SDA SRS question, help please :)
SpeedyFE
Hi all!
On my SDA SRS speakers, hooked up properly with the inteconnect cable, the left speaker, all 4 tweeters are not working. I replaced one of the 4 with a working tweeter and still no dice. Any suggestions? Is there a fuse inside, or a x-over issue? Thanks! Also, everything on the right speaker is working perfect. Thanks
Paul
Paul
Post edited by SpeedyFE on
Las got it.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
so there is one poly switch for all 4 tweeters?
Is the polyswitch on the crossover?
Thanks guys... -
yep. yep.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
awesome, let me take it apart and let you guys know how it ends up! Thanks!
this may be a first, check it out....
Is it just me or does the E-0012-1 cap look disconected?
the leg is just broken off at the joint...it was just bouncing around when i took the x-over out!
i know it may be obvious, but would this make all 4 tweeters not work
like i said though, all woofers work along with the radiator... -
Well i think you found your problem? I woulder if this happened bringing them home.
Well the radiator works from the air preasure that the drivers produce. -
thats a good point, maybe from a bump or something....well now the is posed:
do i use this as an excuse to completly redo the x-overs
does anyone know where to find just that replacement cap if I decide to just do that one...
thanks -
Just solder a piece of wire in between, to join the two ends of the broken run. Quick and dirty fix for now and until you go for the complete upgrade.:)
thanks Las!! I may do that... I have to see how much it will cost though! You have done it?
gdb, i may do that just until i get enough for the complete upgrade, good idea. -
They are not TL. I will have the TL conversion up soon with detailed directions.Time to upgrade those crossovers.
Since you have them out!
Sal,
Call Sonic Craft http://www.soniccraft.com/ ; 501-620-4444, you will be speaking to Elliot.
Sonic Craft Generation 1 http://www.soniccraft.com/sonicaps.htm
"Sonic Capacitors Generation 1
Ask for Custom Matched & as close to 1% tolerance as possible:
Qty Rating
(6) 12uf (he was able to get the 1% tolerance for me)
(2) 0.25uf (he is going to have problems matching this and will probably get within 8% tolerance which is okay. On mine I bought Mundorfs for these two. they were much closer than the Sonicaps.
(2) 13.5uf (he could get 3% tolerance here for me)
(2) 27uf (2% tolerance for me on this one)
Mills Wirewound Resistors non-inductive http://www.soniccraft.com/mills_resistors.htm <http://www.soniccraft.com/mills_resistors.htm>
All should be rated 12 watt
Qty Rating
(2) 2.7 Ώ
(2) 7.5 Ώ
(2) 11.5 Ώ (you may have to settle for 11 ohms here)
(2) 15 Ώ
(2) 22.5 Ώ (if you can only get 22 ohms that is okay)
To summarize, you will be ordering 12 capacitors & 10 resistors
Mention that you were sent to their site by the Polk Forum and maybe you'll get a little discount!Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Better yet talk to Ben.
Nevermind he just posted. He is the guy to talk to SP.
yea, they are just SDA SRS
Those are not SDA SRS crossover boards. What tweeter model do you have?Political Correctness'.........defined
President of Club Polk -
Those speakers are the 1.2's with the SL2000's. The easy give away is the smaller caps, and the 20/40 shunts on the lows.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
as far as i know the speakers are all original....the serial tag says SDA SRS
pics:
Yep, those are 1.2's.Political Correctness'.........defined
but how can they be 1.2s when the back serial pad says just SDA SRS??
SRS just means signature reference series. The original srs's had the Blade blade IC and were 4ohms. These are Pin Blade 6ohms.
BTW I have a pair of those XO's on my desk getting the 1.2TL upgrade;)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
nice!
Ok so the original SRS and SRS 1.2 are visually the same? Except for the blade blade over blade post which i have...
Is one better to have over the other??
thanks -
But the cover plate looks like the srs version. Guess the plates could have been extras or just swaped out.
nice!
thanks
The 1.2, and 1.2TL use a simpler cancellation setup for the SDA part of the XO. The SRS used big caps to prevent canceling the lower bass frequencies where the 1.2's bled of the bass cancellation signal via a large inductor. If you have a Blade blade socket on that speaker it is setup like the pin blade socket. no difference but appearances there.
Ben
Edit: can you pull one of the outer and inner drivers, and see what models they are?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
nice!
thanks
Yes. -
yes, I have the blade pin socket...
Thats a good thing. It is easier to make an upgraded IC cable for them:)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
sounds good then, I guess a TL x-over upgrade and some tweets are in order once my wallet fattens up some time soon
