So much for using Pioneer as a pre-amp ...
wizzy
wizzy Posts: 867
edited June 2009 in Electronics
Well, a while back I picked up a Bryston amp, and had it hooked up to my old H/K avi200-mkii as the pre-amp.
Thought I would hook up the Pioneer VSX-816 as a pre as it has a crossover, and could cut off the LSi9's at 80Hz. I figured surely it isn't that hard to be a pre-amp, right?
So got it hooked up to start (no crossover or anything set yet) and popped in a Pentangle CD. About fifteen seconds into the first track it turned into "WTF is this??" all the high end was gone, acoustic strings went flat and lifeless, just plain sucked. Checked settings on Pioneer, even reset it to factory defaults.
Listened a little more ... c'mon Pioneer, this thing sucks.
It's coming out and the H/K going back in.
To double check I connected the CD player (which has variable output levels) straight into amp and wham, there was the way it sounded when hooked up to the HK. So I know it wasn't that the HK was "adding something" there.
So much for having a crossover, but it ain't worth it if the music sounds like crap.
Post edited by wizzy on
  • nguyendot
    nguyendot Posts: 3,594
    edited June 2009
    That's not a very high end Pioneer.... what did you expect compared to your other proven gear?
    Main Surround -
  • Sherardp
    Sherardp Posts: 8,038
    edited June 2009
    Step your game up and go for a SC -05 or SC-07. Your thoughts would definitely change and that's before you even turn it on. :)
  • wizzy
    wizzy Posts: 867
    edited June 2009
    nguyendot wrote: »
    Guess I didn't think it was that hard to screw up a pre-amp.
    Taught me!
  • wizzy
    wizzy Posts: 867
    edited June 2009
    Kex wrote: »
    That seems very high to me. Others might not agree, but I would be trying 60 or lower for the LSi9.
    Well, if I had got past step #1 I would have probably played with that number :)
    I was thinking 80 as a start point as I've only got 200w/channel and the lower the frequencies, the more power needed.
  • wizzy
    wizzy Posts: 867
    edited June 2009
    Kex wrote: »
    My question is: how could it sound worse as a simple pre, with a good amplifier, than as a simple receiver without any help from an external amplifier?
    It never sounded good as a simple receiver actually. Well before getting the Bryston I did a side by side comparison with my HK-3480, using both as a stereo amp, and it couldn't hold a candle. Been through the setup menus numerous times, and also made sure I was in direct mode on it.
    My older HK AVI200 mkII sounds better than the HK 3480 even though it puts out less power.
    I think I should go get my Marantz receiver out of storage and see how it's 35w/channel do.
    W
  • michaeljhsda2
    michaeljhsda2 Posts: 2,200
    edited June 2009
    I used the VSX 816 as a preamp without any problems...not sure why you pre is not working.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • gdb
    gdb Posts: 6,012
    edited June 2009
    I guess I'm a little confused by your use of an AVR as a preamp. Do you use the AVR for both multichannel HT and 2ch. duty? I guess what I'm really asking is, why not use a regular preamp to send signal to your Bryston? Is there an advantage to using an AVR so that you can go from stereo/music to 5.1/7.1 HT? I'm just starting to look into HT and am trying to learn as much as I can, sorry if the questions seem stupid!:o:)
  • pearsall001
    pearsall001 Posts: 5,257
    edited June 2009
    gdb wrote: »
    It all depends on if you consider yourself a "Golden Ears" or not. A lot of guys will balk at the thought of using an AVR for both HT & as the preamp for there two channel listening. I've traveled both roads...separate pre for two channel & AVR for strictly HT, & just an AVR for both venues.
    My two separate pre's were a Conrad Johnson (tube) pre & a Krell SS pre. Both units sounded superb & really fit the bill nicely. My AVR is an NAD which is stellar in it's performance both for HT & used as the pre for my two channel listening.
    I spent a lot of time doing A/B listening comparisons & in the end the NAD AVR used as the two channel pre was just as compelling & satisfing as the CJ & Krell pre's. Now mind you, I haven't tried other stand alone pre's but for my situation & listening criteria, the NAD was the winner.
