These any good?
MrNightly
http://kansascity.craigslist.org/ele/1091696201.html
I have no idea about HDMI stuff... I didn't want to pay 79 bucks at BB for Monster.
Thanks!
Thanks!
Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub
Denon 3805
Rotel RB-985 5-Channel Amplifier
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
Post edited by MrNightly on
This is a place where spec's mean a lot. If the cable is HDMI 1.3a certified, then it's a good cable, you can spend all you want on a better cable and gain no performance. I have tested HDMI cables and have learned from HDMI, there is no difference. They don't care who made the cable, they care only if it can perform. Once it passes, it's good.
I use all Binary HDMI cables.
DanDan
Ya but those aren't in town
I can spend 20 bucks on a couple cables, and if i need to upgrade down the road no biggie I think. Unless they are total crap?Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
Rotel RB-985 5-Channel Amplifier -
http://www.snapav.com/snapav/LISTVIEW1.ASPX?TYPE=PROD&VALUE=20
See if any dealers carry these, I use them myself and Install them everyday.
DanDan
eeek
Well, I picked up two for 20 bucks just so I can get the PS3 hooked up. They did pretty good I thought. Obviously will upgrade down the road... but for now, they do the trick.Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
