New JVC RS10 Projector on the Way
  • millerman 3732
    millerman 3732 Posts: 1,488
    edited May 2009
    Sherardp wrote: »
    Couple screen caps from Bolt.
    Have you calibrated it yet? It looks like your losing a lot of detail in the darker areas, it could just be your camera though.
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Toshiba HD-XA2 (HD-DVD, CD)
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi 10 (bi-amped)
    Polk CSi5 (bi-amped)
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
    TV Rig: Samsung 50'' 4k display
    Polk Signa-1 Surround bar
  • 66chevyIISS
    66chevyIISS Posts: 857
    edited May 2009
    Thats just sick....
    What rear speaker mounts are you using on your RTI's? are you able to angle them at all?
    My Home Theater (WIP):
    Panasonic AE900 Projector - 126" screen, XBOX 360, Pioneer BDP-320 Bluray
    Receiver: Denon AVR-1905
    Fronts: RTi6's, Center: CSi5, Surrounds: RTi4, Rears: Denon
    Dual Subs: PSW202, and behind the couch Denon 8"
    My showcase link:
    Media Room pics
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2009
    The projector is calibrated so its the camera, the projector performs very well and the image is great. The rear speakers are B-tech 77 and yes I am able to aim them vertical/horizontal. The projector throws a sick image.
  • Grimster74
    Grimster74 Posts: 2,577
    edited May 2009
    I'm hoping to get some new pics of my current setup this weekend, haven't really had the time to really enjoy my new JVC projector but looking forward to getting up some new pics in my showcase. Sherard has a kick **** H/T room.
  • VinnyDaFish
    VinnyDaFish Posts: 13
    edited May 2009
    Does everyone recommend using a professional color calibration on these units or do most folks just run with it out of the box with just some manual fine tuning? Any thoughts on how the RS10 compares to the Sony VW60?
    AVR - Denon 3808CI 7.1
    Mains - Polk Audio RTi12's
    Center - Polk Audio CSi5
    Surrounds - Polk Audio OWM3's
    Rear - Polk Audio OWM3's
    Sub - Klipsch Sub 12
    Amp - Adcom GFA-5500
    Bluray - 80GB PS3
    Display - JVC DLA-RS10 1080p
  • Sherardp
    edited May 2009
    You can use DVE to put you in the ballpark area of a calibrated image. I used the DVE with the HD1 Rob has and the image was very good. I played with the settings on the RS10 and out of box the colors were off. The calibrated image adds more pop, excellent shadow detail.
    JVCs over the Sony anyday, so consider a used HD/RS1, the Pio PFJ1 and of course the RS10. All of these are under 3k, with the RS10 just there around 3600-3700. No dynamic iris with the JVCs so you get great blacks which is where the JVC's really shine. I've seen the new Sony VW80, not sold in US and it is also very good , but the RS10 still does a better job. Take a look at one for yourself and decide. All the new PJs are rather close in performance anyway, but if the budget allows shoot for the JVC's.
  • VinnyDaFish
    edited May 2009
    Ordered the RS10 and it should arrive later this week (before I'll have time to start putting everything together. Ugh)
    I have a fairly tall ceiling in the screening room and would prefer to not have the projector hanging down five or six feet on the mount. My understanding is that the projector is fairly flexible with the projection angels, is that true? Any other mounting or start up issues to be aware of in advance?
    Bluray - 80GB PS3
  • Sherardp
    edited May 2009
    Congrats Vinny, youre in for a treat. I would mount the projector on shelf if you dont want to ceiling mount. The RS10 does have keystone correction but understand you lose some PQ using keystone and it is normally advised not to use it. The projector has plenty horizontal/vertical lens shift so you're good there. How big a screen did you go with?
  • VinnyDaFish
    edited May 2009
    It's a 105 inch screen. We just moved into a new house and the prior owner had the screen (and sub-optimal setup), but figured I would invest the money in new equipment and then redo the screen and room configuration in the future. UPS is telling me the RS10 should arrive on Friday, but I probably won't have time to properly install it until the following Saturday. In the meantime, I'll just leave it on a counter in the back of the room and lock the kids out.
    Really, really, really have to find the time to get the room up to speed so I can start enjoying the new projector. Anything you wished you had known when setting it up -- any funny tricks, features, problems?
    Bluray - 80GB PS3
  • Sherardp
    edited May 2009
    None really, my projector was calibrated so I can't really say much, if you want I can share my settings and you can make adjustments there and see what you like. OoTB I didnt like the preset colors, but once I adjusted Custom Gamma curve and calibrated colors the PQ is very nice.