    Less rack space & $$$$ saved were an added bonus. Now, who knows, I just might get the itch to try another pre down the road, but for now both HT & two channel listening are just fine & dandy.
  • madmax
    madmax Posts: 12,434
    edited June 2009
    wizzy wrote: »
    Taught me!
    One of the most important pieces of equipment and VERY easy to mess up. ;)
    madmax
    Vinyl, the final frontier...
  • gdb
    gdb Posts: 6,012
    edited June 2009
    pearsall,
    That sounds like a good match-up and a well above average AVR! I've read that a lot/most AVRs don't produce a true stereo signal and that it's called "simulated stereo" but maybe that's old info! I doubt I'll ever have the funds for your level of equipment ! For simplicities sake I'm going to keep my HT gear and 2ch rig completely separate, at least it'll be simpler for me because I am easily confused by complicated electronic pieces like the AVRs and all their options! I'll just set my fronts right on top of my SRS2s, problem solved.:)
  • nguyendot
    edited June 2009
    Simulated stereo? Wouldn't that take more effort than simply passing two signals directly to the amplifier?
    I'm pretty sure AVR's do have 'real stereo'.
    Main Surround -
  • gdb
    gdb Posts: 6,012
    edited June 2009
    Probably, I've been reading the less than current stuff at my library. With ever changing technology, you really need the latest publications! I also think the materials I found there were mainly covering the low end of the spectrum regarding AVRs. I have used an older Pioneer that only had "simulated stereo", I don't remember the age or model, I just remember that it didn't sound too hot.
  • wizzy
    wizzy Posts: 867
    edited June 2009
    It works fine. It just sounds like crap when compared to either the HK AVR as a preamp, or compared to the CD player ran straight into the amp with no preamp.
    W
  • Marty913
    Marty913 Posts: 760
    edited June 2009
    wizzy wrote: »
    W
    I won't jump in the middle of an AVR versus dedicated preamp discussion but I did use a Pioneer 1018 for a couple of weeks as a preamp (with a Carver amp) and was definitely not impressed. Although I configured it pretty much every which way I could, it always sounded "hollow, thin, non-dynamic" when compared to my HK receiver (as a preamp) and my dedicated Outlaw 950. I returned the Pioneer.
    I think that's one of the reasons I haven't pulled the trigger on an SC yet; fear that the supposed "laid back sound" and "dynamics" will turn out to be like the 1018. Probably is not a valid concern as I'm sure they are completely different (maybe ?). Everybody's ears are different and I have not tried a Pioneer 816 but if it's like the 1018, I know exactly what you mean.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • mantis
    mantis Posts: 17,333
    edited June 2009
    wizzy wrote: »
    Wizzy,
    give me a run down of your system. I'm still trying to figure out why your buying a Pioneer vsx816 and not at least an Elite model.
    You own Lsi speakers and a Bryston amp, why not use something alittle in the class bro??? Your system design is at fault.
    I own Dynaudio speakers and used my Pioneer Elite sc-07 as a preamp. it actually sounded as good and in some ways better then my Rotel rsp1068 preamp. Then I removed my Rotel RMB1095 and ran the Sc-07 with the Dynaudio speaker package. This on paper is a complete miss match. The Sc-07 is rated to drive 6 to 16 ohms. But it runs the 4 ohm package better then I have expected. This is not a desired system for me as I'm completely revamping my system but as far as sound quality, Pioneer makes excellent preamps with receivers. I have been doing it in the field for years.
    I also don't think your system is properly setup. Connecting and going and making judgements on your system is not logical. You have to properly calibrate before and listening can be done. If you don't know how to calibrate, then I suggest you hire a professional. Where do you live??? I just so happen to be one.
    So post your system, room , cables etc and maybe we can get that system to sound it's best.
    Good luck man,
    Dan
    Dan
  • wizzy
    wizzy Posts: 867
    edited June 2009
    mantis wrote: »
    Wizzy,
    I'm not buying it, I had it laying around.
  • Face
    Face Posts: 14,340
    edited June 2009
    Synergy is a ****.
  • mantis
    edited June 2009
    Face wrote: »
    Synergy is a ****.
    Totally agree with you there Bro
    Dan
    Dan
