Active DIY HT MTM Speakers
soiset
Design goals:
A high-quality home theater design, with good dispersion and plenty of punch, an F3 well below 80 Hz, which will be the sub xover freq, and excellent clarity.
Speakers:
Dayton RS-150 6" drivers, pair
Tang Band 28-847SD tweeter
.75 ft3 box, ported
image of layout attached
Speakers:
.75 ft3 box, ported
Post edited by soiset on
Good idea getting that center to center spacing as close as possible.Testing
Testing
Testing -
I forgot to mention that the smallest circle is just the schematic port location (not sure if that is the best location or not - but it would effectively reduce the baffle at the tweeter). I spaced the woofers by a common formula, with an 1800 Hz xover, then squeezed the tweeter in tight. The tweeter would be flush, and the woofers would be surface. I could actually move the tweeter closer to the center, but I'd be eating up more of the tweeter flange under the woofers.
I've seen so many MTM designs where they seem to ignore the woofer spacing crossover rules. Are they going for aesthetics? Build simplicity? -
I used a similar baffle layout for an MTM center channel(now replaced by an active 3way).The small flanged SEAS that I used (H1397)allowed for close spacing of the 2 6.5" mid/woofers.Center to center spacing is even more important for an MTM positioned horizontally.The crossover was at 2k.
With your tweeters low resonance 1.8k with 24db slopes should be no problem.
I would be tempted to place the port on the rear panel,then any chuffing noises will not be heard.
Aswell as the delay you are adding for the tweeter,you might need to add some baffle step compensation so that the speaker does not sound lean in the lower mids/ upper bass.It will require modding your Rane xover .I can provide more info on this if you would like.
Do you have access to schematics for the Rane?Testing
Testing
Testing -
I do have the schematics. Rane is really good about that sort of thing. How, generally, is bs compensation different from equalization? -
Yeah, I'm pretty stoked about that Tang Band tweeter. It enables so much. WRT chuffing, I was hoping that with flares, both internal and external, that I could avoid that. I could design for especially low velocity, in addition. The tuning freq would be well above 40 Hz, anyway. -
You know, I keep reading and reading, and it seems that BSC in a design ends up being kind of a dart thrown with a blindfold on. The speaker's in-room response is just so unpredictable, even the models for predicting based on the baffle itself and tweeter are pretty close to guesswork.
So it seems that the better thing to do is first, limit the baffle step in the first place, by cabinet design, and second, adjust once it is all in place, if even necessary. For a nice two-channel setup, making the baffle around the tweeter really, really tiny (like B&W's top-mounted tweeters) would seem to be key, as well as having nice tapered edges on the baffle. If done well, it seems the need for BSC would be eliminated.
In the case of HT speakers such as those I am planning, where the box is much simpler (gotta build a slew of them, after all, and they need to be mounted simply), minimize the baffle step with a narrow baffle, off-center spacing, filleted edges, etc., and then EQ out the rest. I'll be using Rane's THX eq's anyway, and since we are only talking about a few dB, the magnitude and center frequencies of which won't be known very accurately until the speakers are complete and mounted, it just makes sense to fix it last.
I could be wrong, of course. Feel free to tell me so. Really. -
When done electronically with opamp,the response will begin a gradual rise below (right down to DC) the chosen center freuqency.EQ is generally limited to a small bandwith.how generally, is bs compensation different from equalization?
Here is how to incorporate it with an op amp.http://www.t-linespeakers.org/tech/bafflestep/bstepcompo.html
Heres some more reading.http://www.trueaudio.com/st_diff1.htmTesting
Testing
Testing -
Having minimum baffle area ala B&W and Vandersteen( or better yet the Egg shape used by Waveform)will improve dispersion and off axis response but there will still be a step,it will just occur higher up in frequency.I should add that depending on xover frequency and slope etc.the step may then be mostly nullified by the xover when it occurs higher up.really tiny (like B&W's top-mounted tweeters) would seem to be key, as well as having nice tapered edges on the baffle. If done well, it seems the need for BSC would be eliminated......I could be wrong, of course. Feel free to tell me so. Really.Testing
Testing
Testing -
True, but if the baffle is small enough, it will be at such a high frequency as to be inaudible. The wavelength at 20 kHz is 0.67".
What do you think of the baffle-less pvc pipe design at PE? -
BSC is usually only used for response shaping below 1k or so,not the treble range.True, but if the baffle is small enough, it will be at such a high frequency as to be inaudible. The wavelength at 20 kHz is 0.67".
I have not seen it.
What do you think of the baffle-less pvc pipe design at PE?Testing
Testing
Testing -
Here it is:
http://www.parts-express.com/projectshowcase/indexn.cfm?project=TotallyTubular
Unfortunately, the tweeter does have a baffle, and the very worst kind. I don't know why he didn't choose a pipe that matched the size of the tweeter flange. The baffle step must be huge. -
Revised baffle attached. The size of the Precision Port flare for a 2" port requires placement at the bottom (along with the principle of leaving space beside the port equal or greater than the diameter of the port). So a 20" cab with .75" walls just barely contains everything properly. Tuning will be 40-50 Hz, well below the sub xover of 80 Hz. Between that and the flares, port noise should not be an issue at all.