    If you're going to ceiling mount, suggest you get with ProjectorPeople and buy the Chief Mount RPA-U model, they also carry the ceiling mount and down pipe if needed.
  • 66chevyIISS
    edited May 2009
    Sherardp wrote: »
    Thanks! Those are some pricey mounts, but they look solid. My current ones aren't going to hold my RTi4's when I move them to the rear. Anyone else sell them besides Crutchfield and Polk? looks like Polk is the cheapest at $59.99.
    My showcase link:
    Media Room pics
  • slowpolky
    slowpolky Posts: 714
    edited May 2009
    I want an rs10 , but wifey thinks my panasonic 200 is good enough
  • Sherardp
    edited May 2009
    If the JVC is out of your price range, look at the new Panny 3000 or new Epsons.
  • VinnyDaFish
    edited May 2009
    Watched parts of a couple of blu-ray movies and the projector in 1080p looks fantastic. Did a quick test with a 1080i Dish Network broadcast of the NBA Playoffs on TNT and ABC as well as part of a movie (TBS HD I believe) and I wasn't thrilled with the look coming from the satellite. Anyone have any experience with broadcast signals and tweaking the picture quality on the RS10 for sports, shows, etc from Dish or other? I've got to figure out if there is a way to save a setting for Blu-ray and another for better broadcast tv.
    I think the Dalite screen that was installed by the previous owner of our house is a weak point in the PQ right now, but I may have to live with it for a time until I can revamp the room and move from a 105" to 120" screen.
    I'm planning to mount the RS10 to the ceiling this weekend (as well as run some new speaker cables through the ceiling / walls). Can't wait to get everything buttoned up so I can get down to business.
    Bluray - 80GB PS3
  • Sherardp
    edited May 2009
    I use User one for BD ( pro calibration) and I use dynamic for gaming, etc. You need to calibrate that unit for it to really shine. You'll definitely get better imaging, pm me ya email address and I will take snap shots of my settings and send it. Out.
  • Serendipity
    Serendipity Posts: 6,975
    edited May 2009
    Sherardp wrote: »
    The Epson 1080UB is a solid performer too.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • mantis
    mantis Posts: 17,363
    edited May 2009
    I would love to come over and give that bad boy a ISF calibration. But I would have to fly to Japan, eat mad sushi , maybe check out all the cool spots ,hit the audio shops, go shopping , check out all the local hotties, then hit the crib for the Calibration.
    It would be fun.
    O and then I would have to setup the audio system. Calibrate that as well.
    So when should I expect my plane tickets?
    Dan
    Dan
  • Sherardp
    edited May 2009
    mantis wrote: »
    It would be fun.
    Dan
    Everything calibrating over here already, had the projector calibrated at AVS, sure you could probably tweak my auduo setup a tad more outside of MCACC and my SPL meter. You can crash here but you have to pay your own route. Food, hotties, bars, drinks, all on me. Come on out.
  • Grimster74
    edited May 2009
    mantis wrote: »
    It would be fun.
    Dan
    I'm not too far from PA Dan, I have Sherards old HD1 that your more than welcome to come by and ISF calibrate. I have no problem throwing you up for the night and filling you full of beer and food.:D So if your every in the area, hit me up sometime.
    Rob
  • mantis
    edited May 2009
    Sherardp wrote: »
    I gotta plan a trip to Japan.
    Dan
    Dan
  • mantis
    edited May 2009
    Grimster74 wrote: »
    Rob
    Will do , Isn't there a famous beach down there?
    Dan
    Dan
  • Serendipity
    edited May 2009
    Grimster74 wrote: »
    Rob
    Isn't Sherard's old HD1 already calibrated? The only differences I can think of are screen and room, so it shouldn't require much more than adjustments to color temp. to match the screen??
  • Sherardp
    edited May 2009
    appadv wrote: »
    Yeah PJ was calibrated by local Japanese video shop, then other tweaks by myself using DVE software. Not much left to do with it, perhaps color temp as mentioned. That HD1 is a beast though, I liked it allot.
    Hey Dan you should take Rob up on that offer man, not far at all. I go through there and visit after going to McConnellsburg PA for meetings. Dude can really grill and his family is awesome. That HT room is very sweet. Hence the ideas for my own room.
  • Serendipity
    edited May 2009
    Great, I know these JVC's look great but when calibrated they are even better.
  • Sherardp
    edited May 2009
    appadv wrote: »
    I think you should own one also.
  • Serendipity
    edited May 2009
    Haha, I'm on a budget and the Epson is pretty good so far.
