Do larger speakers sound better ?
I have tsi100's am currently using for my front speakers till i can afford to to get monitor 60 but what im wondering is will they actually sound better then the tsi100's i have or just more powerful ? I listen to alot of music and some movies too with these so sound quality is important to me. Might be a stupid question but it's been buggin me for awhile
TV- Samsung 24" LCD T240HD
5.1 Receiver - Harman/Kardon AVR 247
Stereo Receiver - Harman/Kardon 3390
Front - Monitor 60
Center - Cs10
Surround - Tsi100
Sub - SVS PB10-NSD
Playstation 3
Front - Monitor 60
Center - Cs10
Surround - Tsi100
Sub - SVS PB10-NSD
Playstation 3
Post edited by Dan2036 on
I am going to jump in and say yes. But somethings might hinder the sound quality with larger speakers.
1- The size of your room your putting them in.
2- How you are powering them.
3- and i just learned this. Room Treatments.
Some others might chime in with other ideas, But these are a few that i have learned in the last few months.
Larry. -
Pretty modestly powered i believe 50 watts per channel, and medium to small sized room if that helps at allTV- Samsung 24" LCD T240HD
Front - Monitor 60
Center - Cs10
Surround - Tsi100
Sub - SVS PB10-NSD
Playstation 3 -
for what its worth my R50's sound a lot better than anything Ive had before regardless of size.:DPolk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
It just depends on the size of the room and what kind of furniture is in the room.
it`s not the size of your speaker....
...it`s how ya use it
and work the walls (with treatments)
get yer mind outta the gutter
or not !Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Larger speakers are more generally more dynamic."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
First, you have to define what "better" means to you. Bigger speakers tend to sound fuller and more dynamic, but small speakers, imo, usually image better; they better reproduce three-dimensional images outside the confines of the speaker enclosure. Images tend to float free of the speakers. But you can, to an extent, have the best of both worlds if you really try! Some bigger speakers do image well, and some small speakers can sound very dynamic and full when mated with good subs and set up properly.THE MAN-CAVE 5.1 CHANNEL A/V RIG
Sony KDS-60A3000
a/d/s/ HT-400LCR (3)
a/d/s/ HT-300 (2)
Velodyne DLS-4000R (2)
Pioneer Elite VSX-55TXi
Pioneer Elite DV-47Ai
Sony BDP-S300
Sony SLV-779HF
DirecTV HD sat. receiver
MAN-CAVE 2-CHANNEL RIG (shares sources with a/v system)
Adcom GFA-5500
Bose 901 Series VI
NAD C-165BEE
Slim Devices Squeezebox Classic
TEAC CD-RW890
Technics SL-BD20D w/ Audio-Technica P34
Akai HX-A3X -
An unanswereable question, I'm afraid.
large speakers+high wattage amps+big room=sound better as a general rule. Of course a lot depends on the type of each componant in the equasion.
Since I have SDA 1Cs I will say yes but there are a lot of factors as stated above.Speakers: SDA-1C (most all the goodies)
Large tower speakers tend to have more coloration from the large cabinets not being properly brace. Most manufacturers don't do this right do to weight and cost. That being said I'll take a floorstander over a bookshelf 9/10 times.
Ok well basically what im asking is for a medium sized room for a person that cares about music and a little bit of movies which speaker would be the better fit with the better sound, Tsi100 or the Monitor 60 ?TV- Samsung 24" LCD T240HD
Front - Monitor 60
Center - Cs10
Surround - Tsi100
Sub - SVS PB10-NSD
Playstation 3 -
Larger speakers don't mean better sound or more dynamic range. Actually most smaller speakers sound more dynamic and cleaner then larger speakers. I will explain.
In most lines , they go from a small bookshelf speaker to a large floor standing speaker. Most of the time the larger speaker sounds better and fuller as some said above, but this is not always the case and the room you plan on using them in really dictates what speakers you should use. Forget about what you want and think of the room. The room is the single most important thing to picking any part of the system. Mess this up and the system does not function correctly.
Small speakers when crossed over correctly sound better then a lot of floor speakers as most of the time people try to send a full range signal to them that they have no business playing. You lose Frequencies and this is a huge problem when trying to calibrate. I will hardly never set a pair of speakers in "large" due to the facts hardly no speaker can actually play full range. Did you know that taking away low end actually makes most speakers sound better??? Using the sub to run the bottom end and blending correctly is key. Using multi subs work better then buying larger speakers.