You know, it would be a lot easier if you bought a pair of used LSi9's then upgraded the caps and resistors.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Agreed.Tuning will be 40-50 Hz, well below the sub xover of 80 Hz. Between that and the flares, port noise should not be an issue at all.
Boring:pYou know, it would be a lot easier if you bought a pair of used LSi9's then upgraded the caps and resistors.
Testing
Testing
Testing -
Agreed.
Boring:p
Not just boring, but not taking into account that I'm building a LOT more than a pair of these! I figure the time/money per speaker will end up being very low, considering the efficiency of scale.
For finish on these, I'm thinking that I'll just take the cabs in to a body shop, and have them shot there. I could get all the equipment and paint, etc, but I just don't think that's worth the investment right now.
Matte charcoal or something similar, just suitable (dark, non-reflective, and kewl) for an HT environment. -
He's just fun'in ya,he has been known to like the taste of MDF dust himself.Not just boring, but not taking into account that I'm building a LOT more than a pair of these! I figure the time/money per speaker will end up being very low, considering the efficiency of scale.Testing
Testing
Testing -
That's what I figgered. He was playing a role (and a common one, at that). -
Where would you get that from?He's just fun'in ya,he has been known to like the taste of MDF dust himself.
http://face.cleanandquiet.com/store/Speaker%20Testing%202-12-09b.jpg
Pay no attention to their ugliness, I've also been dealing with baffle diffraction issues. My last baffle tested much better, but now I have to figure out how to make it look good. It never ends.
In turn, I wish you the best of luck."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Pay no attention to their ugliness, I've also been dealing with baffle diffraction issues. My last baffle tasted much better, but now I have to figure out how to make it look good. It never ends.
Fixed it for ya.
I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff. -
Alternate baffle design attached. I've adjusted the cabinet dimensional ratios to be golden, which only slightly widened it. The alternate design would use a .5" layer of mdf as an additional layer on the baffle underneath, which would offset the drivers so that sound-absorptive material could be placed in the hatched area. Besides the treble that reflected off the woofer cones themselves, that should eliminate the baffle-step problem entirely, right?
Your new design may well reduce high frequency reflections and improve the frequency response in the treble range.However baffle step, (or as Joe D'Appolito calls it diffraction loss) is a lower midrange/ upper bass issue.Besides the treble that reflected off the woofer cones themselves, that should eliminate the baffle-step problem entirely, right?
It will still occur with your new design as it relates to baffle width. (The wider the baffle the lower the frequency where the step will begin).Because of their longer wavelengths, at progressively lower frequencies the sound waves wrap around the baffle instead of being reflected by it.So upper mids will get some reinforcement from baffle reflection's while the lower mids and bass do not causing an imbalance.Testing
Testing
Testing -
My understanding is that all wavelengths less than the distance of the driver to the baffle edge will be reinforced, and will be operating in 2 pi space. The wavelength of 1800 Hz (xover point) is 7.5". The cabinet is 8.625" wide. Half that is 4.3125, which corresponds to a wavelength of 3100 hz. Horizontally, that should be the floor of frequencies reinforced by the baffle.
What I don't know is if the woofers themselves are counted as baffle width to the tweeter, that is, as the sound travels from the tweeter more or less vertically, the distance it crosses over the woofers would include a wider range of frequencies that would be reflected off the woofer cones and reinforced. -
You would use the full width 8.625" to calculate were the step starts.Aswell the transition from half space to full space is gradual as frequency decreases.The wavelength of 1800 Hz (xover point) is 7.5". The cabinet is 8.625" wide. Half that is 4.3125, which corresponds to a wavelength of 3100 hz. Horizontally, that should be the floor of frequencies reinforced by the baffle.
The woofers are definately reflective surfaces for the tweeters output albeit moving ones.This causes doppler or FM (frequency modulation)distortion of variing degrees.What I don't know is if the woofers themselves are counted as baffle width to the tweeter, that is, as the sound travels from the tweeter more or less vertically, the distance it crosses over the woofers would include a wider range of frequencies that would be reflected off the woofer cones and reinforced.Testing
Testing
Testing -
What if I coated the woofer cones in velvet? That would be sweet! -
Yeah it sure would:eek::rolleyes::D The question is what colour would be most effective,aswell it will help damp the high frequency break up mode of those metal cones.;)What if I coated the woofer cones in velvet? That would be pimpinTesting
Testing
Testing -
You may not have to recess those tweeters after all. It appears with steep slopes and MTM style speakers it's not very important.
http://www.musicanddesign.com/Dipole-offset.html
http://techtalk.parts-express.com/showthread.php?t=208939
http://www.htguide.com/forum/showthread.php4?t=33343"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Mr Linkwitz recommends adding the tweeter delay in systems with active xovers and does so with his designs using 24 db LR slopes.With passive xovers the phase differences can be easily fixed by adjusting component values.Thats not as easy to do with actives.The MTM arraigment solves the lobing issue but not the FR.You may not have to recess those tweeters after all. It appears with steep slopes and MTM style speakers it's not very important.Testing
Testing
Testing -
Thanks Fred.
I'm glad I didn't go active now.
To clarify,the delay can also be added by angling or stepping the baffle.With DIY actives it is very easy to add the necessary delay stage if your design uses a flat baffle.
Testing
Testing
Testing
