Denon DP-37F turntable
haimoc
I bought this turntable in excelent condition (except the dust cover). Everything works fine so far. Does anyone know where I can buy a dust cover that fits this turntable. Do newer Denon head shell and cartridges work with this turntable? Any MOD recommendation? I also need to find a manual, too.
Thanks for your input.
Post edited by haimoc on
the easy way would be to get one that fits over the entire turntable.
http://www.jmkdisplays.com/turntablecovers.html
you can also check this out.
http://tampabay.kijiji.com/c-For-sale-Electronics-NEW-CLEAR-ACRYLIC-PRECISE-FIT-VINTAGE-TURNTABLE-DUST-COVER-W0QQAdIdZ107183787Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Congrats on the New turntable.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Thanks... This is more like a new vintage turntable. It is hard to find parts for it. I want to try Denon DL-160 cart on it, later. -
Check on the Vinyl Engine forums. Somebody there might know.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Measure it and shoot me a PM. I have a dustcover from an Audio-Technica table that may fit it. It has a small crack on the back, but shouldn't affect it for what you need it to do. If the dimensions are correct I'll give it to you. Just cover the shipping.
Regards,
Mike
Thanks, Mike.
The Denon dust cover dimension is 16.75 x 13.75 x 2.5". -
Thanks, Mike. PM returned with Verlalab woodblocks offered in return.
This turntable sounds very very good so far. I'd like this turntable auto features.. Load a record, press the PLAY button, and bingo... The turntable locks the speed, moves to arm/cartridge to the record, and plays. It will lift off the arm off the record at the end, too.. Very beautiful sounds..
Does anyone know if newer Denon headshell would fit this turntable?
Thanks. -
haimoc, I'm not familiar with that type of tonearm and headshell design. You could contact Denon and ask them. I have a Denon DL-160 MC cartridge on my Technics and it sounds fantastic. Here's a contact link for Denon.
http://www.usa.denon.com/ContactUs.asp
When things open up for business here today, I'll be looking for stuff for this dustcover and will be in touch with you.
Good luck and enjoy that table. She's a beaut!
Thanks... Just send an inquiry to Denon... Hopefully, new Denon headshells would work with this turntable.. I read many great reviews on Denon DL-160
and want to have it for this vintage turntable, too...
