SDA SRS question, help please :)
SpeedyFE
SpeedyFE Posts: 143
edited December 2009 in Vintage Speakers
Hi all!
On my SDA SRS speakers, hooked up properly with the inteconnect cable, the left speaker, all 4 tweeters are not working. I replaced one of the 4 with a working tweeter and still no dice. Any suggestions? Is there a fuse inside, or a x-over issue? Thanks! Also, everything on the right speaker is working perfect. Thanks
Paul
Post edited by SpeedyFE on
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    Las got it.
    Ben
  • SpeedyFE
    SpeedyFE Posts: 143
    edited May 2009
    so there is one poly switch for all 4 tweeters?
    Is the polyswitch on the crossover?
    Thanks guys...
  • ben62670
    edited May 2009
    yep. yep.
    Ben
  • SpeedyFE
    SpeedyFE Posts: 143
    edited May 2009
    awesome, let me take it apart and let you guys know how it ends up! Thanks!
  • SpeedyFE
    SpeedyFE Posts: 143
    edited May 2009
    this may be a first, check it out....
    Toolfan66 Posts: 18,181
    edited May 2009
    Is it just me or does the E-0012-1 cap look disconected?
  • SpeedyFE
    SpeedyFE Posts: 143
    edited May 2009
    the leg is just broken off at the joint...it was just bouncing around when i took the x-over out!
  • SpeedyFE
    SpeedyFE Posts: 143
    edited May 2009
    i know it may be obvious, but would this make all 4 tweeters not work ;)
    like i said though, all woofers work along with the radiator...
    edited May 2009
    Well i think you found your problem? I woulder if this happened bringing them home.
    edited May 2009
    SpeedyFE wrote: »
    Well the radiator works from the air preasure that the drivers produce.
  • SpeedyFE
    SpeedyFE Posts: 143
    edited May 2009
    thats a good point, maybe from a bump or something....well now the is posed:
    do i use this as an excuse to completly redo the x-overs ;)
    does anyone know where to find just that replacement cap if I decide to just do that one...
    thanks
  • gdb
    gdb Posts: 6,012
    edited May 2009
    Just solder a piece of wire in between, to join the two ends of the broken run. Quick and dirty fix for now and until you go for the complete upgrade.:)
  • SpeedyFE
    SpeedyFE Posts: 143
    edited May 2009
    thanks Las!! I may do that... I have to see how much it will cost though! You have done it?
    gdb, i may do that just until i get enough for the complete upgrade, good idea.
  • ben62670
    edited May 2009
    They are not TL. I will have the TL conversion up soon with detailed directions.
    Lasareath wrote: »
    Time to upgrade those crossovers.
    Since you have them out!
    Sal,
    Call Sonic Craft http://www.soniccraft.com/ ; 501-620-4444, you will be speaking to Elliot.
    Sonic Craft Generation 1 http://www.soniccraft.com/sonicaps.htm
    "Sonic Capacitors Generation 1”
    Ask for Custom Matched & as close to 1% tolerance as possible:
    Qty Rating
    (6) 12uf (he was able to get the 1% tolerance for me)
    (2) 0.25uf (he is going to have problems matching this and will probably get within 8% tolerance which is okay. On mine I bought Mundorfs for these two. they were much closer than the Sonicaps.
    (2) 13.5uf (he could get 3% tolerance here for me)
    (2) 27uf (2% tolerance for me on this one)
    Mills Wirewound Resistors – non-inductive http://www.soniccraft.com/mills_resistors.htm <http://www.soniccraft.com/mills_resistors.htm&gt;
    All should be rated 12 watt
    Qty Rating
    (2) 2.7 Ώ
    (2) 7.5 Ώ
    (2) 11.5 Ώ (you may have to settle for 11 ohms here)
    (2) 15 Ώ
    (2) 22.5 Ώ (if you can only get 22 ohms that is okay)
    To summarize, you will be ordering 12 capacitors & 10 resistors
    Mention that you were sent to their site by the Polk Forum and maybe you'll get a little discount!
    Ben
    edited May 2009
    Better yet talk to Ben.
    edited May 2009
    Nevermind he just posted. He is the guy to talk to SP.
  • SpeedyFE
    SpeedyFE Posts: 143
    edited May 2009
    yea, they are just SDA SRS
    F1nut Posts: 52,000
    edited May 2009
    Those are not SDA SRS crossover boards. What tweeter model do you have?
  • ben62670
    edited May 2009
    Those speakers are the 1.2's with the SL2000's. The easy give away is the smaller caps, and the 20/40 shunts on the lows.
    Ben
  • SpeedyFE
    SpeedyFE Posts: 143
    edited May 2009
    as far as i know the speakers are all original....the serial tag says SDA SRS
    pics:
    F1nut Posts: 52,000
    edited May 2009
    Yep, those are 1.2's.
  • SpeedyFE
    SpeedyFE Posts: 143
    edited May 2009
    but how can they be 1.2s when the back serial pad says just SDA SRS??
  • ben62670
    edited May 2009
    SRS just means signature reference series. The original srs's had the Blade blade IC and were 4ohms. These are Pin Blade 6ohms.
    BTW I have a pair of those XO's on my desk getting the 1.2TL upgrade;)
    Ben
  • SpeedyFE
    SpeedyFE Posts: 143
    edited May 2009
    nice!
    Ok so the original SRS and SRS 1.2 are visually the same? Except for the blade blade over blade post which i have...
    Is one better to have over the other??
    thanks
    edited May 2009
    But the cover plate looks like the srs version. Guess the plates could have been extras or just swaped out.
  • ben62670
    edited May 2009
    SpeedyFE wrote: »
    nice!
    thanks
    The 1.2, and 1.2TL use a simpler cancellation setup for the SDA part of the XO. The SRS used big caps to prevent canceling the lower bass frequencies where the 1.2's bled of the bass cancellation signal via a large inductor. If you have a Blade blade socket on that speaker it is setup like the pin blade socket. no difference but appearances there.
    Ben
    Edit: can you pull one of the outer and inner drivers, and see what models they are?
    Ben
    edited May 2009
    SpeedyFE wrote: »
    nice!
    thanks
    Yes.
  • SpeedyFE
    SpeedyFE Posts: 143
    edited May 2009
    yes, I have the blade pin socket...
  • ben62670
    edited May 2009
    SpeedyFE wrote: »
    Thats a good thing. It is easier to make an upgraded IC cable for them:)
    Ben
  • SpeedyFE
    SpeedyFE Posts: 143
    edited May 2009
    sounds good then, I guess a TL x-over upgrade and some tweets are in order once my wallet fattens up some time soon :D
