Spearker cables..fact or fiction?
1…4647495152…71
  • bikezappa
    bikezappa Posts: 2,463
    edited May 2009
    One other point, the people who charge you money for the experience of walking on rocks are liars because they never tell you that they have heated up special low density rocks.
    There are people in the world like this, be skeptical, and don't buy all the bull ****.
  • ahardy17
    ahardy17 Posts: 84
    edited May 2009
    bikezappa wrote: »
    thanks bikezappa i'm still in bed and already i learned something!
    In-Car:
    Head Unit: Sony MEX-1GP
    Door speakers: Infinity Kappa 680.9cs
    Rear speakers: Polk db690
    Subwoofers: Memphis Audio 15-M3124
    Amps: Pioneer GM5300T, Kenwood KAC 6020, Memphis Audio MCD1.1100
    In-Home:
    Harmon/Kardon AVR 230
    Harmon/Kardon DVD 101
    Yamaha RX-V995
    Bose 161
    Bose 901
    Polk FXi30
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    You are wrong one time in a thousand shots.
    I have learned a lot from my sisters and brothers here. I will say that I have been proven wrong more than one time in a thousand;) Use your ears:)
    Ben
    F1nut Posts: 52,400
    edited May 2009
    The ablity to walk on hot stones in based on the low thermal conductivity and heat capacity of the rocks. The rocks used during these experiments are volcanic and they have a very low heat capacity and thermal conductivity. Not all rocks have the same properties.
    Interesting and makes sense. I've never seen it live, so I wasn't aware that they used rocks. I always thought they walked on the actual hot coals.
    Of course, this has no bearing on blind tests being useless. :D
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited May 2009
    It is however related to the same emotional faith the cable manufacturers are creating to sell their so called high end cables ;)
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2009
    TECHNOKID wrote: »
    In my heart and soul there is faith. When it comes to my ears there is no faith but accuracy. My MIT ICs and Speaker cables blow any other IC or speaker cable that I've heard away.
    Have you tried any "so called" high end cables in your rig. If not your opinions are worthless; if so then would you share with us your findings and results please?
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited May 2009
    TECHNOKID wrote: »
    A simple measurement of the temperature of the rock isn't sufficient if one is contemplating walking on the rock.
    " 800 degrees ! No way ! ".
    Yes way.
    You need to measure the density, porosity, and determine the rate at which those rocks can transfer heat to determine if it is safe to walk on a "Hot" rock.
    As Bikezappa correctly pointed out, the ability of those porous rocks to transfer heat is very, very low.
    The rocks themselves are really "hot", but they contain little heat and what heat they have is transferred to the bare foot verrrrrrry slowly.
    The same is true of cables; ohms may be the same as copper wire, inductance/capacitance differences may be negligible, but ..... they sound different.
    Perhaps one provides a noticeable, if not measureable, damping factor. Or ..... ?
    Who knows if there is a measurable factor that causes what is, seemingly, noticeable.
    That may be something to look into. Instead of thinking, "Well, I can't measure a difference, therefore there can't be one !", perhaps you might come up with a means for determining what causes this difference.
  • Hillbilly61
    Hillbilly61 Posts: 702
    edited May 2009
    Kind of the same principle behind how the space shuttle tiles work. The heat is not well transferred to the item in contact, but held within. Going back to the theme of blind tests posted earlier go fire up some good ole Kingsford charcoal, blindfold the fire walker and ask him or her to go for a stoll....
    I very much believe in blind tests, particularly concerning those things that are not well measured, but people sense differently. While this is an audio forum and while many a war is waged here concerning things heard, scents are among the most difficult to measure senses we possess.
    F1nut Posts: 52,400
    edited May 2009
    TECHNOKID wrote: »
    Emotional faith created by cable manufacturers? Where did you come up with that one?
    Anyway......
    I don't need a blind test to tell me that what I hear is what I hear. For example, I've had a $2000+ power cable on loan from the manufacturer. This pc is 4 times the cost of my current reference pc and I had hope it would take my system to a higher level. However, I trust my ears and they told me that my current pc sounds better.
    Blind tests are for amateurs and cowards.
  • Hillbilly61
    edited May 2009
    Read my post above. You are hearing something that is not easy to measure.
  • Legion5
    Legion5 Posts: 14
    edited May 2009
    The way that blind tests are conducted is incorrect is the point. You're trying to determine if the human is sensitive enough as a measuring instrument to detect the differences between two sets of music on different pieces of equipment. What Jess is saying which is backed up by psychological science is that humans are numb to the differences between two similar sounds and won't start to notice the differences until they hear one or the other for hours on end.
    This is a proven system of the human mind designed to aid in hearing faint sounds and to stop people from going crazy from aural over stimulation.
    They did a test once where they changed the whole BEAT of a song and played the two different beats with the same lyrics to people. The result was that on average humans could not tell the difference uppon the first hearing of a song with a different beat and the same lyrics. I know this because I'm a DJ that remixes songs and people tell me all the time that they've heard my music on the radio, that's what I found when I investigated.
    You need to hear a song multiple times before you can detect a difference in beat, that's why we like new songs often but after listening to them more we think they're crap.
    Humans are so incredibly ridiculously numb to sound that they actually hear faint sounds and then think it's their cell phone or some one calling their name. Something completely different from the actual sound ie a microwave.
    Does this mean that all sound is the exact same and that the beat of music is all the same?
