Does anyone use equalizers anymore?
polkapolka
polkapolka Posts: 145
edited April 2009 in Electronics
If so, who, what, why, $, you know, all the good stuff!
Thanks,
Matt
Mitsubishi 60" HD LDP
Polk RTI-A3 L/R
Csi-a4 CC
Polk CSW 10 Sub
Pio. Elite VSX-03
Pioneer BDP-51FD Blu-Ray
Polk Fxi3s for surround.[/SIZE]
Post edited by polkapolka on
«13456
  • zarrdoss
    zarrdoss Posts: 2,562
    edited April 2009
    I do I have a BSR eq300010 band and you can still get an Audio Source at home depot or here
    http://www.nextag.com/audiosource-eq-200/stores-html
  • McLoki
    McLoki Posts: 5,231
    edited April 2009
    I use a BFD (behringer feedback destroyer) on my subwoofers. Has stereo 12 band parametric eq's. (although I only use about 4 or 5 bands of one channel)
    Has made a huge improvement in the bass of my system.
    Michael
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2009
    Velodyne SMS-1 on my subs if you want to call that an EQ.
  • jinjuku
    jinjuku Posts: 1,523
    edited April 2009
    I am using the DCX 2496 to EQ my setup and for sub-woofer management.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited April 2009
    My Polk HT sub-amp has an EQ card designed for that particular Polk sub speaker.
    Besides that if your rack needs an EQ something is lacking in your gear or you just like a particular frequency.
    RT1
  • inspiredsports
    inspiredsports Posts: 5,502
    edited April 2009
    Older NAD products provide a bass equalization circuit that can be switched on or off, and +/- 6db parametric controls at 50, 120, 250, 3,000, 6,000 and 12,000 KHz that can used or completely switched off. Both circuits are exceptionally well thought out and quiet with regard to additional distortion.
    Since rebuilding crossovers, installing RDO198-1's and upgrading IC's and cables, I have found absolutely no equalization is needed and I now listen with the bass and EQ circuits permanently in the off position.
    I agree with rt1 above. As food for thought, you might consider putting the money you would put into an equalizer into balancing your system out with better main components.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
    mhardy6647 Posts: 35,033
    edited April 2009
    No (nor did I ever) but the Behringer DEQ2496 Ultracurve Pro Digital EQ/RTA is an intriguing little gizmo at a comparatively bargain price.
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=248-661
    The original version of this thingamabob enjoyed some popularity in audiophile circles when it was new.
    http://www.audioxpress.com/reviews/media/203hansen2196.pdf
    (N.B. I have no ears-on experience with these)
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2009
    Nope.
    heiney9 Posts: 25,437
    edited April 2009
    Nope, never. If you need one then you have other issues. I can see it's use to "tune" a sub in an HT system but in a nice 2 channel rig absolutely not, IMHO. I don't have or even like bass and treble controls in the signal path
  • jinjuku
    edited April 2009
    RT1
    Are you saying that no EQ should be required? or that the EQ routine in AVR/Pre-pro's are good enough, or that tone controls will do the trick? Most subs and pre-pro's / AVR's have some form of correction routine built in.
    You normally EQ to set a house curve. You can have great equipment in your rack, but you still have to account for room characteristics. It made a difference for me even after room treatments (though they helped a good deal).
    The nice thing about an intelligent EQ is you can store several settings. You could have an HT setting, another for Music,and break it down even further from there for the type of music, if you really wanted too.
    edited April 2009
    No equalizer or tone controls are needed if you're gear is up to snuff. There are extreme situations where room acoustics might dictate trying to fix gaping problems. For me personally I'd not use that room or figure out a different configuration before using an EQ or any tone control.
    With my set-up I'm willing to take the warts and all with the recordings. With a passive pre-amp and 2 gain stage amplifier it's about as close to straight thru as one can reasonably get. My system sounds fantastic with well recorded material and so-so with poorly recorded material, but I get all the "essence" of the original recordings. No EQ will make the poor recordings sound like the stellar recordings...........the damage was done at the mastering/recordings phase.
