Active DIY HT MTM Speakers
You may not have to recess those tweeters after all. It appears with steep slopes and MTM style speakers it's not very important.
http://www.musicanddesign.com/Dipole-offset.html
http://techtalk.parts-express.com/showthread.php?t=208939
http://www.htguide.com/forum/showthread.php4?t=33343
I'm planning on the electronic delay for the tweeters. I have to recess the tweeters the thickness of the woofer flange so I can reduce get the woofers closer together, but not enough to line up the voice coils.
I now have the mdf, and if anybody in DFW needs to know where to get a really good deal on that, they should contact Jeff at Casino Supply Company. -
Thanks for the tip!I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff. -
Thanks for the tip!
$1.50 for a 1' x 6' x 3/4 sheet is a great deal. I got 20 of them. He's got maybe 150-200 left. -
Great deal.I pay nearly $10 for 2'x4'x3/4" MDF at my local HD.$1.50 for a 1' x 6' x 3/4 sheet is a great deal. I got 20 of them. He's got maybe 150-200 left.Testing
Testing
Testing -
With exchange rates, that's pretty much what I pay here, $35ish for a 4'x8'x3/4" board. To special order a 1" or 1.25"x4'x8' it's $100 though! :eek:Great deal.I pay nearly $10 for 2'x4'x3/4" MDF at my local HD."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Too funny...I ordered six of them.:eek:Testing
Testing
Testing -
HAHHAHAHHAHA!!! Wow, I hope he isn't serious...SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality -
If you're interested, he's 100% serious.
Seriously! -
And back to speaker building...
I have a problem with the side surround design (using direct radiators in back). If I use a layout similar to the LSi f/x, with two woofers and two tweeters, my impedance changes because of the second tweeter. I could solve this by using a tweeter similar to the others, but in a 4 ohm nominal impedance, eg, use this:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-834
for the two tweeters in the side surrounds, instead of this:
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=264-822
which I'm planning to use for the MTM designs. The sound would have to be a little different, being a different tweeter, but it is side surround, and the high freqs are really rolled off anyway. Thoughts?
Also, I got the woofers in. They are very pretty, that's for sure. -
If you plan to also actively xover the side surrounds then impedance should not be an issue.2x the 264-822's in parallel will be 4 ohms which IIRC correctly your amps will be OK with.
Are they to be a dipoles or bipoles?Testing
Testing
Testing -
I haven't decided bipole or dipole, yet. I'm leaning toward bipole, but will read more before I decide. My concern with the impedance is that I'll get a very different response curve at 4 ohms than I would at 8, which is what the woofers would be at, like the rest of the system. Can that be compensated with gain? -
There may be some frequency response alterations due to comb filtering(interference)between the 2 tweeters because of the dipolar or bipolar radiation but otherwise the response will not change because of the lowered impedance.The output should be a few db higher , but thats as you mentioned easily fixed with a gain adjustment if need be.My concern with the impedance is that I'll get a very different response curve at 4 ohms than I would at 8, which is what the woofers would be at, like the rest of the system. Can that be compensated with gain?Testing
Testing
Testing -
Attached are wireframe and hidden views of the cabs. I'm using .75" mdf all around, with an additional 15/64" plywood layer behind the baffle for added stiffness and screw-holding capacity. I haven't shown the cutout for the binding posts, but it will probably go in the middle of the back panel.
I like the clean look of that box and the rounded corners on the front; very professional.
Thanks. I don't know how hard it will be to get a 1" radius quarter-round bit, but that's what ebay is for! When I get my shop set up, I'll post some pics.
Any opinions on the Axiom QS8 configuration for surround?
http://www.axiomaudio.com/qs8.html?1071#
I figure it's either that or the LSi f/x arrangement. -
Interesting design.If you are looking for more of a diffuse vs directional response then that driver arrangement should do it.Testing
Testing
Testing -
I've slightly altered my design, reducing the height by .5", to make MUCH more efficient use of the the big stack of mdf that I have. Still maintaining the golden ratio in internal dimensions. Will post plans soon.
Now, anyone got suggestions for some really pretty screws to mount the drivers? I figure I might skip grilles, and if I do, the screws should be very pretty. Nothing too shiny, as that would be distracting in an HT environment. But something damned cool. -
I agree, and that's what I was thinking of. I wish they'd put the head diameter on those - my woofers have countersunk screw holes. -
You might be able to give them a call and ask. What's the worst they could say, "We don't know?"
That's what they'd probably say, actually. But I'll try.
Any opinions on grille-less speakers? -
As long as you don't have children that would destroy your dustcaps or domes, why not?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Ah, the blessings of a DINK household...
And dogs really aren't irresistibly compelled to "press the buttons." Oddly, though, my wife admits to finding it very hard to resist. -
ALMOST ready to begin construction, and I have some questions. After I get my Sonic barrier internal damping sheets for the insides and F13 felt for the baffle outside, I'm going to build a trial box. I'm going to start with the 2" Precision Ports with no tube between the flares, for an effective 4" port.
When I get a box built, I'm going to test near-field outside using my Rane RE-27. Here's where I could use some help:
I'm building these to be used with subs crossed at 80 Hz. I plan to use the 7.1 analog outputs of a blu-ray player with bass management, just using my Sunfire pre/pro as a preamp only. To mimic this configuration (I don't yet own a player) I need to know what kind of crossover slope the players typically use.
Any ideas? -
I was wondering what happened to you:D
I believe most pre/pro's will use the THX standard of an LR4 lowpass and 12 db hi pass both at 80hz.As for Blu Ray players I can't say specifically but if they are built to the THX standard then it should be the same.I'm building these to be used with subs crossed at 80 Hz. I plan to use the 7.1 analog outputs of a blu-ray player with bass management, just using my Sunfire pre/pro as a preamp only. To mimic this configuration (I don't yet own a player) I need to know what kind of crossover slope the players typically use.
Any ideas?Testing
Testing
Testing -
Here I am!
I read some stuff like that, saying that the 12 db hi pass slope complemented THX cert speakers with a 12 dB cutoff slope for a summed 24 dB slope. I want the port tuning to be well below the crossover point, around 50 Hz, to achieve a flat response when crossed, and to avoid port-related nastiness. My Rane xovers are 4th order, so they won't properly mimic THX standards. But my RE-27 eq/analyzer could be set to mimic that slope somewhat, I guess. -
Oh, and I went with the Dayton 1-1/8" Neo silk domes for the tweets. They were reviewed more favorably than the TB tweets, and I got a heck of a deal on them.