    Does this mean we should replace our voiceboxes with microwaves because people can't tell the difference.
    Think about it.
    The correct way is to do a blind test is over multiple weeks with music experts and see if you can conclusively prove that one piece of equipment is better than another. ie if the majority of experts say one thing is better then it is, if no conclusion is reached under those circumstances then and only then is it legitimate.
  • ahardy17
    ahardy17 Posts: 84
    edited May 2009
    Legion5 wrote: »
    so true! my phone talks and says who i'm getting a message from and i constantly think i hear it saying "message from _____" then i check it and there's nothing there.
    anyway...this thread is getting a little silly...i know people are making relevant points but the porosity of rocks has nothing to do with the quality of speaker cables :rolleyes: no one will win this argument or talk any sense into the people opposing their opinions...
    In-Car:
    In-Home:
    Yamaha RX-V995
    Bose 161
    Bose 901
    Polk FXi30
    F1nut Posts: 52,400
    edited May 2009
    Thanks for your words of wisdom, although it's something most of us have known from the first post.
    edited May 2009
    Ain't that the truth.Sometimes I wonder if these stupid arguements are started by guys from other forums.Regardless,these types of threads are pretty worthless in my book.
  • sucks2beme
    sucks2beme Posts: 5,702
    edited May 2009
    I'm sure there's some site crossover. Some of the cable/equipment
    debates over at head-fi are completely braindead. I guess using a
    low bitrate I-pod as a source to gauge equipment performance yields
    some very strange results. And there's a very vocal group of flat-earthers
    over there. Amp design,cables, sources are all snakeoil to them. There's
    really no limit to how far to take it. Whatever. I enjoy my upgrade path,
    and if that's not what they want, to heck with it. Somebody really enjoys
    food from Micky D's ,too.
    edited May 2009
    Keiko wrote: »
    I feel a Big Mac attack coming on. With a vanilla shake and a hot apple PIE!
    Sorry Keiko,
    Beat you to it. Just had one!
    cnh
  • sucks2beme
    edited May 2009
    Keiko wrote: »
    Other than breakfast, they don't have anything I'd eat. The new
    "Healthier" Fries taste horrible. Why would anyone try to make fries
    healthy anyhow? It's kinda like alcohol free beer. What's the point?
  • lightman1
    lightman1 Posts: 10,801
    edited May 2009
    Did somebody say.....pie?
    I'm off probation............uhhhh-ohhhhh!!!!!
  • Lord Vader
    Lord Vader Posts: 167
    edited May 2009
    tonyb wrote: »
    If this thread is so worthless, why does everyone continue to defile themselves by posting here. I agree this thread is a waste of forum bandwidth. Let this thread die as the Emporer has forseen.
  • Hillbilly61
    edited May 2009
    sucks2beme wrote: »
    The new
    Crap. They ruined the fries too???! :eek: That was the only thing that I thought they were superlative at producing.
  • LBrize
    LBrize Posts: 58
    edited May 2009
    Here's my addition to this lovely thread, having something to do about blind tests.
    I, for one, strongly believe that I can hear a difference in speaker wires.
    Also, I know I can hear a difference in electronics, to the point of differences in CD players.
    I also do not subscribe to the notion that we have short-term audio memory. I believe that we can remember how things sound, even details like timbre and harshness, and accuracy. (You can think right now and hear your mother's voice in your head, right? Does it sound the same in your mind as one of your female co-workers?--That's remembering the way something sounds, right?)
    So, blind tests? Sure there's a difference...if something sounds different, why wouldn't you be able to hear it???
    There's my two pennies.
  • kevhed72
    kevhed72 Posts: 5,223
    edited May 2009
    This subject is so devisive, I am going to try out a "wireless" system. What could be more transparent than no wires at all?
    Also, I thought the hot coal walking had to do with the layer of ash on top which acted as a insulator...
  • seafire
    seafire Posts: 459
    edited May 2009
    Lord Vader wrote: »
    Hello dickhead!
    Same **** another month gone.Point made??:cool:
  • seafire
    seafire Posts: 459
    edited May 2009
    LBrize wrote: »
    Interesting
    You STRONGLY BELIEVE you can hear a difference in speaker cable.
    You KNOW THAT YOU CAN HEAR A DIFFERENCE IN CD PLAYERS
    You have just answered yourself as Cd players involve source that is critical.
    Speaker cables 90% of the time are in your mind!!!!! :rolleyes: yawwwwwn
  • seafire
    seafire Posts: 459
    edited May 2009
    This thread is amazing. It has now morphed again ... into a positive and meaningful audio discussion. 'goes to show that if trolls are ignored long enough, they will go away!
    your **** on toast:cool:
  • seafire
    seafire Posts: 459
    edited May 2009
    Keiko wrote: »
    Reported
    REPORT YOURSELF YOU SPINELESS PIECE OF SH........:cool:
  • hearingimpared
    edited May 2009
    seafire wrote: »
    Interesting
    reported
  • hearingimpared
    edited May 2009
    seafire wrote: »
    reported
  • lightman1
    edited May 2009
    OOOOOOHH SHIIIIIIIT!!!!! Close the ears, Mods!
  • seafire
    seafire Posts: 459
    edited May 2009
    Hey KAKO (KAK MEANING ****) go and check on your buddy's language use on this site.Reported awwwww GIVE YOURSELF A BREAK DICKHEAD ;););)