    Listening to the Beatles is certainly just as rewarding as listening to a GRP jazz selection even though the recording process and quality are worlds apart. Some people just like the "boom, boom, tizz, tizz" not me.
  • bluecomet
    bluecomet Posts: 1,118
    edited April 2009
    I have multiply systems that I like to play with. Lazareth is right about not using an EQ with SDA's. It does not sound right. I have a 3 band parametric EQ from SAE and I have found it does help with certain speakers. I think it helps Monitor 10's, especially in the mid's. It is much more clear and I like the fact I can boost the bass, mid's or highs if I find a need to. I like them with older seperates and not built in EQ's that are in some receivers. They are not for everyone but I have found they are usefull in older gear.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
  • jinjuku
    edited April 2009
    heiney9 wrote: »
    Agreed that EQ is normally the last thing you should try. That goes with out saying. The real issue is: How many people actually have the luxury that you speak of?
    A nice EQ lets you get correction on a number of fronts: Boundary and Time Domain. These will be problems for most squarish shaped rooms (which last time I checked is the norm in most houses).
    I think for all the money spent on speakers, amps, electronics, interconnects, what is another $300? You can always defeat the EQ if things aren't too your liking with it in the chain.
    I don't even think that you need to wait for gaping problems to use an EQ. Getting nice flat in room response is desirable in most any situation. Have you taken the opportunity with an RTA to get a glimpse of what your curve looks like vs what you perceive (simply asking out of curiosity, listen to what sounds best).
    edited April 2009
    Not sure it's a luxury but I have a lot of trial and error to get where I am. It's just my personal opinion not having any tone controls. I've never found tone controls/eq's or eq type circuits to be beneficial in any way. They seem to sound very unnatural in most instances.
    I admit at times for some older recordings a bit of bass boost would be nice, but in the end it ruins the "essence" of the original recordings. I would deem it sacreligous to add bass boost to an old Robert Johnson recording........just doesn't seem right ;)
    Not sure if I made it clear but I'm strictly 2 channel and perhaps some fine tuning is needed with an HT system to really make it shine for movies and special effects, etc.
    YMMV
  • jinjuku
    edited April 2009
    heiney9 wrote: »
    YMMV
    I haven't had a strictly two channel setup for going on 14 years now. I remember with the two channel setup: pick some listening spots, position speakers X/Y from walls, toe speakers in/out and enjoy ( used masking tape to mark all my positions. It wall all about placement which is a form of EQ.
    The issue with 5 or 7 (plus sub) is you don't get the flexibility of placement. So yes there is a very valid point of not have to correct for much when dealing with only two speakers.
    edited April 2009
    jinjuku wrote: »
    Look I've been down the EQ path in the early 80's. Left them as well as tone controls behind. After 25+ years in this hobby, I know what sounds good and frankly I'm there as far as a stellar sounding rig. The more I take out of the chain, the better and better the system sounds. Why would I want to start adding things back in? I've worked long and hard and spent some $$$ to make my sytem as basic and simple as possible. It has paid off in a big way.
    edited April 2009
    jinjuku wrote: »
    I haven't had a strictly two channel setup for going on 14 years now. I remember with the two channel setup: Position speakers X/Y from walls, pick a listening spot, toe speakers in/out and enjoy. It wall all about placement which is a form of EQ.
    Oh I see :rolleyes:, I suppose adjusting the seat in your car is just like getting a tune-up.
    You PAINT a very broad and IMO, idiotic definition of EQ. I believe the OP is talking about some external box or built in set of parameters that alters levels of certain frequencies when used.
    If that means, toeing, distance from walls, listening postion, etc. you are way off, but certainly entitled to your opinion. But I think most will agree that's quite a strech.
  • wizzy
    wizzy Posts: 867
    edited April 2009
    While some may say you don't need one if all your equipment is straight from the nads of the lord herself, this doesn't take into account the material one listens to.
    If you have a lot of bootleg, live recordings, a good EQ or parametric EQ can be wonderful.
    I know listening to a lot of live GD / Phish / etc. recordings it can make all the difference in the world.
  • jinjuku
    edited April 2009
    heiney9 wrote: »
    Thats great, really it is. I even stated that EQ is a last resort (because it is). If you have room problems still after taking appropriate measures, than an EQ is still a viable option.
