LSi 15 crossover burned
vmaxer
vmaxer Posts: 5,120
edited April 2009 in Troubleshooting
See attached photo of the LSi 15 crossover that burned...What causes this??
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Post edited by vmaxer on
  • McLoki
    McLoki Posts: 5,231
    edited April 2009
    I would guess to much power - but not sure. (or maybe your amp shorted and was putting out a DC current...)
    It looks like the resistor got hot. A pretty inexpensive fix. Order a 12watt mills and go on with your day.... Any other components that got melted?
  • ben62670
    ben62670 Posts: 15,969
    edited April 2009
    McLoki wrote: »
    Plus 1. Come over and I will do the mod for free.
    Ben
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    What mod?? Are you talking modifying or repairing as it was?? I just got the speakers today and played a couple of hours...Thinking it should be a warranty item??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Face
    Face Posts: 14,340
    edited April 2009
    What are you driving them with?
    F1nut Posts: 51,703
    edited April 2009
    Sizzle lean with Jimmy Dean!
    Good question. And how high was the volume control?
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    I have them hooked up to a Sunfire Signature 405X5. I really didn't have the volume that high. As I said I had just got them and only played them a couple of hours. The tweeter on that speaker was weak from the start, I actually unplugged the bottom wires to see if the tweeter was playing before it burned up??:confused:
    All I have read about the LSi 15's says the more power the better. I have accessories coming to actually bi-amp them with 405 watts to the top and another 405 to the bottom?? I know they won't take that much (at 4 ohms this amp is pushing 810 watts). I had this amp hooked up to RT55i's and played them a lot louder without any problems. If it matters I am using a Sunfire TGP 5 pre...
    This is going to sound stupid....how do you know the limit on the volume?? Do they make an in-line meter so you can see how much power you are feeding them?? My problems in the past were not enough power and frying tweeters on the RT55i's??:eek:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    I updated my sigature so you can see what I am using now...
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • george daniel
    george daniel Posts: 12,096
    edited April 2009
    I'm wondering if the resistor was on it's way out when you got them,,and you just helped it along, you should be able to replace it with a mills 12 watter and be good to go,barring any other bad components in the crossover,,having heard a pair with the upgraded crossovers(Ben's work),,if you are in the neighborhood,, take him up on his offer.Good luck,,let us know how it turns out.
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    Okay..I don't know much about this, I can replace it but I don't know where to get the part you mention??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    Should I do this on both seakers?? When I look the part up it is available in several ohm ratings?? What part number do I need??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • ben62670
    edited April 2009
    Partsexpress.com
    I would replace both.
    Ben
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    There are many Mills 12 watt, which one do I need??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • george daniel
    edited April 2009
    Replace them with the same rating(ohms),,ex; 2 ohm 5 watt----replace with 2 ohm 12 watt.
    Look at the specs on the original resistors on the crossover.
  • McLoki
    McLoki Posts: 5,231
    edited April 2009
    There are 3 - 2ohm resistors going to the Tweeter and 2 5.25 mid-basses. There is also (I think) 1 - 3.5 ohm resistor going to the 8" bass driver.
    I am going to guess that you smoked the resistor going to the tweeter (you will want to verify that though) what speaker is not working?
    I think the resistor in the tweeter circuit is a weak link in the LSi's. I have seen one and heard of 3 others, lSiC resistors that have desoldered themselves from the circuit board in the tweeter circuit of the LSiC. Based on that, i would just replace the 2 ohm reistor in the tweeter circuit of both speakers.
    On a side note - If you just purchased the speakers from an authorized reseller, I would call Polk customer service and ask if it is covered under warrantee before you make any purchases. Either way - it shouldn't be a hard fix.
    Michael
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    I purcased them as refurbished direct from Polk Audio. I sent Ken Swauger a message and will talk to him a little later. It is the tweeter that stopped working.
    :DI want everyone to know that I sincerely appreciate the answers!!:D
    This forum is great!!:D
    It sounds like I need to modify the crossovers at some point in time either way??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    nooshinjohn Posts: 25,893
    edited April 2009
    if you got them from POlk Direct, they will probably send you a replacement without to much hassle. You may want to test the tweeters as well. Polk service rocks!
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited April 2009
    Hello,
    Sorry I wasn't here yesterday, dental surgery. Hopefully you were able to contact one of the other folks here?
    Regards, Ken
  • BlueFox
    BlueFox Posts: 15,251
    edited April 2009
    vmaxer wrote: »
    It is certainly a good thing you were not using an AVR. Otherwise, everything would have burnt up; speakers, crossovers, cabinet, etc. I can only thank my lucky stars my 4 LSi15s and LSiC did not burn up for the three years I used an AVR before I got my Sunfire TGA5400. Oh, wait....Sunfire. Oh!! No!!!!! :rolleyes:
  • ben62670
    edited April 2009
    Hello,
    Regards, Ken
    Well I hope all is well with you. Tooth aches can suck real bad.
    Take care Ken
    Ben
    Ben
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    BlueFox wrote: »
    I'm not sure of how to take this?? Care to provide a bit more insight??:confused:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    ben62670 wrote: »
    Ben,
    What mods do you do/suggest??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • [Deleted User]
    edited April 2009
    Hello,
    Thanks, Ben. I'm much better today. I had a molar that had broken off and left the roots still in place. Yesterday the roots were removed, some bone grafts done and an implant post installed. It took about 3 hours to do, but the oral surgeon is very skilled.
    A dull ache and some tenderness is all I feel.
    Ken
  • McLoki
    McLoki Posts: 5,231
    edited April 2009
    vmaxer wrote: »
    Ben,
    If you are going to mod - this is a proven place to start....
    Michael
    BTW - Ken, Glad you are feeling better.....
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    Does anyone here know if there is such a thing as a "wattmeter" that you can check and see how much power you are sending to your speakers?? I know some amps have them?? I sure would like to know where my limits are...
    I don't think that is what caused this failure as I wasn't playing them that loud..
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    F1nut Posts: 51,703
    edited April 2009
    The meters you refer to are not an accrurate measure of power, they more or less just look cool.
    You can tell when your amp is clipping by the sound coming from your speakers. When the treble starts sounding harsh and the sound gets compressed, it's clipping.
    A general rule of thumb is to keep the volume knob below 12 noon.
  • quadzilla
    quadzilla Posts: 1,543
    edited April 2009
    Hmnmmm... what if you only have an LCD display that measures in db? I've had mine up to reference level (0) and it still sounded fine. It didn't start sounding harsh until I hit about +15.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    Isn't clipping from not enough power?? I think I have the opposite problem.. The Sunfire Signature is rated at 810 watts at 4 ohms. Ken Swager also said it can be caused by too much power. As I understand the tweeters usually get fried first from clipping. I use to have that issue until I upgraded to the amps I have now.....
    My pre doesn't have a marked knob, it turns a long way also, so the 12 o'clock don't work either.
    I have a pair of crossovers coming from Polk and will be back up.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    okay, I went and taped e a marker on the volume knob, it takes just over 6 full turns to go from 0 to 100...so I can't use the 12 o'clock rule...
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Face
    Face Posts: 14,340
    edited April 2009
    12 o'clock = halfway = 3 full turns
    :D
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2009
    Face wrote: »
    :D
    This is true, or since my display goes from 0 to 100 I could use 50 as the mark. I put a SACD in and played it there with the one speaker and get around 78 db on the SPL meter. If that is all I can get from this system I should go back to my Onkyo receiver and RT55i's.:( They would go well above that???:confused:
    The reading was taken aout 10 feet from the speaker.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
