LSi 15 crossover burned
  • Face
    Face Posts: 14,340
    edited April 2009
    I was kidding before, alll volume controls aren't linear.
    You should be able to listen at 90-95db without a problem. Since they are used, it's possible that they were abused before. It could also be that your amp is passing DC and is in need of service. If it happens again, have the amp checked out.
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    Face wrote: »
    Face,
    Thanks a lot, I am very new at this and have a lot to learn. Is there an easy way to check to see if the amp is passing DC??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Face
    Face Posts: 14,340
    edited April 2009
    Possibly with a DMM, I honestly have no idea though.
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    I have an electronic genius friend I will ask tomorrow...most likely will know more than I want to afterward:eek:
    This place is great, I really appreciate all the advise and information!!:D
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Vette C6.r
    Vette C6.r Posts: 1,560
    edited April 2009
    Same thing happen to my XO's on the 15's and the LSic. For me it was caused by an all night party and loud levels.
    Luckly the store that I got them from is super friendly and took care of both of them and even replaced the tweeters for free.
    I did learn my lesson though.
  • McLoki
    McLoki Posts: 5,231
    edited April 2009
    vmaxer wrote: »
    Isn't clipping from not enough power?? I think I have the opposite problem.. The Sunfire Signature is rated at 810 watts at 4 ohms. Ken Swager also said it can be caused by too much power. As I understand the tweeters usually get fried first from clipping. I use to have that issue until I upgraded to the amps I have now.....
    My pre doesn't have a marked knob, it turns a long way also, so the 12 o'clock don't work either.
    I have a pair of crossovers coming from Polk and will be back up.
    There are three signals that could be clipping.
    Source to pre
    Pre to amp
    amp to speakers.
    I think your amp to speakers is covered pretty well and that is what you are running the 810 watts to cover....
    Source to pre is mainly if your source is recorded overly hot or you have a variable output turned up to far.
    Pre to amp is the individual channel adjustments that you can make in your avr. If these are turned up to far, they can clip the output signal to your amp.
    The first two adjustments (source to pre and pre to amp) can cause clipping even at fairly low volumes as they often occure before the volume control in the signal path.
    Good luck on your search,
    Michael
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    McLoki wrote: »
    Source to pre
    Pre to amp
    amp to speakers.
    Michael
    First, Thanks for the tip..I hadn't thought of that.
    I can check the levels in the pre, is there a level that is best ...better to keep them on the lower side, maybe 0 or below??
    I have no idea of the source to the pre, unless you are talking about the levels in the DVD/SACD player. I think they are all on 0 and the system is balanced in the pre. Is this what you are meaning or am I missing the point??:confused:
    Thanks again to everyone!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    F1nut Posts: 51,695
    edited April 2009
    vmaxer wrote: »
    No, clipping results from overdriving the amp be it 10 wpc or 800 wpc. In that vein, watts don't mean all that much. Current (amps) and headroom, resulting from beefy power supplies, are what makes an amp "powerful."
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    Kex wrote: »
    Only Ben listens regularly beyond 100dB, and even he admits to having calmed down recently (if we can believe him), and besides, he likes to flip lawnmowers in his spare time, so I wouldn't trust him if I were you.
    :eek:Flipping lawn mowers...I did that once and that was enough for me....Sounds like an adventurous type of person!!
    I will admit that I sometimes like to listen to 2 channel a bit loud......
    It really would be nice to have a method to know the limits.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • ben62670
    ben62670 Posts: 15,969
    edited April 2009
    Hey bud I have only gone completely over once in my whole life. I even had a lawn mower I named Herbie(the love bug) that we used to do wheelies with(1982-), and I never flipped it. My neighbor did, but I never did:)
    OK back to audio. You really should get an SPL meter. Good speakers/gear can go a lot louder than you think while being clean. It is real easy to figure out how much power your speakers are using. LSi's are mostly 88db for 1 watt at 1 meter.
    1w=88db
    2w=91db
    4w=94db
    8w=97db
    16w=100db
    32w=103db
    64w=106db
    128w=109db
    256w=112db
    512w=115db
    This table can be adjusted for other speakers. You need to double your power to gain 3db. Adjust your SPL meter to C weighting, and slow to get your measurements. Please note that receivers, and lesser amps can not sustain the currant necessary to maintain high db listening with out damage. A good 60wpc amp is much better than nearly all 150wpc receivers;) Also the 5w resistor used in the LSi's should have been specked at 10-12 watts for the application. The tweeters are 4ohms and place too much current load on the 5 watt pieces when listening to the speakers cranked for extended periods of time. Also please do not turn up the treble on your pre, or receiver. This places an unnecessary load on the speakers.