    There is a reason why every manufacturer has a built in EQ routine. Most people simply have a wonky listening environment.
    My goals in this thread are to put relevant and useful information for the lay person that is researching this stuff. That is all. We simply have a difference of approach and opinion. I am not disagreeing with you and your PARTICULAR listening environment. Again listen to what sounds best to your ears.
    I have a friend and his son that purchased HT gear (Pioneer 1015's, RHT in walls etc...) for their respective homes. For the longest time they simply hooked stuff up and ran at defaults. I visited and found out they never ran room correction (never mind trying talk them into room treatments). I dug out the microphone and ran the MCACC and it made a positive difference for them. I don't know what else to say.
    edited April 2009
    wizzy wrote: »
    I have 350 LZ boots and about 150 Hendrix boots and probably 300 or so various other artists and some sort of tone control can be beneficial. I guess that's why I have my office/computer room rig. Strangely enough there are no tone controls in that rig either and I do get by fine listening to boots.
    If I have a particularly poor boot recording I'll fire up WINAMP as the player and adjust as necessary, but this doesn't happen very often. Otherwise I bypass all the Windows drivers and use an unaltered digital output into a seperate external DAC into a little 13wpc tube hybrid integrated and it sound really great.
    edited April 2009
    jinjuku wrote: »
    Last time I checked Pass didn't have any, or my Adcom pre-amp or my Adcom DAC.
    Perhaps you are talking about HT type pre/processors and AVR's.
    edited April 2009
    Look JJ, I don't disagree totally, but my advice to any "lay person" is tread lightly with this kind of stuff because if things are that deficient, then it's time to start looking for better gear if you find yourself being unsatisfied.
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited April 2009
    heiney9 wrote: »
    I don't use any EQ, haven't since buying my SDA's 20 years ago. But I am curious how buying better gear would correct room issues.
  • jinjuku
    edited April 2009
    heiney9 wrote: »
    EQ stands for Equalization. EQ is meant to improve an imperfect listening environment.
    You haven't explained what the 'stretch' actually is...
  • reeltrouble1
    edited April 2009
    William,
    well for one thing it certainly improves the look of the room. for you some fung shwei??? decor might work as well.
    besides you slipped two thoughts in there W, dont see in the quote of H9 where he said that buying gear corrects "room" issues????
    RT1
  • jinjuku
    edited April 2009
    heiney9 wrote: »
    Yes I am. I am sure that at this level most people would prefer a standalone eq of their choosing in a strictly 2 channel setup. That is the point behind going separates.
    I am looking at the OP's signature line that includes his equipment and making an assumption that he has an HT setup.
    edited April 2009
    WilliamM2 wrote: »
    Never said that or eluded to that. In my direct experience what I thought were room issues several years ago were "cured" by moving up the gear ladder, not by trying to EQ the deficiencies out of my lesser equipment. Not saying that is absolutely always the case............but everytime I made an improvement in gear the sound became more pleasing.
    You always seem to read more into a post than anyone I know. Feel free to add whatever you deem necessary to twist these words to fit into your personal POV.
    As always in this hobby YMMV
    edited April 2009
    jinjuku wrote: »
    Oh, I see now you want to use the OP and specifics about his gear/question to futher your point, except when you made the comment about speaker placement, listening position, etc that was clearly outside the scope of what the OP was asking about EQ's just to be argumentative. :rolleyes:
    Again, twist it however you want to fit into your needs.
  • jinjuku
    edited April 2009
    heiney9 wrote: »
    Actually I was agreeing with you on a potential lessening of need for EQ in a two channel setup vs a 5 or 7 channel setup. This agreement being based on the fact that you have more placement options to deal with less than perfect room conditions. That post was simply in context of what you had written, nothing to do with the OP. Really trying to stay on topic for the OP and what looks to be an HT setup :)
  • jinjuku
    edited April 2009
    heiney9 wrote: »
    If you run Vista, MS did away with Kmixer and the subsequent re-sampling that it did.
    In XP you need ASIO to do this, in Vista it is a non issue.