DanDan
When talking about boxes I'll take a 2 way monitor over a floorstander every time. It all depends on what you like. Bigger speakers will have more punch, but for my ears monitors present a more coherent sound._________________________________________________
I've only owned bookshelves. I recall reading once that monitors will image better than large floorstanders, but I'm not sure if that's true or not. I'm very happy with what I have though.
thats not true at all. But one could thing they have better detail due to not playing all the audio range.
DanDan
Dan
Could this be why some of my poorly SQ CD's sound better on my RT55i's then on the A9's or SDA's?
Larry. -
Anybody who tells you little box speakers sound better than full range speakers is just trying to impress you with some unfounded snob look at me I am so wise audio speak/talk.
RT1 -
Monitors paired with dual subs will kick the living daylights out of a pair of floorstanders everyday of the week...and twice on Sunday's.
Monitors/subs rule baby!!!!
If you don't have the full audio range, why bother? You are missing half the music. Most specifically, the part that completes the sound stage that envelops you and puts you IN the venue........better detail due to not playing all the audio range.
At least that's my stance and I will not waiver. IMO, you can not omit frequencies and expect to have accurate reproduction of the music. You are only leaving out the frequencies that are among those that in my experience, the hardest to properly reproduce and integrate into the system. A properly done system IMO will have all of the frequencies accurately reproduced and equal [at all volume settings]. Getting a system that will do that? Well, that can be a challenge but that's half the fun isn't it?
Having gone from floorstanders to a bookshelf set-up, I can tell you that there is a difference. I got rid of my florrstanding set-up because the wife was afraid of the kids pulling them over and hurting themselves. I can honestly say sice then I have gone through 4 different bookshelf set-ups. There seems to be a very wide assortment of bookshelf set-ups and I think having that type of set-up causes you to fine tune moreso to get the most out of your system. Admittedly, I have a pretty small room so this works for me. For a larger, more open room, bookshelves may never be the answer.
Don't get me wrong, the set-up I have now sounds great to me and leaves me extremely satisfied, but the bass response, especially the action scenes, seemed to have had more "ooomph" when I had the floorstanders. I can't say that the previous set-uop sounded better; just different. I am thinking about the possibility of running dual subs to see how that would work.
ShawnShawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
A pair of speakers that give you 40 Hz and up will cover 99% of all instruments and vocals. A well blended sub can provide that missing 1% perfectly well. And I agree, that 1% does make a difference in the overall presentation. (Ok, maybe 5 %)._________________________________________________
Ricardo, if your listening area was still your HT room, would you still prefer monitors?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
yes, but although Phil likes bookshelf's he is adding some humor to the fray. I find some of the so-called experts comments rather humorus although they are serious, not really misguided, just believing they are the one.
We have a thread about the topic every so often. A good floorstander is predictable, bookshelves can hold more suprise, in my book a good floorstander will beat a good bookshelf everytime.
So I am biased, Big Speakers, Big Power, Go Large or Go Home. If your room is too small find another room.
RT1 -
What is this? No comment about tubes? :eek:
Are you feeling ok?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
I can assure you that is not true. What is true is that music lives in the mids and your bookshelf can do that.
RT1 -
tom,
Tubes Rule, I had Patrick put it my S/N title.
RT1 -
Go big, SDA SRS 2.3's, RTA 12's, Monitor 10's, dual HSU 3.3's with dual HSU MBM-12's and that will fill any room especially my 6000 cu ft one.
BillMy 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012 -
Good question. I think I would, based on what I have experienced. But, if you see my first post, I started saying "when talking about box speakers". Now that I moved to planars, I say you need the right radiating surface for your room._________________________________________________
pearsall001 wrote: »Monitors paired with dual subs will kick the living daylights out of a pair of floorstanders everyday of the week...and twice on Sunday's.
I'll put my floorstanders up against your monitor / sub combo anytime, and place a little wager on it too;) -
skip,
you have to remember he is hard of hearing in one ear and cant hear out of the other.......;) he sits off axis in a special spot so he can boost the one frequency that still comes through and tickles his ear bone.
RT1--and just so everyone knows I am OK, Tubes Rule.........