    Ben
    Ben
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    ben62670 wrote: »
    1w=88db
    2w=91db
    4w=94db
    8w=97db
    16w=100db
    32w=103db
    64w=106db
    128w=109db
    256w=112db
    512w=115db
    Ben
    Ben,
    I appreciate your response. I do have a analog SPL meter from Radio Shack and will use it to find my "safe zones" per your chart.
    Another question, earlier in this thread I have been advised to check the tweeters....how is this done?? I checked with a multimeter and get about 2.8-3.0 ohms?? Is it this simple??
    I don't usually use the trebile or bass controls, I leave them on 0.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • ben62670
    edited April 2009
    The readings on your tweeters are in order. Sometimes the voice coils will heat up and drag making some distortion. You should be good. If you are running a receiver figure max volume to about half the "rated" watts. IE a receiver rated at 125w "4ohm capable" you should only drive your speakers to around 106db peaks.
    Ben
    Ben
  • McLoki
    McLoki Posts: 5,231
    edited April 2009
    vmaxer wrote: »
    Ben,
    A few other things to keep in mind - how far are you from the speakers when you listen, and how many speakers are you listening to? Both of those questions can move that chart up and down....
    for example - if you're listening position is 12 feet away from a stereo pair - you need to drop two lines from bens chart. (essentially your would start with 82db efficient not 88db meaning you are at 512 watts with only 109db, not 115.
  • ben62670
    edited April 2009
    McLoki wrote: »
    Thanks for clearing that up. Measurements for power handling need to be taken at one meter:o
    Ben
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    ben62670 wrote: »
    Ben
    See my list below,,,I am using a Sunfire Signature 405 watt at 8 ohm and 810 watt at 4 ohm.
    Thanks a lot to everyone for the continuing education. I am learning and the more I learn the more I find I need to learn:eek:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    trying again the signature line skipped out on me!!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • McLoki
    McLoki Posts: 5,231
    edited April 2009
    ben62670 wrote: »
    and with one speaker playing.... :D
    The math works like this:
    Every time you double the distance from the speaker, SPL drops by 6db. (12 feet - about a 12db drop (6db from 3-6' another 6db from 6-12'))
    Every time you double the number of speakers (very close to each other compared to your listening distance - (more technical than that - but for our purposes close enough)) you increase the SPL by 6db.
    When playing a stereo pair - your chart is accurate (or close anyway) with a listening position about 2 meters (6.5 feet) away from the speakers.....
    Michael
  • ben62670
    edited April 2009
    vmaxer wrote: »
    ...Thanks a lot to everyone for the continuing education. I am learning and the more I learn the more I find I need to learn:eek:
    It is a vicious cycle:eek: I feel much dumberer than the day I signed up here at CP:p
    Ben
    F1nut Posts: 51,695
    edited April 2009
    You're being generous.
  • Hawkeye
    Hawkeye Posts: 1,313
    edited April 2009
    vmaxer wrote: »
    Does anyone here know if there is such a thing as a "wattmeter" that you can check and see how much power you are sending to your speakers?? I know some amps have them?? I sure would like to know where my limits are...
    I don't think that is what caused this failure as I wasn't playing them that loud..
    I'm not aware of an outboard wattmeter you could in line with your speakers. I do know that my amps are true watt meters and are accurate to within 95%
    It sounds like your XO was lame to begin with. If it wasn't, then maybe an available 800 watts for an extended period at high spl levels is too much for your speaks although pretty much doubtful.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    Update...
    I received a pair of new crossovers from Polk and have replaced the one that fried.
    :D Polk customer service is the best I have ever dealt with.:D Absolutely Awesome!!!
    :cool:And it seems like that type of attitude is carried over here by most everyone, a great bunch of people. I really appreciate all the advise and information provided here. A lot of you spend a lot of time here helping others. I hope some day I can return the favors and give something back!!:cool:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • ben62670
    edited April 2009
    Yes Polk CS rocks. I have never dealt with none better:)
    Enjoy.
    Ben
    Ben
