against on each side, so as long as it can wiggle 1/64 at each bolt, he's fine. I'm not saying that MDF isn't the better choice, but I don't see a big issue here. If it were green wood, or the grain was going the other way, maybe.
  • univera
    univera Posts: 848
    You guys should no better than to argue with F1....:)
    He hasn't tooted his own horn, but I will. Jesse restores high end antiques for a living, so he's probably pretty well versed on doing things the best way. All he's attempting to do is let the next person know the ideal method, not knock Mike's caps. I thought is was interesting to find out that MDF was better than solid wood due to resonances. One would naturally think MDF is used to cut corners and costs and that solid ANYTHING would be better than pressboard. The caps look great in any regard. Enjoy!
    UNIVERA
    Historic Charleston SC
    2 Channel:
    SDA-SRS's RDO tweets
    Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
    Anthem Pre 2L w/E.harmonix platinum matched 6H23's
    CDP- NAD C 542
    HT setup:
    AVR: NAD T 773
    Rears: Polk LC80i
    DVD: Toshiba 3109 dual tray
    Subs: Velodyne and M&K
    T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
    Conditioner: Panamax M5100EX
    Master Bedroom Sony 40KDL-XBR3
    "I love it when a plan comes together." Hannibal Smith, The A-Team
  • schwarcw
    schwarcw Posts: 7,358
    Mike, what the guys say may be correct. But the caps look great! Enjoy those SDA's!:)
    Carl
  • amulford
    I like the way they turned out.
    But trust me, I WILL ALWAYS heed the advice of the f#ckin WOOD NINJA
    They don't get any better than him. No ****...
  • Deadof_knight
    edited December 2006
    I wasnt really arguing with him per say. Its more of a bunch of guys talking about things across a table. everyone has their nitch, and the deed is also already done from what I can see it was more of a pitcure of work completed. Not really a question as to what he should do ....its already done
  • Conradicles
    Conradicles Posts: 6,373
    edited June 2009
    This is a very informative post. Question for the WOOD NINJA:
    You said "Apply color and finish, rub out and you're done."
    Does that mean they can be stained black?
  • Ender
    Ender Posts: 603
    edited June 2009
    How about advice on anything to beware of while cutting or otherwise working with solid oak pieces? I am thinking of doing this same exact thing for my SRS 2. Any specific tools that I should use or is a circular saw, jigsaw, and router ok? Any specific finishes I should use? Any prepping of the wood before applying the finish and/or stain?
    SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
    Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
    GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
  • zarrdoss
    zarrdoss Posts: 2,562
    edited June 2009
    They look great!
  • Ender
    Ender Posts: 603
    edited June 2009
    Btw... I just tried removing the top drivers to get at the wooden caps... the driver won't come off!!! It's like that glued it on AND screwed it on!!! Anyone got any experience with this?
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited June 2009
    So did these things ever fall apart, or did the wood caps work?
  • Ender
    Ender Posts: 603
    edited June 2009
    Er... sorry, you can ignore me. I got it covered.
